Wis it made out of decent metal so it will hold up to use?
For adjusting your crack "pipe"?Chrome-plated pot-metal would be my guess. I think it's intended use was hanging on a keychain.
Tom
That is a flash back.
I looked into this a few years ago, checking early Walworth, Ridge, Erie, Nye, and USHCO-Lawson catalogs, and the smallest size they all advertised was 6". What made me curious was the fact that bicycle, auto, and even some early monkey or screw type adjustable wrenches coming in truly tiny sizes. Less than 6" (pic attached). They are all wrenches of similar design with very similar construction in terms of a handle and static jaw and moving jaw. I even have a 3" bicycle wrench (Gormully & Jefferey) that is a working wrench, not an ornament. It made me start thinking about the reasons a pipe wrench would be effective at 6" but apparently ineffective at 4" or 5" and I really couldn't come up with anything convincing. The only thing I can think of is the dynamic jaws in bicycle, auto, and monkey wrenches are much more stable, not as free-floating, and perhaps that created fragility under stress.I've never been able to find one less than 6".
The smallest pipe sizes included in the vintage period (1930s, 40s) pipe wrench charts I reviewed was 1/8" to 1/2". Typically mated with 6" Stillson pattern pipe wrenches. Interestingly, non-Stillson pattern (Ridge, Erie) 6" pattern wrenches were mated only with 3/4" pipe. They were never charted for 1/8" to 1/2". I'm guessing because they were bulkier. The jaws would obviously close on a 1/8" pipe as well as a Stillson. So the question might come down to leverage. The jaws of a conceptual pipe wrench with 4" OAL would certainly close on a 1/8" pipe as well as the jaws of a 6" OAL wrench. Would the 4" handle provide enough leverage to turn it? Was the industry's answer no?I think its more related to what size pipe was available. There were always small nuts and bolts but pipe sizes have been pretty well fixed for ages.
The following may also be true.That seems to bear out our mutual conjecture that the industry reached optimal minimum form factor at 6".
1/8" NPT is still around 3/8" OD, and fittings are move like 5/8", so a much smaller wrench wouldn't serve well. While I've seen plenty of 1/16" pipe with soldered and flared fittings, and I know 1/16" NPT is on the charts, I've never seen 1/16" NPT. Probably because it's only slightly smaller than 1/8" NPT. At these sizes, the wall thickness starts to dominate.Yes pipes just are not that small, at least the garden varieties I have seen.
Most tanks have a little open end wrench, kinda like the ones you get with rotary tools to torque the chuck down. I've never understood why they don't give you a baby pick, for the o rings.For adjusting your crack "pipe"?![]()
Actually, the amount of broken vape parts I see on the curb, it's probably for those.
1/16" NPT is the smallest threaded pipe size I've heard of, but its OD isn't all that much smaller than the far more common 1/8" NPT which isn't that much smaller than 1/4" NPT. Which is why I don't see any call for pipe wrenches under 6".The tiny antique wrenches shown are for nuts/flats, not pipe. Typical pipes are larger so no need for anything < 6"
Nice job on the handle. Good looking wrench.A trip to the local ReStore netted this 8-inch Tiger Tools pipe wrench (actually 7 inches long). The (G/S) in the stamping indicates this was made for Gamble-Skogmo, a chain of auto tool stores. AA lists the brand under Vlchek, who apparently made these in the late 1930s to early 1940s.
The wood handle was originally painted black but the paint was in patchy shape when I got the wrench (for $1). So I sanded it down to bare wood, then finished it with stain and shellac.
