Residential water pipe?
DeeDubz
Socal
Im just curious what would be a good water pipe to use for residential? I want to replace my old pipe. I was thinking of just running PVC schedule 40. I live in so cal the depth required is a foot. Anyone have recommendations?
MongoTA
CT
I'm guessing since it'll be buried it's an exterior water supply pipe?
I'd recommend HDPE. Black pipe. Comes in rolls of varying lengths. That allows you to have a single run with no unions/joints from the street to the house. Not brittle like PVC and has better fatigue resistance as well.
Consider running a warning tape above the pipe as well in case of future digging.
Sumboodie
AK
The line to my house is 1.25" type K copper.
Had to dig it out after the first winter, the contractor had part of it buried only about 2ft and of course it froze. Supposed to be 10.
That Guy Scott
SoCal
You can use PVC if you want, I did, but I had a unique situation. I’d use black poly/HDPE/PEX. You can check out Ewing https://ewingirrigation.com/products/irrigation/pipe/hdpe-pipe or PUS in Corona https://www.performanceutilitysupplyinc.com/ I’m pretty sure They’ll have what you need. Also, I would go deeper than 1’, use a flagging material in the trench and you’re supposed to also install a tracer wire.
Renegade1LI
long island ny
This is what you should be using, specd by most localities, also uses copper tube size fittings, always make sure it has NSF approval.
D
DeeDubz
Socal
Sorry I should have been more specific, it will be the domestic water supply
Wheelingit
Maryland USA
Schedule 40 PVC is prone to cracking. Don't use it. Copper or pex is good. I always like to use copper since if it is hit with a shovel or something it won't split open.
reader2580
Minneapolis, MN
The water feed from my well to my house is the black poly pipe. I’m pretty sure it was installed in 1980 as it goes under the concrete basement floor.
D
DeeDubz
Socal
I think im going to use black poly pipe. I tried of using PVC. I have a water leak under my concrete that was just poured less than a yr ago. Its the water line to my shop/pool equipment. The water line has been moved 3 times. By me, the pool ppl and the ppl that built my shop. I suppose one of us is to blame for the leak. I suppose its at a fitting. Luckily my wife an I were planning on re piping the water line to the house. When I replace the water line Im going to run a new section to the pool / shop water line and tie in. All in all I think ill have to trench about 150ft. I have a friend thats a plumper. He ll help me tie at the meter and into the house.
firebirdparts
Kingsport, TN
It's pretty indestructible in my limited experience. Grew up on a well, and so we had that like reader2580. I'm on city water now, copper.
kbs2244
there may be a code or water supply co requirment
it would be a good idea to check
Crazyjake8493
Upstate NY
Skip the PVC, I'd use black poly or PEX. Indoors I use all PEX, and black poly for outdoor runs above or below ground. PEX would also be fine underground but not exposed unless it is a UV-resistant PEX.
D
DeeDubz
Socal
Yesterday I filled out a call before you dig ticket online. I was surprised to see the water district show up around 4pm. Unfortunately they dont mark anything after the meter.... But they gave me a lot of info. They suggested using 1 inch black ploy. 12 inches is plenty of depth. They mentioned theres a sewer line going toward my house and to stay away from that. But they advised me it should be deeper than 12inches.
Bretny
Dutchess county NY
Yes call before you dig generaly dosnt mark past where the municipality owns. So they really dont care if you screw up your own utilities..just theres.
