posaune
I don't know if it'll work or not, but maybe we should get all of the chatter out of the regular hot deals thread before people get their ******* in a bunch.
Below is what I've found. These, afaik, were true at four different Sears stores in CT (Corbin's Corner, Meriden, Enfield, and Buckland Hills). Only Meriden had anything marked. The local Sears hardware (Bristol) had all of these and more on clearance too but the prices were all higher ($1.88 for regular sockets and $4.88 for flex, iirc).
EDIT: tools with an asterisk in front were found by others in various other areas
These are NOT NECESSARILY MARKED. You can check them yourself on the in-store scanners or have them checked at the register, but I've checked samples at various stores and they seem to be at least area-wide.
1/4" dr:
7/32" hex
1/4" hex
5/16" hex
3/8" hex
1/4" flex
5/16" flex is NOT on clearance(?!?)
3/8" flex
7/16" flex
1/2" flex
9/16" flex
possibly some smaller metric flex
13mm flex
14mm flex
3/16" 12pt shallow
9/16" 12pt shallow
**/32" 12pt shallow and deep
(possibly others too)
3/8" dr:
#1 phillips bit socket
7/32" slotted bit socket
9/32" slotted bit socket
3/8" slotted bit socket
3/8" 6pt flex
7/16" 6pt flex
1/2" 6pt flex
9/16" 6pt flex
5/8" 6pt flex
11/16" 6pt flex
3/4" 6pt flex
11mm 6pt flex
12mm 6pt flex
16mm 6pt flex
17mm 6pt flex
18mm 6pt flex
19mm 6pt flex
13/16" swivel spark plug socket
ALL 8pt sockets - CONFIRMED
1/2" dr:
These are from someone else's post. I didn't note all of the bigger sockets that were on clearance - the sizes seemed pretty random.
*10mm 6pt shallow
*12mm 6pt shallow
*14mm 12pt deep
*16mm 12pt deep
3/4" dr:
The exhaustive list of 3/4" drive sockets on clearance ($.97ea):
47771- 7/8
47772- 15/16
47773- 1
47774- 1-1/16
47791- 2-3/16
47792- 2-1/4
47793- 2-3/8
US-made Pro, fully polished flare wrenches
$1.97ea
9x11mm
19x21mm
1/4"x5/16"
Fully polished Chinese flare wrenches
$1.97ea
*9x11
*10x12
*13x14
*1/4"x5/16"
*3/8"x7/16"
1/2x9/16
5/8x11/16
Hope this helps. If you have anything to add, maybe quote this and edit as needed so people can just take the whole list to the store.
1/4" dr:
7/32" hex
1/4" hex
5/16" hex
3/8" hex
1/4" flex
3/8" flex
7/16" flex
1/2" flex
9/16" flex
13mm flex
14mm flex
3/16" 12pt shallow
9/16" 12pt shallow
3/8" dr:
3/8" 6pt flex
7/16" 6pt flex
1/2" 6pt flex
9/16" 6pt flex
5/8" 6pt flex
11/16" 6pt flex
3/4" 6pt flex
11mm 6pt flex
12mm 6pt flex
16mm 6pt flex
17mm 6pt flex
18mm 6pt flex
19mm 6pt flex
1/2" dr:
*10mm 6pt shallow
*12mm 6pt shallow
*14mm 12pt deep
*16mm 12pt deep
3/4" dr:
47771- 7/8
47772- 15/16
47773- 1
47774- 1-1/16
47791- 2-3/16
47792- 2-1/4
47793- 2-3/8
$1.97ea
9x11mm
19x21mm
1/4"x5/16"
$1.97ea
*9x11
*10x12
*13x14
*1/4"x5/16"
*3/8"x7/16"
1/2x9/16
5/8x11/16
