Puget Dude’s creations and fabrications (Random project thread.)
don long
southern california
Scott
You have blown me away with that sweet bench cabinet.
I just stumbled onto your thread tonight. You can tell by the time I'm posting that I have been here for a while.
I'll be checking in more often now.
Don
drivesitfar
I’m not sure how I kept missing your thread but it looks like you’ve been plenty busy.
Sorry you hurt yourself on the ladder. Lately just going up and down ladders has me pretty sore the next day.
Heal fast!!
P
PugetDude
Superstition Mountains, AZ
I have always subscribed to the old adage that if you fall off a horse, you need to climb right back on… my wife was in strong disagreement. She took this picture to show my sister what an idiot brother she has...
How do birds peck their way through concrete succo over metal lath? Spent the summer at the cabin up north, came home to find two half-dollar size holes at the stucco/ceiling corner- lucklily not in the wood- stucco is easier to patch.
Miss the Pontiacs
Saskatchewan Canada
Dryer tops, locker doors, cookie sheets plus of course some imagination/ingenuity and the result is amazingly. Now get the hell off that ladder and let your wife find you a beverage. 🍺
P
PugetDude
Time for another project post.
This one is a 30” sheet metal brake. (Actual width between the hinges is 30-3/8”)
Had a piece of 3” channel in my steel stash so I used it for the fixed frame and the movable bending beam. Hold down is 2” x 2” x 1/4” angle. Had to machine a clearance slot for the hinges- probably could have just used an angle grinder but elected for milling machine practice instead.
Hinges are fabricated from 1/2” pipe S80 pipe w/ 5/8” diameter cold rolled hinge pins. Drilled and reamed the pipe for a wobble-free fit.
There are a lot of simple DIY brakes on YouTube; one thing I wanted to do differently on this one was to make the hold down adjustable for gauge so I could use it for bending thicker aluminum.
Fabricated simple mounting pads out of 2 x 2 x 1/4" square tubing and 1/2" top plates, welded to the angle. Slotted the 1/2” hold down bolt holes about 1/4” and used a simple adjustment knob threaded into a tapped hole in piece of split heavy wall rectangular tubing welded to the stationary frame. The knob moves the hold down angle and keeps it from moving away from the bend line. It doesn’t need a lot of adjustment but it does make a difference when bending thicker aluminum. I’ve bent up to 1/8” with it (not full width) Made a couple of simple knurled locking nuts because I wanted to try a knurling tool I found in the box of tooling that came with the atlas lathe. Didn't have the height right, ended up with a single knurl- but it works just fine. The working edge of the hold down angle was ground to about 60 degrees to give a crisp contact surface. It was quicker to do it with an angle grinder than to set it up in the mill.
Added an adjustable top brace to pre-load the top angle to prevent camber. This was just a piece of scrap 1/2” rebar, a little chunk of 1/2” pipe and a bolt.
Top is pretty well done, time for the frame..,
P
PugetDude
The base frame was constructed out of 1-1/2" square, 1-1/2" x 3" and 1"x2" rectangular tube, I wanted it to be easily movable so I put a set of 8”solid tire wheels on it. Problem with a movable brake is trying to keep it from moving while bending.
The solution was a drop-down platform that I can step on while bending; it folds up when not in use. I used 1/4" plate for the sides and four scrap pieces of 1/2' x 1-1/2" rectangular ornamental iron tubing for the platform.
This makes it portable so it doesn’t need to be anchored in one place. Space is at a premium in my shop; this lets me park it up on the narrow raised section of the floor next to the pump cabinet and move it out when I need to use it.
Added a couple of removable handles for bending- these are just some 3/4" S40 pipe I had in my steel pile, with bike handgrips I found on Amazon Warehouse Deals. Added a couple of short pieces of tubing so I could store them out of the way when I’m not using it. Clevis pins to secure them in place during use.
Primed and painted with Rustoleum Hammered Silver.
Haven’t used it a lot but it’s worked well for the smaller sheet metal projects I typically do.
P
PugetDude
Knocked out a quick little project- more HF bin storage. Wanted to use up the rest of the old pine shelves, plywood, MDF, etc. I have been storing for way too long. Couldn’t go 3- wide on the bins; the lockers are only 48” wide. The half- width bins worked out well to fill up the open space. Interesting to note the AV receiver is almost exactly the same footprint as the HF bins @ 13” x 17”
The only thing I had to buy for this was paint to match the lockers.
Bears Fan
Indiana
Nice job on the metal brake! the copper house numbers look awesome too!
Good job on the Harbor Freight bin storage cabinet, that's one item I do like from Harbor Freight and they are priced right :thumbup:💲
Here's what I built to hold all my hardware, I still need to finish it with some storage on the right side and a paint job, nothing ever moves too fast in DaBarn, but I do manage to be working on 42 different projects at the same time :ROFLMAO:
P
PugetDude
Those bins are a lot more useful if you take them out of the plastic packaging…
Bears Fan
Indiana
I didn't want to get them dirty! I just haven't figured out how to get the hardware inside of them yet :unsure:
P
PugetDude
Finished up a Christmas present for my buddy Ron; my wife and I have celebrated Christmas together with him for almost 2 decades. We’ve done a lot of projects together, he does a lot of welding and fabrication.
This one started out as a chunk of 6” x6” x 1/2” wall square tube, that I picked up in a scrapyard, someone had torched off a piece of plate that had been welded on to it at some point.
(Note the heavy welded angle brace in the foreground-6" x6" x 1/2" angle with 1/2" gussets ….couldn't just leave it laying there. It's going to show up in this thread in the future…) ;)
When I was pulling the square tube out of the truck I “saw” a welding helmet. in it… so I decided to try my hand at a welded sculpture. I roughed out the shape with a 7” angle grinder and then cut out the top, neck and shoulder pieces of 3/16"”plate. The base is a piece of heavy 8” channel that I picked up with the square tube scrap, boxed the top and ends with 1/4" plate.
Took quite a bit of welding, blending with 40/80/120 grit flap discs to get it all smoothed out. Finished up with a 4-1/2" scotchbrite disc. Left it raw, he can clear coat it or just let it weather.
It’s heavy, weighs about 65#. Fun project.
RivennHewn
PNW
In
(Note the heavy welded angle brace in the foreground…. That’s going to show up here in the future…)
When I was pulling it out of the truck I “saw” a welding helmet. in it… so I decided to try my hand at a welded sculpture. I roughed out the shape with a 7” angle grinder and then started cutting out the top and base out of 1/4” scrap. The base is a piece of heavy 8” channel that I picked up with the square tube scrap.
Took quite a bit of welding, blending with 40/80/120 grit flap discs to get it all smoothed out. Finished up with a scotchbrite disc. Left it raw, he can clear coat it or just let it weather.
Hope you were wearing your steel toed Crocs.
Happy Christmas!
Bears Fan
Indiana
0b6398b9-fb9d-4549-94c0-b20177a4b619-jpeg.1794130
That piece of 6" x 6" angle iron caught my eye too! that would make one cool, heavy ***, industrial looking shelf :unsure: :)
Maybe add some big rivets in those holes?
