mslisaj
My shop roof has a 14' eve with probably a 20' peak and 80' in length. I certainly don't want to fall off this roof as I would never survive enough to retire. At any rate it's a metal roof with wood perlins and trusses for support. I believe I want to run a static line across the top of the eve that I could clip off too with a harness just in case I slipped up there. Do you gentlemen have any thoughts or advice on this. I want to do something that is permanent and professional. I have surfed the net and got a lot of idea's but I wonder what you guys think or use. I'm sure some may be in this type of business and are used to harnesses and tie offs. The harness I already have but I need something to tie it too that will not only protect me but anyone that I may hire to go up there.
Thank you gentlemen for your thoughts and idea's............
Lisa
At the end of the second page I have a full write up of what I finally ended up doing to solve this problem. Thanks to all the good ideas expressed I believe I came up with a good and safe solution. Additional comments are always welcome.
At the end of the third page is the final write up and the final set of pictures with the cable in place and being used. As usual comments are welcome.....
Lisa
