Show your new tool arrivals
Fly Fishing Rick
Upstate NY
My first Veto bag! I was a bit reluctant to pay their prices but it is extremely well made and pretty well designed. No bag is going to be perfect for everyone but this one checks most of my boxes while being more reasonably sized than my last pack. I managed to fit all of my most used tools from my large bag to this one, which should be plenty for most jobs. I put the rest in a small "overflow" bag that I keep in my car while on jobs.
SC Fly Guy
Aiken, SC & Lakewood, NY
You’ll love it … quality is worth paying for IMO!!
SouthernIllinois
168 mile round trip to the nearest Harbor Freight that had the 87 piece Quinn set in stock.
I had an ulterior motive …. That is also where the nearest White Castle is ;)
Edit: The two pieced of 16 gauge 1/2" pipe came from Menards and is for the Harbor Freight sand blaster I am re-engineering. I changed out the valve stack at the bottom and I need to lengthen the legs to clear the new mixing valve assembly I came up with.
cody1325
Southwest Virginia
Schrade Century (made by Adler in Germany in the '90s) Endeavour and the monthly free sticker pack from Klein.
The Endeavour is very close to the Victorinox 84mm Apprentice, but much easier to find (and slightly larger at 91mm). Almost as good quality. I wanted a decent size knife that was light, but had blade and Phillips. This one is perfect for that, but I'm hesitant to use it as it's close to mint except for some handle scratches.
Also, the sticker pack from Klein for this month. Hadn't completed the form for a couple of years, and did it on a whim a few weeks ago. The old packs featured one sticker printed on vinyl that was very good quality. Now it's three lower quality stickers on one backing. But hey, free stickers. All now reside on my mini toolboxes.
willf650
I had an issue recently where I had to remove a screw to pull a panel out. I thought I was good because I carried a right angle screwdriver on my bag. It wasn’t even close and took me about 30 minutes to remove 2 screws a 1/16 turn at a time with a set of twin grip clones.
After that I waffled around and finally decided to order a VIM 1/2 cut screwdriver set and it’s insane how small they are compared to the right angle screwdriver I had which I thought was tiny. It used 1/2 cut bits too.
I ordered the VIM and canceled it as I thought how often do I need a right angle screwdriver and how much smaller could it be. I was pleasantly surprised with it and glad I ordered it a second time and didn't back out.
Ohio Andy
Columbus, Ohio
I ordered the VIM and canceled it as I thought how often do I need a right angle screwdriver and how much smaller could it be. I was pleasantly surprised with it.
I have the vim 77 set, I've never tried the 42 set.
I don't suppose you know how the bits compare..
It is my belief that the bits are identical but that the 42 set contains the nano ratchet is the difference. Well and that the 77 is more bits and it doesn't have a nano ratchet has more of a ratcheting wrench.
Fly Fishing Rick
Upstate NY
Hope so! So far so good. Kinda shocked how much I was able to fit in it, with some room to spare. That small pile of tools and the hammer is all that was left out from everything I had in the large bag after I loaded the new bag out with my most used tools. The remaining tools went into my "overflow" bag that I carry to jobs but leave in my car. My bag weight also went from 31 lbs to just under 20, but it feels like even more of a difference than that. Pretty sure you're right, I'm going to love it.
ChefRex
New cordless Dremel, my old one has been lacking for a bit and my corded has let out some smoke the last couple of times.
Fiskars knife that does not flick open, maybe it will with use but I want one hand use, kinda disappointed.
And sanding barrels for the Dremel.
Forgot to update, the Fiskers works wonderful one handed with an adjustment thanks @Etchase
I'm sure it would have come to me but experience is the quicker way.
PelicanPines
I have two of those dremels and one M12... Along with several corded. The Dremels are great. The M12 feels funny in my hand...
SC Fly Guy
Great loadout post. I have the same Veto bag and loaded it pretty full like yours. As time went on, I removed a few of the lesser used tools, but mine is only used for DIY projects.
Fly Fishing Rick
Upstate NY
I'm calling it my 90% bag. I wanted something I could just grab and do 90% of most common jobs with rather than trying to carry everything I might ever need for every job... Much easier to just keep a few extra tools out in the car. I'm sure it'll change a lot over the next few weeks as I get used to it.
Moving a selection of bits and other small tools to a zipper pouch rather than the pair of hard cases I used to carry was a game changer. Freed up a whole lot of room and if I lose or break a bit, I can just run to the car if I have no other options... I'm sure it'll continue to evolve for a bit as well, but it seems like a good start.
