Securing my bench grinder
MarineScott
W. Pennsylvania
I just purchased an 8 inch bench grinder and would like to know if there is a pedestal I could mount it to with out securing the pedestal to the floor.
NeuseRvrRat
Got a welder? My bench bench grinder stand is just two pieces of plate with a piece of pipe between them. It's not bolted down and does fine. I stand on the bottom plate if I really need to get into it.
Dusty-NZ
Canterbury NZ
Yeah , a bit of drive shaft and brake drum etc .... (pic moved over from how to heat a small shed thread) :)
JABgj
So. California
I bolted my grinder to a piece of channel and clamp it in my vise when I need it, store it when I don't.
rharman
SoCal
I took an old brake drum, a piece of 3" square tube, and a couple of pieces of flat stock to make mine. Been working fine for about 40 years.
Jimithing616
Minnesota
I believe Harbor Freight sells one, as does Rockler... the Rockler one (it's a Rikon and likely available elsewhere) if I recall is better, definitely doesn't need securing to the floor as far as I remember but I could be wrong....
Rockler http://http://www.rockler.com/rikon-80-910-universal-grinder-stand
If you go to the HF site they actually sell 2 "bench grinder stand" is what I searched for
Jimithing616
Minnesota
Or, you could always build something out of 2x4's or plywood or both... I'm sure there are some YouTube videos on exactly that...
exmaxima1
Midwest
I have my 8" grinder on the Harbor Freight stand.
https://www.harborfreight.com/universal-bench-grinder-stand-3184.html
Four legs, a tray half way up and it's reasonably stable. Nothing special but for $30 it hardly seems worthwhile to fab one up.
I have a few of those and I like them much better than post stands. Surprisingly stable, and that shelf is a handy feature: if the grinder is too lightweight, you add some mass to the shelf, ie a box of chain.
:thumbup:
crewchief888
NW indiana
unless you have the material (scrap) laying around, and a welder handy, the cheapest alternative would be one of the HF stands.
i have 2 or 3 of them in the garage & basement for various tools.
my grinder stand was made from scrap i already had, a drive sprocket from a compact track loader, some scrap 3/16" plate, and the drive tube from a street sweeper...
it took longer to paint that it did to weld together.
:beer:
psychob0b1977
Dracut, MA
Do you have a link to that thread? I've been searching for that exact topic with not much success...
lilredex
Toronto
Made this one for my 6" Baldor grinder many years ago. It is just a 2" pipe, some angles and scrap pieces of railings that were on hand. The storage area provides some ballast for stability.
joe_pinehill1
Northern Virginia
I bought one at TSC, paid about $50, that is like the one HF now carries. I put locking casters on it to move around easier in my garage. Works fine.
Pitalplace
North Platte, NE
I have found if you throw one of the rubber mats under the stand it will help with vibration and keep it from walking around. I have several mats in front of my benches that I got from Menards.
BDT/NWMN
Erskine, Mn
Old rubber mud flap from a large truck also works good. For some reason, I seem to have a few that never get tossed out.:lol:
Jbullfrog
Avoca, Iowa
My 8" is on the leg from a restaurant table. It has 4 feet with adjusters and I welded a piece of 3/8" plate to the top to match the grinder. Super stable and portable.
