You should make a videoEverybody wants a press, most without a need in sight. So they paint them as display pieces, lowering potential use farther yet!
Starting here, uses will become apparent as you work.
Step 1. Mount to rigid stand, bearing on the pads underneath press, without obstructing the opening. Remember, some parts [like axles] need room below....
Step 2. Keep the slotted plate, and scrounge long rectangular steel one. 1" thick is sufficient, you can weld gussets or drill and tap for jackscrews as reinforcement. Next time you are straightening, this forms bed for V-blocks.
Step 3. Remove the ram, drill and bore or ream a 1/2" central hole about 1.5" deep, cross drill for two 1/4"-20 setscrews. This allows conversion for tooling, especially holders for smaller pin punches. Turn a mushroom for normal use, protecting the newly bored hole. Use flat point setscrews or mill small flats; cup points distort diameter, making removal a problem.
Step 4. With 2 pieces of rod stock, 1/4" to 3/8" diameter [depending on gear rack size] set them in two teeth, two or three teeth apart, measuring distance outside to outside. Deduct 1 pin diameter, this calculates distance between centers selected. Build a block holding those pins that clamps to ram, adding a fine thread screw to land on head of the frame. This will adjust accurately, stopping travel repeatedly; long as the screw protrudes, extending about distance of two teeth.
Step 5. Extra Credit.....I use a simple pointer on a magnet stuck to ram, and a 6" scale also on a magnet, but on the frame. This helps indicate depths, where there is no land or blind hole to indicate same. Also handy when straightening, when known travel attains desired deflection.
Don't paint stuff until you are satisfied with completion.
I don't and won't do videos or plead for subscriptions. I rarely add CAD drawings, pix, sketches, or drafted drawings. As mentor, and mentee alike, my belief says there is little benefit steering someone into MY concept, compared to pointing them in a possible direction, nearly forcing their own visualization take charge.
Apt descriptions have generated patents and monumental construction for hundreds of years...
Dake still sells parts. I am restoring the same press and ordered missing parts from them. They have detailed drawings and Free manuals too.I picked up an old Dake Model 1-1/2 Ratchet Lever Arbor press (including a stand) at a good low price a couple days ago. It's 3ton capacity and weighs around 150lb.
However, it's seized up pretty solid, the handle is broken off, and is missing pawl, pawl pin & rest pin. Guess I'll try some PB Blaster (or similar) to try to loosen things up. Any other suggestions? Wasn't really looking for another project right now, but it seemed to be begging for a good home.
Just ran across an identical arbor press, but with the name Manley instead of Acco. I wonder how many other brands this one was sold under.Didn't see another Acco in the bunch, so here's mine. I had never seen one before, and now I've seen pics of 3 of them in the past couple weeks. I haven't gotten it mounted yet. I was going to put it on the side of my hydraulic press, but it's so heavy that with only a little load, it will want to tip the hydraulic press over, so I will have to build a leg or an outrigger for it.
I also have a couple of Greenerds but those are far more common, so no pics taken. In fact this pic isn't even mine; it was from the ad when I bought it!
Dave
My recommendation is drill and bore or ream a good hole, drill and tap through one side for a set screw. Then what ever tooling you make fits a standard stem. An angled cut on that should push the tool, seating on face of the ram. Hole could be a decent depth, when not being used, a 'mushroom', blocks it and preserves the hole. That same idea applies to self-made items, they'd better have a solid seat that ISN'T bottom of the hole. All my presses (soap opera for mechanics) are modified in the same manner. I use end mill shanks as sizes, in some mysterious proportion with dimensions of the ram.Question for folks on nomenclature: what are the correct names for the fixtures people mount on the end of the ram? I see lots of press names for the Etsy / leather working crowd, but I am looking for ways to mount a pin on the end of my vintage Dake one ton press for driving pins out of broken tools, etc. I have a jacobs chuck that I’ve attached with a magnet, and used a dull drill for the pin, unspiraled end down. (as seen online). Broke the magnet today trying to press a breaker bar pivot out.
As mine is a very short throat, I would prefer to use something shorter than a regular Starrett punch held in a drill chuck. I am looking for the correct names so I can see what other people are doing, here and elsewhere. I don’t have the tools to carefully drill a hole in the end of my ram, so looking for clever ways to attach things, and strong pins to drive things out.
Thanks for any ideas of phrases to search for.
I wasn't familiar with 7 Rivers Surplus, noted in their web ad "The Man Store", includes a photo; with only trucks in the parking lot. Not to say the fairer of our species don't wheel around in them; the picture is devoid of EV's, hybrids, and various douch-mobiles too small to carry fun home.
Sure beats the $85 I paid directly to Dake for my replacement plate and a few other parts.
Can't beat an arbor press for things that require feel. I have a couple of arbor presses and a couple hydraulic presses and they all get used. Well one hydraulic needs rebuilt right now so it's not getting used.I love having an arbor press, but I've never used it, I always go to the hydraulic press. Always looking for another arbor press, they're just cool, but it's of no use to me, but I still need (want) to get another one.
I'd warrant if you used it and got the feel, it would see use. If for no other reason than sense and appreciate what a proper bearing fit is. Everything about bearing longevity starts with size and roundness of that hole.I love having an arbor press, but I've never used it, I always go to the hydraulic press. Always looking for another arbor press, they're just cool, but it's of no use to me, but I still need (want) to get another one.
I'm going to make an effort to use it, just haven't had much press work. Hyd press sees more time straightening stuff, lol.I'd warrant if you used it and got the feel, it would see use. If for no other reason than sense and appreciate what a proper bearing fit is. Everything about bearing longevity starts with size and roundness of that hole.
Because they can be manipulated comparatively quick, it's not uncommon to start parts in an arbor press, and seat them in a hydraulic.
Not an arbor press?
No idea what that's supposed to mean. I use my lathe and mill to make tooling for my arbor press, but I do a lot of stuff that has nothing to do with machine tools at all. I straighten material. I press assemblies together. Maybe you're a troll....
There goes market price; ^. Can't envision many uses without access to a lathe and/ or mill.
YMMV
Some people are a little high and mighty around here. The type who never make mistakes, never eat at McDonald's, never do stuff the way others do it. Overall it's pretty laid back though. If you really want to get beat up, go post something at practical machinist about a harbor freight bandsaw!thanks whateg01 , i was typing same time you were but expressing same point . this is just my 3rd post here and feeling a little unwelcome lol
That’s sweetRoyersford foundry & machine co. made in Royersford , Penn. USA press #3 / 3 ton / dia. of work 15 1/4" / cap. over table 12 3/4 / ram 1 1/2" sq. / leverage ratio 50 : 1 / 220 pounds........ i found these specs. in a catalog dated 1949
Craigslist find a couple months ago @ $250 , i thought it was a reasonable price considering very good original condition .
i've searched and only found only a couple of these , then searched more to find out the company is still in buisness in Penn.
