rattle_snake
Yes always lots going on in the shop.
Took truck out for first test drive with new trans on Friday. Very different experience than the 3 spd. 3-up gears shift at lower rpm and manutronic button didn't work. Got trans to 178* and cooler circuit should have opened. Hoses or cooler didn't feel hot so not sure if full of air still. Will cause fluid level to drop when it does. Could not read fluid level on remote dipstick. Used a razor to score a cross hatch pattern on the end, now I can read.
Installed shift software on PC, connected to controller and configured some items. Farted around with Shift RPM vs TPS tables. Can program how trans behaves with shift selector positions, shift RPM, firmness, and so on. WOT shift points are set at 5500 RPM, 40% TPS at 3000 RPM. Slick.
Test drove again, manual buttons work as expected in 'M' position. Tried progressively higher throttle application through the gears as learning was taking place. From a stop, moderate throttle will lift front end up and spin the tires. Feels like it hits a limit, probably the limit ******** left side. Didn't go WOT through the gears yet.
Still amazed it is not leaking anything. Don't know what to do will all the cardboard I had saved up. Might even clean up the stains on the shop floor.
