Fallon
My current Kobalt 5hp (which I doubt is really 5hp) 60 gallon 14cfm @90psi compressor has barely been keeping up with some of my sandblasting. Recently the tank pinholed & I'm looking for a new tank for it. I got the compressor in a trade for a snowblower, so it has been used a fair bit & no idea of it's maintenance history. Even if/when I replace the tank I'm seriously thinking about replacing the compressor & looking for recommendations.
I'm thinking something that will put out high teens of CFM in the 175psi range, probably a real 5hp, maybe 7.5hp should take care of my needs. There are a handful in the big box home & ranch stores around & I'm looking for some recommendations. I hear IR, Quincy & Champion being highly recommended, but also that some of their stuff I'm looking at in the little over $1,000 range probably isn't going to stand up to their reputation on higher end systems.
Ideally I'd like to fine a nice beefy industrial compressor I could rebuild, but I haven't seen anything that doesn't look beat to hell or at a price point I could rebuild and/or re-power it to single phase. Also, given my current tank failing on me has me a little gun shy about dealing with a used tank that may have not been drained often & have rust issues hiding.
Any recommendations? Manufacturers, pump models, etc. I should be looking for? Just quickly re-tank my current one (maybe even with a smaller tank off a oil-less compressor) hold out for an old industrial compressor I can rebuild & maybe replace the tank (eventually) & possibly motor on?
