Show us your welding projects
zimman
Mark Twain National Forest
Making an accessory for the Brick--my new Vanagon--that won't make it go any faster or run better. I didn't intend to do a triple-pass weld, but I forgot to turn the heat up on the old Sparky, so pretty much it was either that or grind out all the original weld.
Looks kinda' low--but I'm lazy, so
About perfect! The vise is attached with captive nuts and wingbolts, because--I may have mentioned this--I'm lazy and carrying it as two pieces--not to mention stowing it--is much easier. Work smarter, not harder!
It's getting a couple of coats of Rusto Gloss Black right now, then into the oven--if it fits.
Why do you have a Subaru badge on a Volkswagen? Just asking.
Zim
Beerhippie
Far NE Oregon
Yes his van had a *** change.
Not real sure what this means.
Having the EJ25 means 165 hp and 155 ftlb of torque, vs. 85 hp and 90 ftlb. (both optimistic) of the largest stock engine VW put in these (2.1 L Wasserboxer).
Maintenance-wise, it apples and oranges. The Suby engine is actually a modern engine, with OBDII and all. Since it's still a DO four, it feels and sounds like a hot-rodded VW.