Ohio Andy
Columbus, Ohio
I like the setup and your loadout....
Jarhead0408
Who knows?
pretty much everything. A few things were left out and my multimeter isn't in a case anymore but this new bag has a dedicated meter pouch which helps.
That's pretty crazy. I've been contemplating buying one for the big truck. I need to just go ahead and pull the trigger. Thanks for the pics. They reallly put things in perspective.
Jarhead0408
Who knows?
Bernsomatic TS4000 trigger start propane or faux-MAP gas torch. I don't know why it has taken me so long to buy one of these. No more fiddling with a lighter with half frozen hands.
And the OEMTOOLS 27306 Long-Reach Harmonic Balancer/Pulley Installer Kit. No intended use yet; just looks like it could unexpectedly come in handy one day.
Coincidentally, I ordered a bunch of 1/2 drum sanding barrels as well, but @ChefRex looks to have found a better price for more of them. I'll be tracking those down to make a bulk buy as well. (Thanks man!)20251121_225224.jpg
Etchase
Hawaii
Sometimes you need to loosen that screw near the hinge to get the flip motion just right. I had to adjust a couple of mine.
ChefRex
Prospecter
Maine
I had to change my Tocamoas rear bumper as id reversed into something. To make it easier , I unbolted the skin but needed to remove my towball to get the skin off.
There i was , 38mm socket on an extendable breaker bar , on the ground , with my foot against the pipe wrench on top and after heating with wax caryon and some wd40 , crack , it eventually came loose. Despite me think I was being careful, I still sheered an inch worth of thread off the towball.
I then proceeded to undo it slowly as I needed my foot in place on the pipe wrench. On that day I decided I needed an impact. Through the research process Id done , and my slight baism towards Bosch , I decided to go for the GDS18V-740N.
I didn't quite think this through maybe as this thing is heavy and large , so I might need to get another one for situations where this won't fit and my 1/4 Makita wont have enough grunt for.
Shoot me , with the addition of a few other purchases , I've found myself running 2 battery ecosystems now , something I didn't want ,but Makita don't make everything and Bosch don't make everything so it is what it is. I will NOT enter a 3rd.
COO Malaysia , interestingly , my little IXO screw driver is made in Hungary , I don't think I've seen a single Bosch power tool made in China although a fair amount of their bits and blades are.
These are a good $100 or more cheaper than the Makita equivalents ,I don't know why , are these baragins or is the Makita more expensive than it needs to be ?
Impact wrenches are a game changer for stuff like that. I agree. I am never going to add another battery platform. I only have Hitachi, Dewalt, Bauer, Torqeedo, and EGO. :unsure:
Squankum
Southeast
I've never seen a white castle IRL.
Apparently there's one 20 miles away!
Made me look! Nearest is (sniff) 352 miles away. Been a long time since I've had one. Been a slightly less longer time since I've seen them sold in the freezer section of a grocery store, so keep an eye peeled for that. "Locations" page of their website does show where to find it in grocery stores.
Beerhippie
Far NE Oregon
I have no idea what a White Castle is, but who screws up the spelling of their meme?
Or is that part of the joke I'm missing?
mikeinri
I think I've only seen them in NJ. Tried it once (a friend was going regardless, as we were in Atlantic City for a mid-winter boat show, and he'd been planning on stopping there as part of the trip). NOT impressed, haven't gone back (hard to believe that was almost 30 years ago).
Mike
BobsYourUncle69
Westchester New York
The movie Harold and Kumar go to White Castle is how I learned about white Castle.
Ffwd a few years I finally land in NY , we go to NJ the next day and I get to try it. That movie hyped it up so much and I was rather disappointed.
Then a few weeks ago , I saw one in Nanuet NY , thought I'd give it a try and it was pretty much the same.
It's not terrible , it just comes across as the bare minimum effort as far as food goes. Compared to nurger king dor example , I find it to be expensive for what it is. Burger King also isn't amazing but it is better value I think.
I didn't know it was a real place at the time of watching the movie so when I heard it was , I wanted to try it
Ohio Andy
Columbus, Ohio
Mike
We have them in Columbus, Ohio.... Every now and then I stop there. For me, I might be more excited that they have Coca-Cola than that they have sliders.
Ohio Andy
Columbus, Ohio
How are you liking your veto pro pac? I was considering one as a quick go bag.
Was also considering an atlas 46 but I think that the veto might be a better fit for me.
