Show us your welding projects
BlueSteel
Montana
A little modification to my exsisting turbo kit. Better flex bellows and v band. Modified my downpipe and also built a new coolant overflow tank. Cap kit was from Summit Racing!
zmotorsports
Northern Utah
Thank you sir. I was literally just going through your thread, really enjoy your lathe work! Makes me want one!
For doing much of any fabrication I think a lathe is a good piece of equipment to have in the shop. Even for small repair jobs it comes in quite handy. It's amazing how many little jobs end up being tweaked or approached in a different manner with a lathe and mill, however, they are a considerable investment and not to be approached lightly. Tooling will easily run more than the lathe or mill themselves.
InDaRed2
MO
Fixed a broken mower deck on my walk behind and fixed a crack in my boat recently.
Mower deck had a bolt fall out we didnt realize which lead to the upper mounting bar breaking. I ended up welding it to the lower deck support, not sure why it wasnt from the factory.
The boat has cracked 2 previous welds so i really beefed it up this go around. If it breaks again its getting plated like ive seen others done with a crack in this same spot.
zmotorsports
Northern Utah
Nice job on both the mower deck and the aluminum boat.
MP&C
Leonardtown, MD
Had a job come in to replace the casters/wheels on a smoker with stationary legs to eliminate the need for tie down straps. The smoker is going to be a permanent fixture in the trailer, so casters no longer needed. 2x2 tubing, 1/8 wall and 3/16 flat sheet was used..
The rear brackets each have two bolts going through a structural member under the floor. All others used fender washers underneath the 1/4" steel diamond plate floor.
Spare parts
zmotorsports
Northern Utah
Spare parts
Those are some nice looking TIG welds and feet Robert. Great job as usual.
chickenfarmer
I have one customer that is particularly good at destroying things, I spent the last couple days fixing their latest goof up
img_20211004_104814-jpg.1529911
IMG_20211005_184729.jpgIMG_20211006_103651.jpgIMG_20211007_122352.jpgIMG_20211007_122431.jpg
JackOfDiamonds
Idaho (USA)
Still not welding, but I made stroller wheels for my Burley bike trailer. And a drawbar for my cargo bike to pull it with.
jwith68
EC Missouri
Crikey!! Has that machine spent a lot of its life working in rock? Because if it's mostly doing dirt work as shown, that's some next-level f'up-ability. Of course, it may have 6-figure hours on it, too.
f150skidoo
Ontario, Canada
Neighbour asked if I could make removable extension wings for his 60" John Deere snowplow blade. The wings are 8" wide and have a 30 degree forward angle to help hold the snow, the wings were bump bent from 3/16" mild steel.
Bigblue&Goldie
Those are miniature! What are those going on? Still working on the tapered bottom bracket mounts?
I just picked up a Micro sized BMX for my youngest and it came with 100mm cranks. Now that we're in BMX it seems cranks are the "factory Dad" component, with the ******** guys buying them for their kids in 5mm increments as they grow! Granted, these kids have $2k bikes, so it's all relative!
slowtwitch73
Hellgate
Brazing... not technically welding, but close enough.
Is the miniature bike just for kicks or?
Paul Brodie on youtube has a few vids on making center pulls, levers, etc.
BukitCase
Oregon
Those do look really nice; my previous model PM45 really struggles with 1" steel, 4"/minute means I have to set a 1/16" increment ruler next to the torch and move it 1/16" per second. Gets old MUCH quicker than the steel gets cut :rolleyes:
The XP versions really are a plus... Steve
f150skidoo
Ontario, Canada
The XP does have a bit more power then the previous PM45 but it still cuts really slow on 1". Those parts were cut at 3.5 IPM, I've previously cut as fast as 7 IPM but wasn't crazy about the cut quality.
BukitCase
Oregon
Yeah; I just zoomed in on the first pic, noticed the slight but EVEN "droop" on bottom cut lines (as in, perfect cut speed :=)
Now tell me you did those FREEHAND, so I can feel EVEN MORE INADEQUATE :unsure::unsure::unsure:... Steve
Mc8541ss
cpttuna
napoleon ohio
My 4'X5' stainless utility trailer . It has a 2000 pound axle, 10 ply 15" tires, 18" sides, and also has a hand crank winch. The tailgate is hooked by means of a piano hinge. with cover on, it weighs in at about 500 pounds. It took about 6 months gathering all the pieces of scrap stainless to build it. All the stainless was bought at scrap prices.
