Replacing oiless air compressor ring & cylinder question
The Cobbler
Don't mouth off about how I should toss it in the garbage. It was a habitat purchase solely for the tank, but I decided to pass it along to a friend. I did repair the obvious ( broken ****** into the tank) , and then it became obvious the cylinder & ring was worn as it would only build about 60PSI
for a few $$$ I bought a ring & cylinder kit .as already mentioned I plan on passing this compressor on to a friend .
I have never installed a new ring on an oiless compressor. It seems quite large for the cylinder and needs to be compressed a bit . I know once the cap is installed on the piston that holds the ring it will push downwards some, making the diameter a bit less. It looks like it will still be a bit to large.
Just wondering if any one has any tricks on compressing the teflon or whatever ring to get it into the cylinder?
whateg01
doo dah, kansas, usa
Might help if you post the model. The oilless I've repaired either had a phenolic (guessing at that) ring that was spherical on the outside so the piston could rock in the cylinder or had a metal disc that sealed (mostly) to the cylinder wall. Not sure what yours looks like.
T
The Cobbler
I don't have the model , but here is a related thread. the ring & cylinder is pictured below
the ring is similar to leather ,but it' s some sort of man made material . I don't have pics of the piston etc at this time , but it's a thin pancake type that can rock back & forth in the cylinder
whateg01
Sounds like you don't have it apart yet. My experience is that the valves or head gasket are as likely to be source of that problem. So I would check those out while it's apart. If it was mine, I would bore a conical hole in a piece of nylon to guide the ring into the hole. But that's just me. How much does it need to compress?
T
The Cobbler
it is apart & determined a badly scored cylinder & very worn ring( daylight visible along edges ) . the reed plates look okay . new oring seals included for the reed plate & head so I'm good there too.
not sure on how much it needs to compress, I imagine when I get the ring installed on the piston it will curve down & might not need to be compressed too much .Now that I think about it, I do have a small ring compressor that might come in handy too
Beerhippie
Far NE Oregon
This is why we used to call them "airless" compressors on the jobsite. Running one of those in dusty conditions wears them out in a week or two.
