Show us your welding projects
sqznby
Coastal NC
I have no real reason to think this, but with only using the two legs, it looks sketchy. The same for the pic with just the two straps on the rear.
Maybe he's just showing how balanced it is. If everything lines up perfectly (which it looks like it does), he could swing a leg out of the way to get access and swing it back to secure it while working on it.
On a side note, now welding today just tapping and cleaning some 3/8 316 SS, fun fun fun haha.
Old Man Roger
Palm Coast Florida
Ya it might be perfect solid, it just looks sketchy.lol
Beerhippie
Far NE Oregon
Tapping 316... I still have scars from cutting myself on the broken end of the tap when it sheared off. I've learned to just weld on a fitting that's already tapped--especially pipe taper threads.
My booger-weld of the day:
Motor mount for my treadmill-motor variable-speed drill press project.
Beerhippie
Far NE Oregon
What it's for:
customh
East Bethel, MN
Look close boys, he's got the lift pads bolted to the arms where he's only using 2.
sqznby
Coastal NC
Unfortunately, these are mounts that will be polished to a mirror finish.
Please please pleeeeease don't be offended or mad at me for saying this but, GOOD DAWG dude those welds look awful.
I do want to see the end result of your drill press, looks like it's going to nice.
Notch1988
Fort Saskatchewan, AB, Canada
As stated, with it bolted it's very stable. It will pick fine without the bolts, in fact, I tend to pick it up to working height so I don't have to bend over to tighten the bolts. The machinist at work made me donuts out of solid bar stock that are welded to the underside, machined for the bolt diameter and the OD is the same as my lift adapters. These would essentially have to roll out of the lift arms for this to tip over and that's not happening. I have used pipe stands under the non-supported corner which keeps the access I want and relieves any strain on the hoist arm if I'm doing work that may cause it.
Copymutt
Colorado
Never seem to have a C clamp that fits the project, so here’s my first go. Expect to make several more, deeper throats, small w/ pointed contact, right angle, etc.
Version 2.1
Quick adjust. Tang on back side can be tapped to gain close sliding tolerance.
Copymutt
Colorado
IMG_4281.jpegIMG_4279.jpegIMG_3074.jpegIMG_3075.jpegTime for a set of plank clamps. Table tops, furniture glue ups.
TS discarded several clothing racks w/ button lock adjustable arms.
Perfect for clamping wide glue ups. Very little welding ended up w/ nice looking 21” to 48” clamps. Salvaged extension ladder feet for the clamp face.
WillyBoy
Genesee valley area of New York state
Way back on page 55, of this thread, Pco6 posted some pictures of his Lincoln 225 stick welder and the mobile base he fabricated.
I really liked how it looked and decided that something similar would be a good winter project.
Here's how it turned out.
I used 1-1/2 inch square tube. Storage box on the back and a tray on top on coupling nut standoffs.
I like the idea of receptacles on the leads and added a couple of pieces of PVC pipe to stick them into.
The hooks for the leads are a hardware store item.
The lower edges of the cabinet had a fair amount of surface rust, so this was also an opportunity to disassemble the cabinet to clean up and repaint.
Jswain
Calgary, AB
That looks sharp, nice job!
y'sguy
Tulsa, Oklahoma
Great work! I use the same welder. I may have to steal your/and their ideas for mine. Shoot, I hardly weld anything anymore but still, it's nice to have a machine set up to go like this when the time comes.
Good solution to the way the leads detach too. I'll be googiing those soon.
Fixr
SW VA
I have had a need for a firewood rack for a while and today was the day. Was able to knock it out in about 6 hours which pretty good for me. Getting accurate miters with an abrasive chop saw is a pain.
Pics don't count until it's in place and loaded. We will critique the size and uniformity of your splits.
jcarapet
Texas
But then I have to paint it, and I don't love paint prep.
Curious about the design. Are the corners of the triangles going to be a waste of space ?
Likely unless you throw some twigs on top. Normally form follows function, but in this instance the aesthetic is more important than 100% space utilization. At least to me.
BukitCase
Oregon
If by "table" you mean WELDING table, no way - I'd sooner hang all my machines on the 3 foot diameter oak tree in my back yard when not in use :eek:
Explanation - I have 2 Miller migs, MM252 and MM211 - a 52 yr old 250 amp copper wound stick machine (bought new), an Everlast stick/tig and a Hypertherm PM45 plasma - both Millers cooling air ENTERS the FRONT, pretty sure it's also true of the Everlast - I never could figure out what they were thinking (if at all) by doing that, since it's pretty common to end up with that INTAKE pointing at your weld project (as in, sucking in everything you DON'T want inside your welder)
So my machines live in a corner of the garage under various sized 600 denier barbeque covers when not in use, and when they ARE in use I have a 3' x 4' piece of 1/2" plywood that gets LEANED against the front of the machine (at enough angle NOT to restrict air flow, but BLOCK direct particle flow)
My MM252 was a fantastic CL find, including dual running gear, 3 bottles and a never-used 30A spool gun for $2200 total - replacement cost today would be close to $6k so I tend to be careful (NOT hanging it from the ol' oak tree :lol: )
Holy ****, my 252 is even more to replace now
And my second MM211 is nearly TWICE what I paid - yuck...
For the stick machines I have just over 100 feet of leads with adapters to fit either machine, so they can stay in the garage out of the way. The plasma came with 25' leads so no prob.
Power - I have 6/50 extension cords in 12, 25 and 85 foot lengths most of which get stored on heavy duty garden hose hangers so they're never kinked... Steve
Oh, an older shot of the storage area BEFORE I discovered barbeque covers :)
kaymccampbell
Upstate New York
Anyone ever made under table storage for all their machines?
I rather cut the cords to length and have two dedicated extension cords for 110/220.
No way in Hades. They spray too much ****, along with grinders n paint n sanders n whatnot. Nope. Mine sit on a cart, away from things, unless they're in use.
Jswain
Calgary, AB
Not a welded piece but a drive roller support for my old Miller 175.847F4AFA-68E9-406A-BF1D-2F2B7B20328E.jpeg088DD166-A151-40A0-8370-CF0128E6D754.jpeg
Did the shaft get loose on the wire feed from over tightening? Solid fix! Isn't the wire/roll energized tho while welding?
I had a 180 autoset like that. One end of the shaft was egged from wear(inside the wire feed motor gearbox) so I heated up and removed the gear off the shaft from inside, machined a new shaft then silver soldered it back on. It was kind of a PIA lol. And I believe their newer models used a much larger bronze bushing/shaft to probably eliminate the problem.
sqznby
Coastal NC
Forgot my handle so whipped this up. The bolt was a bit too long and I didn't feel the need to cut/grind it down so I used a nut and rubber washer to keep it tight so it wouldn't rotate while using it. Nothing crazy just to do a little touch up with the grinder :)
Bob Heine
Boca Raton, Florida
@sqznby, I don't use the handles on most of my grinders but I can't bring myself to throw them away. Threaded holes in a piece of steel strap and screwed the handles in so they don't roll around in the drawer. Of course the day I finished making the strap, found another handle.
sqznby
Coastal NC
Honestly, I never use handles for my grinders either it just happens to be a certain time where it made it just a tad bit easier at the angle I needed to grind. And for the life of me I can't remember what the heck I was grinding, huh.
I wish my grinding drawer was that organized :)
