Shop air lines
mikeyr
Santa Barbara, CA
I used copper, only because i was too lazy to make it work with pipe, I don't have a threading machine. It was expensive but a one time expense for the garage I will taken out of feet first by the coroner, not planning on ever selling or moving. Big advantage, I did not plan on is a lot less moisture in my air lines, because copper cools the air pretty quick. I get water in my first drop, very little to no water in drops further down the line.
OCD
Edmonton, Ab. Canada
What kit or product did you use? I like the look of the metal fittings the fastpipe kit looks very plastic like for the fittings, I could be wrong though.
I went with Infinity fittings and pipe... Awesome fittings to work with, and no leaks since install... However, they are not cheap...
warbird1
Just today finished up with the copper airlines in my rented shop. Not a large system; so the expense wasn't bad... besides, I've been working with copper for 40+ years and kind of like working with it.
NakeDiesel
oklahoma
Here's my setup, Eaton 2 stage verticle 80 gallon compressor, dryer unit using black pipe and hydraulic hoses inside compressor room. Black pipe out and branched in 2 directions. One to a set of hose connectors and a filtered/regulated outlet for when I'm painting, I just recently added a 1/2" air hose that goes up and across the ceiling to the opposite wall for 2 more hose outlets and a reel hose outside the shop for air up equipment and vehicles when needed or my outside sand blaster. The other branch goes to 2 outlets and then 3 feeders to my 20' workbench. 2 coiled hoses and a reel hose. I also have drains at each drop point on the end to remove potential liquid that in the lines. Just picked up my cyclone blasting cabinet for the shop yesterday and haven't gotten it hooked up yet.
Steve_P
unbelievable that we're still debating the difference between compressed air and water. Pressure vessels are hydro tested, and not compressed air tested, for a reason: no one gets killed from a PV failure with compressed water. As said, compressed air, like a compressed coil spring, has an incredible amount of potential energy. Water under pressure, like a steel plate under pressure, has ~no potential energy. Physics doesn't know about OSHA; but you should know about physics.
I did my air system with 3/4 and 1/2 copper tube. 3/4 runs down the wall 25' to allow cooling, back 25', then reduces to 1/2" into a water separator, regulator, and hose reel. There are three dead leg drops for water to drop out. I did my system in ~2003 and it cost about $200 for the tubing, ball valves, and fittings. Yes, it was a lot of $ at the time, but I spent $1600 on a compressor. And the copper is a life-long solution and doesn't rust or leak at the joints. I realize there's inflation, but people here have no problem spending that much $ today on a 7 piece Snap On screwdriver set where they'll only use the #2 phillips 99.99% of the time.
rwreuter
Mulvane, Kansas
I had 8 drops in my old shop with wide open lines everywhere and never had a pressure drop issue. I could run a big impact while someone else is running a die grinder with no issues. I don't follow the ASTM stuff cause I'm not a commercial shop.
What size pex were you running? 1/2" or 3/4"?
pmiranda
Austin, TX
FWIW, I already have a mix of 1/2 and 3/4 PEX water plumbing in my shop, so I'm thinking I might as well use it for air as well since I have all the tools already and I can easily drop by 2 or 3 stores open late hours for more fittings. I'm not excited about having to mail order a special system or buy new tools to run something else. I sure as hell don't want to learn to solder copper an inch from spray foam insulation :)
First segment is just 40 feet or so to get from where the compressor is going to a convenient drop in the shop where I'll mount a hose reel.
pmiranda
Austin, TX
I guess the thing I'm fuzzy on is how to get long horizontal runs of PEX to reliably slope to drains. Requires a lot more support than metal pipe, but getting rid of half a dozen fittings seems worth it.
Wrench97
Southeastern Pa
Run it like a rain gutter high on one end lower on the other the air will push the water through.
Also a tee and a drop on the riser with a petcock on the bottom will collect a lot of water.
BlueSteel
Montana
A mixture of Rapid Air and Northern tool(because it is grey). Really happy with it.
BlueSteel
Montana
What's the grey stuff? I ended up with all rapid air materials
Northern Tool sells their own air line kit. It is a copy cat of the Rapid Air. The tubing appears to be identical but the fittings are different. I mixed and matched with no issue. The grey just matched my walls better.
T
thejudges69
youngstown, ohio
Interesting. Is that a new line? I saw nothing in their catalog about it
BlueSteel
Montana
soloz2
Western NY
I had been looking at the less expensive rapid air kit vs the Maxline and Pex alternative. I decided to go with Pex, but haven't gotten around to doing the install just yet. Pex cost is about the same as the cheap Rapidair kit and has the same size ID as the more expensive kits.
acer66
Western North Carolina
Not exited to buy new tools?
Heck, I come up with totally unnecessary and absolutely useless projects all the time so I have to “invest” in new tools. 😉
mike93lx
Richmond, VA
Similar. Just I have 100ft of hose coiled up. It's long enough to get almost to the end of my driveway.
I use a combo of hoses and a lightweight compressor. I bring it to the work, which is really helpful when I need it in the house for trim work
NakeDiesel
oklahoma
When temps get below 40 degrees, I'll switch the 2" closed and open the 2 1" valves to pull air from inside. Will also cover the 2 vents and shut off the vent fan till warmer weather.
It's high of 68 today, tomorrow low 30s high down into teens.
Metallitubby
ATL OTP North
My local Tractor Supply had two of these in-stock. One was an open-box/display model with everything included. They ended up giving me their employee discount and I got it for $100 OTD. Thank you again for the heads up. (y)
