Above 1200 Sq/FT Shorty's Shed
shortykorte
Tallahassee, Fl
I almost spit out my coffee this morning on this one!
Shorty your projects are looking good. Look how close the CL is to the paint booth. That has me kind of scared. If I can slap the hood on the truck and get it inspected I can drive it down to your place and be the first one painted in the booth just don't tell Bob. You would really be helping me out on my ever closer deadline in September.:thumbup:
Bret
Hopefully you had more coffee. :spit: Thanks, I'm trying to keep up with you all. I'm sure you'll meet your deadline without any push from me.
Shorty please NO French maid pics..
Keep up the great work in any case..
Wait, no pictures? Does that mean Andy is going to be stuck here, eating all my groceries?
shortykorte
Tallahassee, Fl
Here's a picture of the finished hat rack. I'm not sure what happen to the shelf. It was straight when I installed it. :mad:
So more of the little things I've been working on. The cafeteria cart turned service cart had casters that were falling apart. Checking the caster cache, I had casters with same bolt spacing. Sweeeeet :thumbup: I also cleaned layers of dust off and put the cart to work. While I had the Sheila Shine out, I cleaned the water fountain. Sure wish the cooler had cold water. One day.
While on caster duty, I brought casters for the horizontal band saw. Everything on wheels. :thumbup:
shortykorte
Tallahassee, Fl
A few months ago, I decided to perform a thorough flushing of the Tahoe coolant system. I drained the radiator and used the heater hoses to back flush everything. I won't share the picture of what came out of the heater core. In the past, I've wrestled with getting the drain plug off with various pliers. I decided to get a SO radiator plug removal tool. SO as in Shorty's O'****. Another trip to the bandsaw and no blood. What am I doing wrong. :headscrat
The Mrs. isn't the most organized person, whereas I try to be. I saw an under-counter rack at Costco so I decided this project would be a good distraction from sanding on the SL. It was a pretty straight forward install and sure does make a difference. The last pic is all the duplicates that were taking up space under the sink.
shortykorte
Tallahassee, Fl
How about one of the insightful safety tips. Tip one, don't use a forstner bit in your cordless drill that is the same diameter as the drill chuck. Boy did it wedge itself into the hole I was drilling. Tip two is always ensure anything on your shaft is tight. When messing with the table saw improvements, the pulley for the blade just slide off. :confused:
A sorta of safety tip is the magnetic in the bag trick that you have on your DP. I tried this and cleaning up the metallic slivers was as easy as removing the magnetic from the bag. No getting stuck trying to clean an unprotected magnetic. :)
Stay tune, there might be a French Maid in the neighborhood.
shortykorte
Tallahassee, Fl
Well I guess Andy has left the building.
Fannie is in tears and keeps mumbling “Mon Andi, fais moi l'amour. S'il vous plaît, mon Andi’”4fc914aab342d5e6e03bc93f5b720299.jpg
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Mmmm, this Dr. Pepper Jerky is good!!
No that is a drink I have missed for a very long time.
OK GOOGLE translate worked well but what happened to the maid ?
Where is Shorty? Nice to see a HAMB calander on the wall.
Bob Heine
Boca Raton, Florida
Stewart, you live in Florida so I assume you have storm shutters. Those usually involve wingnuts and lots of them. Pretty sure Home Depot, Lowe's and every hardware store stocks the wingnut socket, in 1/4" hex drive and all sorts of others. A gas- and time-wasting drive and a lengthy discussion with clerks in all of those stores and you could have had a ready-made solution.
Now you've turned a rare and irreplaceable socket into a special tool, wasting several minutes and missing out on a rage-filled drive. What were you thinking?
Guster
Auckland, New Zealand
And now there's tea all over both monitors! :spit:
News just in: Local police have called in an APB on a half finished truck with OK plates last seen speeding. Driver appeared distressed, covered in soda-pop but not dangerous. Advise to proceed with caution.
oldironfarmer
Terlton, Oklahoma
Well, you ran out of peanuts. What do you expect?
