Similar tool storage
Kscardsfan
The Little Apple
Does anyone store tools that get used together inside a small box so they stay ready to go? The most recent example I have in my head is trying to find a box to hold my terminal brush, terminal puller and related battery changing tools together so I can just grab them all out of the drawer in one move. Does anyone else do this or am I just going full on OCD about this one?
OccupantRJ
Eastern North Carolina
I don’t because I use the various tools way more in the shop than other locations and I want quick easy access to them. I keep drawers set up for various types of work in the shop and set up a tote bag for use in other locations as needed.
willf650
Yes, In some specialty termination kits I will have a duplicate set of X in that kit just to have everything available in one spot.
NostraThpmas
Yes. I have seperate "kits" for electrical work, upholstery work, etc. I grab the kit box and I have everything I need right there.
signcrafter
Are you working far away from your toolbox? I don't do this for automotive tools. I do keep things like you mentioned together in a drawer so I can grab all of what I need when I open the door. I don't have room to have a bunch of boxes in the drawers. If I need to take a bunch of tools to work on something away from the box I'll grab one of the bags that milwaukee tools come in and throw what I need in there, I have a ton of them that came with milwaukee tools and I don't keep my cordless stuff in those bags. They work good for junkyard runs.
I do keep my construction tools in ridgid boxes by jobs.
Renegade1LI
long island ny
I try to keep like with like, plumbing takes up a lot storage, carpentry same thing and so on. I have found, at least for me it's easier to store tools and equipment by discipline, even if it means doubles or triples of some stuff.
zimman
Mark Twain National Forest
I have a cheap HF plastic ammo box with battery, electrical and tire plug patching in the truck.
Probably less than 30 bucks invested.
Zim
Skellyii
KC Area
I've had rental properties, so I set up bags for each task, i.e. plumbing, electrical, standard repairs, etc. Just grab and go.
For in the shop, I kept some of the plastic boxes that drills and saws come in, and use them to group dedicated tools and supplies together for certain tasks. Saves time not having to root through various drawers cabinets for everything.
danielbuck
I do for some things.
One example would be copper working (think jewelry/art), I keep a ball peen hammer, black smith tongs, rivets, a few snips/cutters and bending jigs and dies and other random items that we use alot all in a metal box. When my wife and I want to work on copper stuff, we bring out the copper working tools. only thing I don't keep in there is the torch, mostly because it's too large to fit.
The other main example I have is electrical tools.
Nobody-named-Olli
The majority of my tools are kit based, aka grab the box and have everything that is needed to complete a task/job.
But none of these fit the description of a drawer based kit. The closest I have fitting that description would be my accessory kits for certain tools. Prominent example, my oscillating multitool. The kit has the tool and everything needed to make cuts in wood, metal, composite/drywall and scrape. Then there are two kits that would fit a drawer: One has everything needed for sanding & dust extraction, the other kit has everything needed for tile/grout removal.
And yes, some of that leads to needing duplicate tools, but I try for variety when the basics are covered. So I have further options. Like: I have a couple of different electrical installation pliers, which all cover the same basic needs for such pliers. But they are different enough that one might get me out of a pinch over the other in certain cases. Requires stringent organization and discipline obviously.
Kind regards,
Olli
PCustoms
VT
Most of my plumbing tools are in one hand carry tool box.
Ditto.
Box stays in the utility room, where most of the plumbing is. If I need something it's in that box, otherwise at this point (renovation done) I really don't need those tools.
In a similar fashion most of my electrical stuff has been hanging in a pouch by the panel.
KnurledNut
n/a
I do a good bit of itinerant work and have several tool rolls and bags set up to grab and go as needed. I keep a variety of metal files in one. Another has a set of body and trim tools. Angle wrenches stay in a roll. Same for my Facom thin wrenches which stay in the roll they came with and extra long combos are in heavy duty wrench rolls. I keep a set of 1/2 drive sockets and 3/8 drive shallow impacts both in small metal boxes inside my main box that are ready to grab.
I also built a fairly comprehensive portable wiring/termination kit which is in a chicago-style case for field use.
Beerhippie
Far NE Oregon
I have a bucket organizer for plumbing and one for carpentry hand tools. My go-bag in the rig has most every tool I need for roadside repairs on both my rigs. My electrical tools are in a belt.
Otherwise, no, I don't organize by job--just fill a bucket with the tools I think I'll need for any task around the plant--then go back to the shop five times for the tools I didn't think I'd need.
K
Kscardsfan
The Little Apple
I swear you and me must've worked together in the past :ROFLMAO:
macs_rock
Idaho
As a home gamer, I've got a handful of Packouts dedicated to tasks/similar tools.
In no particular order:
1) "Fix most things" home toolkit box
2) Electrical box
3) Plumbing box
4) Angle grinder stuff
5) Die grinder and dremel stuff
6) Sawzall stuff
7) Nail guns
8) Nail gun nails
9) Oscillating tool and blades
I have a couple empties that get filled up depending on the task at hand, and I have some tools stashed in my truck that are specific to truck/towing things. The rest are stored in the big boxes in the garage. We have a 27 gal tote of painting supplies, a couple totes of car wash stuff, and a tote of assorted home parts like curtain rod brackets and shelf brackets and such.
My wife has all her nice wood working tools sorted how she likes them, they're much neater than my boxes.
