Took quite a while to get all the paint off the traffic light, using a selection of brass brushes in my M12 drill and die grinders but when I got there I thought it ended up looking pretty good in brushed aluminum. So, it’s going to stay that way for the time being. I have plenty of yellow paint if I change my mind later.
Built the mounting brackets out of 1”, 1-1/4”, and 1-1/2” pipe and. 1” Kee fittings. Used the 1” pipe inside the 1-1/4” to fit the larger diameter to the smaller galvanized Kee elbows- I have a bunch of 1” elbows and tees left over from another project, been trying to use them up whenever I can.
Bought a little controller on Amazon, currently have it running: Red@20 seconds, Yellow@10 seconds, and Green@30 seconds. Had some leftover sheet cork so I shot it with 3M spray adhesive and put it behind the controller; didn’t have enough room for the little plastic standoffs that shipped with the controller.
Got it mounted above the Texaco display cabinets since I had power up there already and I could hide the cord.
I’m calling this one done; I got tired of moving it from one side of the shop to the other over the last year; at least it’s finally functional and off the workbenches.
