Grant Gunderson
The RH (forward) spindle clutch gear assembly felt pretty good, but after seeing how bad the rear was, I figured I better have it apart and look at it.
Note, there is a single dot factory witness mark on the back of the gear shaft as well as on the top side of the lock ring. There is also a witness line scribed across both on the ends.
My plywood trick wouldn't work for this gear assembly as the end off the gear is larger in diameter than the mount collar. So I used the same 3-⅞" hole saw and notched some scrap ⅛" thick aluminum angle. It's not pretty but it worked.
This fit into the ring that cut into the mounting ring, that stands proud of the press fit for it. This ring is for the oil passages.
I used the same large drift to press it out in the arbor press.
L to R gear, mounting ring, lock ring
While this assembly felt better than the previous one, it still had some galling on the gear shaft.
The mounting ring side was in way better shape, but note the grove worn in it.
Probably best to see if I can find a replacement for this one as well.