"Fannie, c'est ton Andy, mon amour"
"Où sont tes bas?" :sad:
shortykorte
Tallahassee, Fl
Ok, Fannie has settled down...some. Just the occasional whimper “Andi’”
I’m really happy none of the overspray got on the SL.
shortykorte
Tallahassee, Fl
You didn’t want it to cover up the roller marks or bare spots? [emoji51]
Sent from my iPad using Tapatalk Pro
Roller Marks? Bare Spots? Those are ginuwine custom paint treatment. Kinda like usin’ plastic wrap, lace or water droplets for effect.
shortykorte
Tallahassee, Fl
We need more jerky here. Why don't I ever see you?
Jerky has been restock. I’ll be here all weekend.
You got food? I didn’t even get a beer offered last time I stopped by. I think he’s doesn’t show up thinking you’ll get bored and start working on this projects. LOL. Shorty is sly like that. LOL
No beer when you’re working.
shortykorte
Tallahassee, Fl
Over last couple weeknights and weekends, I’ve been helping a coworker build a birdhouse. He decided he wants to try falconry. He wanted something he could move if he moved, so we came with a modular design. He’ll set 4x4 post with the panels in between. 0f7126a0b16aa2f0a8bdde83bd6f8796.jpg
There’s a total of twelve panels, 8 plain, 2 door and 2 window. For bars, we used 1” pvc pipe spaced 2” apart. 316559a9184158fd37e7ec4503d8c9db.jpg
Bottom 2x was drilled 3/4” deep whereas the top was through drilled. This allows him to change out the bars. A 1x1 wood strip is screwed down over top of bars.
It was amazing how much added weight there was with the window and door panels. This morning, we loaded up my enclosed trailer and took them to his house. I set up this dolly cart with some 2x to keep panel from sliding sideways. Boy did this dolly make it easier. 34c1d5f40e7aafd42b3c9c62f5ee66c9.jpg
shortykorte
Tallahassee, Fl
With the new vacuum, I wanted to have a cart for both the vacuum and dust deputy. Found a piece of old loft flooring the right size so knock this out. 3ee91316a651a9e5ef7b22de2a38e05b.jpg
For casters, looked at my stash and had a bunch of vintage chair casters. 7b5e44a39f36ec59a5a8487320b83180.jpg
The little fastening points were bent in so a little work, like new. 3db0cec83cef3adeb90c3dbe6c2611ed.jpg
The finished product. I need to clamp bucket down because pulling on hose caused it to fall over. 91555ffbf7a9163bac81a11ba9b7cac0.jpg
Here’s how it works. 8171478bce389ce65919592135c7a078.jpg722bf6f0b6149356e2253679e4819e8d.jpg
shortykorte
Tallahassee, Fl
Nice work!
And no blood? Now I'm a bit disappointed.
My apologies, I was saving it for September’s safety lesson. a1b091dd3a4b3490a1846a667915b43d.jpg
Not my thumb thankfully. Today’s lesson is don’t smash your thumb between a sawzall and concrete while removing a 2x2 tubing threshold. Many thanks to Craig (CBacres).
shortykorte
Tallahassee, Fl
Dust deputies are great, I love using mine.
Will you put up a pic of the falcon house when done ?
GB
Definitely helps save the vac filter. I need to do something to keep bucket in place when hose is pulled.
May take awhile for the Mew (birdhouse to me) to be finished. His sister and BIL are supposed to start today. Wish I was a fly on the wall. I will probably be doing the roof so will get pics then.
Top work Shorty..
Trying to learn from one of the best.
Duker
Livingston, TX
Note to self..... wear gloves, hard hat and steel toe boots if I ever work with Shorty!
I like the vac setup, I will need to do something similar in my metal shop as I am already deep in dirt and metal dust from grinding on some projects.
Craptain
Tampa Bay FL
Nice work on the dust deputy. I have one for my blasting cabinet and it really works well. Now I need a cart like that. I have the same problem with the hose pulling it over.
Sent from my SM-G930T using Tapatalk
cbacres
SW Florida
Duker, that's my thumb done in my shop, or I broke in the shed, actually it broke me in.:lol_hitti
It wasn't the sawzall, i smashed it between the square tubing and the concrete, go figuire!
