jonathan75
Fair enough, well keep up the great work sir, it is going to be a beautiful beast of a compressor... Also look and see if you can find a Dayton motor, they are great quality motors (believe they are USA made) and a little less known so you might find a better deal then a balder.
Thanks, I will look for Dayton also.
The leak detector is just soapy fluid of some type. I found online recipes for soapy water and glycerin, a whole bottle of dawn soap in water, etc. I tried soapy water and could not find the leak. I bought this when Ibought the PTFE tape and found some of the leaks. Not sure how I messed up soapy water. I replaced the check valve b/c the tank was still draining but not making bubbles anywhere I could find. The tank now holds pressure after replacing the check valve. I had already soap and retaped every joint.
http://m.homedepot.com/p/Oatey-8-oz-All-Purpose-Leak-Detector-302092/100151681/
Thanks for the link, I may pick up some leak detector if it makes it any easier. Ken at Air-Flo said Saylor Beall does not have the repair kit for my old model of check valve anymore so I will buy a aftermarket one from him. I want to get as much from one supplier as possible. Not only that but Air-Flo has been great with communication and help and offers competitive prices.
