Grant Gunderson
A bunch of the parts I ordered for the Generator finally arrived. Everything is a bit delayed up here right now after I5 was closed due to a land slide south of town after all of the rain we got last weekend.
I ordered a new variable resistor. This is for the Exciter but its mounted on the generator unit. Its a Ohmite D25K50E and its rated fr 25W250Ohms. Out of the box it tests for 239Ω
There is a really good thread on PM that a guy named Cal started. It states that the variable resistor should be set to 150Ω. I ended up with 150.7Ω. I'm sure thats good enough.
Here is a shot of the new resistor after I got it fully packaged to be installed.
Before the resistor gets installed the brush unit needs to get put back first. I aligned it to the witness marks I made when I took it all apart.
And here is what it looks like with everything back in place.
Next, I pressed the *** 6304-c-2hrs bearing into the rear end bell. I have chosen to go with fully sealed bearings after dealing with the grease mess this generator was.
I then installed the bearing retainer behind it.
And then I blued all of the machined mating surfaces. I could have painted these, but I was unsure how exacting the tolerances was, so figured blueing them was a safer bet. I then installed the bearing retainer with its two bolt and installed a pipe plug.
Next, I bolted the front legs on and then pressed in a SKF 6205 2RSJEM bearing.
I then temporally installed the bearing caps to position the bearing exactly where it needs to be.
