Show us your welding projects
wagzilla
Arizona
Lols. Is there a specific car build place in here ? I have a bit of info in my shed thread. Point me in the direction of where better to put info ? :D
It really isn't very exciting. It's incredibly slow build but it's fun.
Sent from my HTC_0P6B using Tapatalk
I like slow builds
James
aka Larry
Eastern, NC
Don't see what I couldn't. I have migged plenty of car panel sheets and they are .9mm
So you welded a .9mm panel with a continuous weld bead? How long was this bead 1mm?
Pulsing to produce a look such as tig is demonstrably weaker. It is pure and simple poor form.
Who said I did it to make it look like TIG? I did it to get the job done, and as you can see by heat signature in my pics, I have good penetration.
I've welded roll cages, and of course I didn't pulse the trigger when welding 0.120" wall DOM tubing. I think I know when the pulse technique can be used and when it can't.
jinjaninja
Sure thing mate. Not interested in a **** measuring. Internet high5 for being awesome.
Fixed
Ontario, Canada
Had some steel around, my dad asked me to build him a weight tree to try to keep stuff organized. c49ea8dc25ad67d883bc1ed5cbbe12f6.jpg
Robert Haas
This one took almost 2 weeks. I sure like how it came out.
build thread
jimgood
Marshall, VA
Fantistic job, Robert!
4 FN 27
Minnesnowta
Made a Firewood Storage Rack for my buddies Cabin. He wanted a top that we can lay our wet gloves on to dry out after snowmobiling.
Just need to paint it.
emtmark
831e044a22170cda935f63229bcdb1b4.jpgbeb66a7fdbf03fb832229e017e1d9fe7.jpg9fd68006458fc114db82eb9032ae444e.jpg90fc746c44a21fdc423f52b5d0e667c1.jpg1cb7ae0133869abf983b7f5a7d1fca6e.jpg
Trying to make a Dutch oven cooking stand / campfire griddle :) first ever welding project. Good friend with lots of time in the trade over saw my puddle pushing. :)
It's not my project til I'm bleeding! Lol
4 FN 27
Minnesnowta
While on a roll playing in the shop I finally got to a project I have been meaning to do for 8 years. I always wanted to add a Receiver Hitch to my Box Blade so I do not have to drop the Box Blade to move a trailer...Lasered these parts out months ago for another project (extra set) and made them work for this deal. I little sawing, machining and welding and DONE!
matt_i
Here's a branding iron I made per a customer's request before Christmas, given to a relative who gives him freezer beef every year. Not sure if it was supposed to be used or a display piece, bottom is 304SS just in case :) I had never made one before, the versions I saw online had the corners & intersections relieved (gapped), somehow I think the concentrated heat there if they are connected leads to some problems.
kkroger
Don't have any REALLY good pics hosted just yet, but working on a "Kite" section 28' Beam with 5/8 thick flatbar on all 4 sides the formers are 3/8 plate. fully welded, ground and so forth it is a custom vertical member for 3 floors going in a house.
kkroger
KKroger,
Would like to see pics of that installed.
Absolutely! Me Too! LOL!
Still have to make and weld on the Baseplate and plates to bolt the floor structures in. And of course finish welding it out without turning it into a banana...
royce
fairbanks ak
I too would like to see the application for this fine fabrication.
Best of luck keeping it straight through the weld out.
Royce
bmxdad
Puyallup, WA
Ok, I give ...what is a KITE section?
toolferone
Raleigh, NC
Almost done with my 3rd welding project. A dual grinder stand that will mount in a rim I have. 3/8" plate base, 2" sq 1/4" wall post, & 3" 3/16" angle top. Have a Jet 8" 1hp going on one side and a old Dunlap 6" on the other.
toolferone
Raleigh, NC
Hey Toolferone: From the height of that stand you must be about 8' tall. :dunno:
So the rim I'm using is aluminum (was free). I was a bit worried about it being heavy enough. So I am putting the stand in the back side of the rim. If I need more weight I can fill the rim with what ever I need. So the height should be ok. Thanks for asking.
Robert Haas
Built two mounts for a grinder and a buffer. I use a 2" receiver on my benches for the vice mounts and other accessories. so it is simple to just build mounts like these;
the Second and third are already painted it is for a small Craftsman bench grinder. It is already painted.
The second will be the mount for the Buffer.
Yarz
Tarentum PA
I was planning to do a receiver mount on my bench too, and I found Harbor Freight has these step bumper receiver mounts:
It may cut down on time to fab them if the premade ones would do what you'd like.
I bought one, but haven't gotten around to installing it yet.
Griff93
Huntsville, AL
Made a materials rack to hold my supply of metal. First we made three of these laid out on the table.
We ran some tubes between the earlier assemblies to create a stand alone tube rack.
Finally got around to making a removable tire carrier for my car trailer. I figured that spare wasn't much good laying on the side of the house. It's built to slide into a standard hitch reciever....easy money.
BD1
north side
'' I love the minion on the wall ''
Here's a horseshoe ones I made ,
V-10 Killer
Midland, MI
I put this together to move some stonecrete. Bought the bucket but needed to fab up a mount for my quad. Needed to backfill under the deck where soil was eroding away. It was a fun project, way better than wheel barreling 4 yards of stone uphill lol.
Muggzy
Orange Co., NY
Nice! Don't suppose you have some build pics from as you went along do you? Where'd you get the bucket?
Sent from my SM-G920V using Tapatalk
V-10 Killer
Midland, MI
Its a Swisher ATV loader bucket. I know Tractor Supply sells them, but i got mine used (but never used). I just didn't like the universal mount kit they sell for them. I don't have any mid-build pics, sorry. This one engages the plow mount, the front rack, and I remove the front bumper to use its mounting bolts too. I got an old leaf spring from the junkyard and mounted it so i can spread the load out directly to the end of the A-arms. That way the springs/shocks don't bottom out.
Wanna Ride
You can also buy the version of that from HF, that is just the receiver tube, minus the step plate. Last one i bought was about ten bucks.
