Know Wosad
- Joined
- May 15, 2016
- Messages
- 811
I converted all of my connectors over to those HF high flows (7 pkgs) a few months ago and thought I would be happy with them. Half of them leak air, and I honestly can't tell much, if any difference over my standard 3/8 fittings. Plus they are heavy and often hard to connect. I'm thinking of switching back to my old ones by using two different air lines and just use the high flows where they might (?) do the most good! Better quality brands are just way too expensive! Home Depot has their Husky branded aluminum set that I also thought I might give a try. $15 for similar 4 pc set.
Where's the leak?
Even w/ the cheapest of cheap couplers, I've never had leaks at the actual interface coupling itself, only the threads, which you can probably say is user error. They are really hard to connect/disconnect though, and I think they're the cause of my flow issues as well.
Why did You get the HF ones if you already had 3/8 ones?
I have older SO NiCad impacts. Just recently went to MW for drill etc. Likely going to buy the impact.
Please share your experiences with it.
otc 8260mi didn't know they made these.
Easiest way to tell is that the plastic at the top edge is different between the USA and China packagesExcellent.
I will keep that in mind when at HD next week.
man that is tiny huh
Facom tappet wrenches.
gifts for myself; ABN 4054 hose clamps and an Astro Pneumatic 7848 brake tool set.
Wished we had those stores out here west..
Dunno if these just came out or what but it's the 1st time I've ever seen them on the Snappy truck and picked them up on a scratch n' dent discount as you can see by the pic, it's the BluePoint AP12
After using my first pair of pliers wrench for a while Ive decided to fill out the collection. And to try out the Quickset Cobra.
https://scontent-sea1-1.**.fbcdn.net/v/t31.0-8/15723495_10153983235061782_1108344129871132893_o.jpg?oh=ee3b10606c83a0ba9de838c13d21abef&oe=58EFC977
