Show us your welding projects
GreenIron
A bit north of the GOA
Mc8541ss, this is nice.
6ca24d96-f325-4a7d-b91f-e0fec2125a2a-jpeg.1537147
wrenchguy
NW Indiana
Anyone know what's going on with this piece I fabricated about 4 years ago? It's 18 ga.304 stainless tig welded with .045 s/s wire filler added. Then excess bead removed and burnished then buffed. It only happens on the curve of the part. It's a boat part with the boat remaining in the water the all season long. It seems rusting inside the hair line cracks and starting to pit on the inside and outside of the part. Rust removed on 1 side of the part. Why the cracking? Thanks for any help.
Again, only in the curve area. No cracking within 6" of the end. This photo was taken when first installed.
txvwnut
Bedford, Texas
While clearancing guide bosses for dual springs one of the bosses broke off. I believe this was due to some ham fisted “machinist” putting guides in these heads years ago. When I cleaned the area up you could tell it had been cracked for some time as the it was rather dark in the break.
PugetDude
Superstition Mountains, AZ
Contaminated grinding wheel?
welder4956
Birmingham, AL USA
Looks like stress corrosion cracking to me. 321 or 347 would have been a better choice than 304 for marine service.
Honch
Danville, IN
One possibility:
SSC (Stress Corrosion Cracking)
old_smokey
Manitoba
Salvaged some scrap bed rails and a bunch of steel I found at the local landfill (???), supplemented with some square tubing and I made these two items for my shop. Did it all TIG to get some practice in. I bought a Primeweld 225 ten months ago and have been sneaking jobs in here and there. I'm starting to get the feel of it now, but have much to learn still.
y'sguy
Tulsa, Oklahoma
Just looking in here to learn about the issue on the stainless bow guard or whatever it's called.
I'm a beginner welder and am curious about it.
Could it be that impurities were introduced during welding materials or even when polishing, seems to me? Also wanted to add that it's not the first time I've seen stainless rust or corrode, especially under those conditions. I would even ask if introducing heat in the process of welding possibly changes the chemistry of that particular material. Just wondering, I'm way past my knowledge base! Hope you get the right answer and can share with us.
FTG-05
TN
I made a Burke Bar last week; ever since seeing Scott at YT Essential Craftsman build one years ago, I finally decided I "needed" one.
Start with a 12" long +/- 5/8" thick truck leaf spring, heat it and forge it into the correct shape and angle - both of which I had to guess since Scott didn't give any dimensions. Shouldn't matter since it's just a glorified pry bar.
Once forged to shape and angle and normalized it (i.e. left it in the coal fire, heated to dull red, then shut the air off), cut the "nail puller", which I screwed up, oh well. :( Clean and polish the pry end with a 120 grit flap wheel, get all the forging marks out. Find a 52" length of 1x2x.120" tubing and cut to length. Cut out a slot on one end for the head, about 4" or so in length. Fit the pry end to the bar for a close-ish fitting. Pre-heat the pry end to 450-500 degrees, fit it to the handle and weld up. Add 1x1/8" flat bar to the handle for strength.
Weld it up, then clean up all the dang $#%^#$#@@!!! splatter that was left from the welding job.
Now, go figure out what I'm gonna pry with this thing!
Thanks for looking!
IRQVET
Forgotten Coast (FL)
Can’t remember if I ever shared a pic of my 49 Willys when I was cutting out rusted panels and welding in new sheet metal. Any bondo I found was painstakingly removed, and new sheet metal was welded into place. Bubba at some point made the entire cab corner in Bondo! So I did my best to fabricate the corner out of solid sheet metal. It was tricky as I am not a professional fabricator.
ekuhn
Winter's coming. Bought two Meyers plow setups for $150 (only needed one) and a Titan Attachments 3/8" SSQA Plate. This will mount to the front of my tractor. I'm still quasi new under the hood, but been trying every chance I get. Sometimes I get impatient and rush, but welding has taught met to slow down.
Lincoln 210MP with .030 wire. I need to order some .035 wire, just haven't gotten to it yet. I need to move the chain to the flat stock over the pin for the swivel of the plow and build some shoes for my mostly gravel / some asphalt driveway.
Let me know how I did.
DeeDubz
Socal
I made this a little over a week or two ago. I got tired of storing my angle grinders in a tool box. The drawer was on the small size for all the grinders. It made it difficult at times to open and close. I found inspiration on Pinterest. I have plenty of scrapmetal laying around.
stinkity stoink
New Jersey
The door is great. I’m just curious if you will insulate it somehow ? I have to build one for my house and the last one I did was wood with insulation sandwiched in between. Steel is mor fun .. lol
ed_
Maine
Thanks! And I'm not going to insulate it just because we have spray foam insulation so the crawl spaces are at the same temp as the interior. I did add some weatherstripping on the gaps to prevent any drafts from passing through but I don't anticipate heat being an issue
DeeDubz
Socal
Making an arrow to replace one on a exit sign.
Don-F
Oregon
I have been working on a car trailer project off and on for the past few weeks. The steel was from a contractor that used to build NFL stadium VIP boxes. The virus put them out of business and I was able to pick up some 2x4 3/16 wall tube for a fair price. Its hot dipped galvanized. I learned to grind then grind some more to get the zinc off for welding. Every once in a while I find a pocket of crud and it makes a mess. Not sure if I would buy the stuff again but I am getting close to the end. I have been wanting to build an open trailer for a long time. I finally got around to it. https://www.garagejournal.com/forum/threads/lightweight-car-trailers.264215/
PugetDude
Great project! Be careful with that tubing, burning zinc will give you a helluva headache if you aren’t careful.
Don-F
Oregon
Grinding off the zinc makes a big difference in fumes and the quality of the weld. I can always tell when I didn't grind enough, the weld turns to crud and massive amounts of smoke.
