Cave Creek Ray
After three years of house renovation and workshop overhaul, I am in the process of trying to get my garage renovated.
After drywall repairs and painting, I had new garage doors installed. With the new doors came new side-mount openers. The signal wiring between the wall switch and openers for the old openers ended in the middle of the ceiling. I tore it all down and re-wired it.
I have run all wires inside conduit just because it looks so darn clean when you are done. Getting the new tube up amidst the existing tubing would take some thought. One day, while staring at my 1/2" tubing a thought passed through my head: "Why not bent a single tube to run the wiring and make it clean -and cheap." I got out my $9.99 Harbor Freight heat gun and started heating PVC. The aim was to job around the well power line without being too unsightly.
Here is what I ended up with...
It worked out great. I bent 1/2" schedule 40 and, using high temp, heated about a foot of it until it started to droop. That was the sign it was soft. Then, on the floor to keep everything flat, I bent what I needed and then hit the soft area with a wet sponge to harden it back up. Then I rolled it with a base coat of paint before installing it. Then, all that was needed was a quick touch up here and there, like on the brackets.
I have some speaker wire to run and I'll use the same method...
I used conduit for all my electrical wiring and air lines in the workshop and it worked great and looks really nice. (NOTE: Don't custom bend PVC air lines. Glue it up with schedule 40 or 80 if you can get it.)
Ray
Ray
