I did that made it worse. sticks up farther as the spring is doing it's job to lift the hood....
I did managed to solve my hood fitment issues. Had to step back and restart one thing at a time.
Removed the latch, because that is the only way to open the hood.
Removed the spring from right hinge. It is still a disaster and deflects badly in multiple places. Won't fold shut completely. The pivots were loose allowing the arms to twist and deflect. So I re-swedged them in the press with some custom dies.
Reinstalled hinge and now it functions properly and the hood will close on that side. Put the spring back on, and it's still OK.
On to the latch. The hood is offset to the left farther than adjustment allows. I loosened the bolts from frame to core support and was able to move the front over 1/4" or so. Now the hood catch would line up with latch. But the catch was bent, so I fixed that.
Hood still gets stuck. I was able to determine that the secondary safety hook was pushed back behind it's opening and jamming. Aghhh... So I pulled the latch off, beat it back into shape and tweaked the safety hook back into position. And with that the hood can be closed and opened.
I could have just spend money on new hinges, waited for them to arrive and added to old to the landfill. but I'm cheap and and impatient.
