Don't mouth off about how I should toss it in the garbage. It was a habitat purchase solely for the tank, but I decided to pass it along to a friend. I did repair the obvious ( broken ****** into the tank) , and then it became obvious the cylinder & ring was worn as it would only build about 60PSI
for a few $$$ I bought a ring & cylinder kit .as already mentioned I plan on passing this compressor on to a friend .
I have never installed a new ring on an oiless compressor. It seems quite large for the cylinder and needs to be compressed a bit . I know once the cap is installed on the piston that holds the ring it will push downwards some, making the diameter a bit less. It looks like it will still be a bit to large.
Just wondering if any one has any tricks on compressing the teflon or whatever ring to get it into the cylinder?
