ScepterToad
- Joined
- Nov 9, 2023
- Messages
- 340
I have to say Mike, on the water is probably the most relaxing thing I can do. Something about it just melts everything away. Problem for me is that the coach is ruining my boating habit!Keith, I'm not a water person, but those pictures of being out on the water are amazing, so calm and tranquil appearing.
Out of curiosity, how many miles are on your coach? I just turned over 148k on our trip last week and I have service both my rear end and transmission three times now, even though Allison and Eaton state 75k mile intervals, I'd rather be a little overzealous than not on service intervals. Allison also states a 4-year interval in there but after speaking with a rep. several years ago he led me to believe that the time interval, while still recommended, was more for off-highway or stationary equipment that was running for longer durations and at higher loads.
Looks like you've already completed yours, but I do have a video showing the Allison service as well as the rear diff. service thrown in for good measure. The key points on the Allison are to not over-torque the filter housing bolts. Specs are 38-43 ft/lbs. and anything more can pull the threads in the case which will turn into a bad day. I've had to repair a few from other's misfortune and so I highly recommend sticking to the OEM torque specifications.
As for the oil filter, I prefill mine because they hold nearly a gallon and that is a long time to go with no oil pressure, even though Cummins states not to. I think they recommend against it is solely because of the possibility of introducing contaminants into the oil, but if you're clean and take care in what you are doing, I see no downside. Fuel filters, I do follow their recommendation and do not prefill, because the orifices are so much smaller in the injectors, plus they have a method of cycling the key to prime the system. Now with my FASS fuel pump, filling filters is even more simple.
Our coach has just about 92K on it, and you'd be right to note that the service of the trans and diff are severely behind schedule. From here on, it'll be a much shorter interval. I've actually watched your video several times. Interestingly enough, the Allison filter kit did not come with instructions like I think yours did. I did torque mine on the low end at 38. I felt that it was adequate. Coming out, the bolts were VERY tight.
Interestingly enough, I recently looked up the oil filter prefill on Quickserve for my engine. The service instruction actually says to pre-fill the oil filters. I found that service procedure when responding to a thread over on IRV2. So, in response to this, I figured I'd go back and see what Cummins had to say about it. And, I have to say I'm shocked but not shocked. There's lots of bad information on the internets these days, and I'll try this procedure next time I do fuel filters.
According to Cummins, for a CAPS fuel system (which I don't have), do NOT prefill the fuel filters. For Common Rail (which I have): "It will be necessary to fill the 10-micron water stripping (suction-side) fuel filter with fuel." It goes on to say to not fill the 3-micron primary.
Hopefully that link will work. I think next time, I'll try it out and see what happens. The downside is, if I'm on the side of the road with bad fuel (for whatever reason), and I go to change the filters, it's unlikely I'd be able to get and stay started based on my most recent experience.
EDIT: I read the remainder of the procedure. The lift pump cycle time is 30 full seconds and the ECM needs 10 seconds to reset between priming intervals. And, you're supposed to increase idle speed after starting to purge the air out of the system.
