Show us your welding projects
Muggzy
Orange Co., NY
Re: Show us your welding projects/ need advice on holding
I've been working on a stand for my bench grinder. I am modeling mine after one I saw on "Docs shop projects". It's a fabricated stand that will look like it could be a factory cast stand. The main fab is done, the base is made using tubing, quartered, to form the rounded edge. I will add a couple of layers of bondo to blend the welded corners and smooth the rest. I will also make a bracket for a water cup.
You might try a flat bar along one side and use binder clips to hold them while you tack the open side. How well that works will depend on the type of welder you use and how lightly you can approach the tack.
Really curious what that's for
I could use some advice on holding these number stamps for welding purposes.
I'm wondering if I should deal with each one individually or try and clamp all of them at once with a flat bar and clamp or something ? Thanks
Sent from my KFOT using Tapatalk
Hephaestus29
Indianapolis
I'm wanting to build a cradle for my DoAll 16-2 vertical band saw. The machine weight is 1400 lbs and has a footprint of approx. 3'x3'
Any ideas of the thickness of angle I might want to use for the framework ? I'm also going
to want it fairly low to the floor so I figure on welding on angle to the sides for the castors.
Dugan
New Castle, DE
If you welded the angle at 45* at the corners then ground it flat and welded a cap plate at the corners then put your casters under it 1/8th" would suffice
Hephaestus29
Indianapolis
Using scrap or unused stuff laying around the shop to make this table top press
for my dads canjo manufacturing. It's for the number stamp jig I made up so he can press all the numbers in at once instead of hammering each one in by hand.
toelesswelder
Custom intake i built for a friends 2012 ram
Sent from my SM-G925W8 using Tapatalk
Muggzy
Orange Co., NY
Looks great. Be sure to post more picks as you finish it.
Sent from my SM-G920V using Tapatalk
bmxdad
Puyallup, WA
Canjo .... as in a banjo made from a can?
GTA Matt
Zebulon, NC
Decided to build some longer ramps for my trailer. The originals were pretty short and had gotten bent up over the years. I don't have any pictures of them completed, but I spray bombed them in crinkle coat black. I plan on adding traction tape to them, but all the local stuff was crazy expensive so I'm going to search around for a deal.
GTA Matt
Zebulon, NC
It cuts great. Virtually no cleanup after and very fast, even on the heavy angle iron. I have a specific metal blade for it but I haven't put it on yet. I did try cutting some 3/4" 4130 tube and it didn't like that at all however.
IRQVET
Forgotten Coast (FL)
Mini bike build for my daughter
duanesz
S.E. Michigan
Frame extended engine plate moved over to work with new new engine. Work in floor and steering shaft next.
Brunow
Belgium
Custom fuel tank for my triumph spitfire IV :3gears:
pepi
Woodstock, GA
Built some parts for a new machine I just received for the garage.
To be continued
jimdevlinjr
Few projects I've done
Tire cheetah for seating beads
Landing gear for my trailer. So much better than a single wheel
Miniature Bilco door for crawl access
Swing set for my girls
Upgraded moms clothes line poles to steel
BD1
north side
Material support tables for my Ellis 1600. Used a recycled refrigerator tray for a sliding drawer.
jimdevlinjr
Alpinewhite believe me I considered that, check out the other pic you will see a string tied to the pressure relief. I pressure tested it remotely then blew off the pressure before going back to it.
pepi
Woodstock, GA
Some more parts for the machine stand, fits like a clove. Need to do the corners of the upper edges. Add caters and levelers, paint to match then crown the stand.
zmotorsports
Northern Utah
Nice job. What size mill did you get? Brand? Looks like colors of Precision Mathews.
Mike.
ryolse
Colorado
Here's a couple of my novelty projects. First up was a bench after having a large collection of trashed snowboards from a Ski shop I use to work at.
Next is the result of making room from having a spare seat and EMT laying around.
devoalan
Best advice I ever was given came from my old instructor. Use gas with fc, I think pure co2 was the ticket. Welds come out perfect. spatter free, wets real good, and flux just falls off. makes a cheap wire feeder work like a miller. for about 100 bucks you can get setup at the chinese place just to try it, then spend bigger money for real gear. it makes a huge difference.
devoalan
smart with the string trick. SO you have a bit of self preservation in you, and that's a good thing. If you ever do this again, to maintain the integrity of the cylinder, go in the head. mathematically much stronger area, and the shell will not be compromised. If I could remember the formula I would share it, but alas retirement is kicking in. does it work?
ryolse
Colorado
Only my second post, but this thread caught my eye. Absolute armature welder. This is a smoker I built, and my brewing stand.
Looks great, my co-worker has had a really great setup the last few years that we even brewed my wedding beer with. He and a few friends have an amazing operation going that cooks up 20 gallon batch in 6 hours. They've recently automated it with the Building Automation controls we sell/install that has taken it to a whole new level. Only thing they haven't figured out is fast painless cleaning.
alpinewhite
Orange County, California, USA
There's a reason these tanks are machine-welded. Too much at stake to rely on humans. Would you buy a tank that was human-welded knowing that your safety is at stake? Food for thought. I'm just concerned about your safety. It's one thing for a weld to fail on a machine stand. It's another thing if it blows up on your face when it has 100psi in it.
jimdevlinjr
I'll have to find the pics of the bumper I built for my jeep. I had a 10,000 lb winch on it and a friend wanted to straighten the frame on his totaled f150. I reluctantly agreed because I didn't trust my welds. Friend of mine who used to build Forrest fire trucks was there and I expressed my concern to him. He said "I've seen your welds you have nothing to worry about" hmm well that's one of us. We chained the jeep to a tree and the truck to another tree. The winch was doubled and had restraints on it if the cable broke. The tension bottomed out the front suspension on my jeep that was lifted 5 inches, and the power steering pump was whining. So if my math is right we had 20,000 lbs of pulling power at our disposal. The winch was definitely over 80 percent capacity you could hear it. Shocking the steel with a sledge that frame moved back out and was within a 1/16th in from spec when finished. That was the day I started trusting my welds. I would never let anybody else use the fake cheetah, I'm the one who built it and if it fails I'll be the one it does it to. It was a case of I'm poor and I needed tractor tires seated. Built it out of stuff I had and it cost me nothing.
jimdevlinjr
Yes it works quite well actually, and I was originally going to come out of the head but the ones they sell online they come out of the shell so I didn't try to reinvent the wheel.
jimdevlinjr
I don't think I could refrain from sticking a potato in that:p123
That is one of a few things I can think of that I won't use, because I cover my ears with both hands.
Thought of it then didn't want to be responsible for the damaged window LOL
MarkG
Elgin, IL
Looks good Jim. I'm curious though as to why a lot of guys here seems to build such simple structures using members that would support a whole car?
I think it falls into the same line of reasoning as the quote 'you can never be too rich!' :D
Seriously, I think for me anyway, it has to do with the look and depending on the project, maybe it's what you have available, mostly though, I'd say it's the looks of a heavy-duty project. Obviously, mass production of a commercial product is different!
