EngineerNate
Hi all,
Starting a fresh thread for this. I brought this home for $250 today. The owner brought it home from work but realized he was in over his head with 3 phase power etc. Time will tell if I did good or flushed two and a half big ones down the toilet. These compressors have been hard to find locally so I took a gamble on this one.
Tank is 120 gallons. Looks good from the outside. Couldn't get any of the inspection ports or bungs off to have a look at the inside.
The good:
Looks to have been used indoors. Very little surface rust.
Pump isn't overly dirty, and has signs of previous service, so hopefully it was reasonably cared for before it was retired and sold on and then resold to me. The oil in it wasn't super great but I've seen worse.
The bad:
1. Something is definitely loose in the bottom end. As it turns over there's a "clunk" once a revolution. I took off the inspection plate and there's nothing broken inside, so I'm hopeful it's fixable.
2. When it was moved, some bozo cut all the unloader copper lines. I'll need to buy/make replacements.
3. The motor on it is a 575v fixed voltage unit. Not usable.
At $250 I was willing to roll the dice. This thread will either become a cautionary tale or a nice rebuild log. Maybe both.
Cheers,
Nathan
The good:
The bad:
Cheers,
Nathan
