Awesome thread, Hiball. I have the Napa version of this jack and while it's working just fine, some day I will probably need to a rebuild. Your instruction is just what we need preserve our old USA jacks. Thank you, my friend and I'm looking forward to more of the rebuild. Talk about motivation!
As you are going through the steps, Please let us know what specific tools and parts (numbers) we need to do to properly do a Walker rebuild like you're doing. I'm so glad I have a 3/4" breaker bar and 2" socket. Thanks.![]()
Ive been doing a little thinking and i'm definitely gonna repaint Snap on Red, So Im looking for some help finding the proper Color or Really... Close. I was thinking about having some of the fasteners Chromed to really set the Red off and just scream Snap on. I have enclosed a picture with my ideas and am curious to what you guys think. I dont what to overdue it be scared to use it but i think a little bit would look awesome. Open to suggestions fellas.
Depending on the age of your napa it may not have the same type of tank nut, Some of them use a spanner nut and they my friend are a pain in the Azz. I hope yours doesnt a you can get away with using a big socket. As far as part numbers i will keep everyone up to date and if you look towards the bottom of each thread i have been listing what tools where required to get to that point. Im definitly better at doing than explaining sometimes so bear with me fellas. And by all means if you have any questions feel free to ask dont worry about hijacking my thread its all good.
Snapon Red: PPG Ditzler 73504
Does anyone know where i can buy this paint? I googled but it kept bringing me to GJ posts from the past. Any Major Retailers? Thanks in advance.
My local shop can mix any color and put it in a aerosol can ready to spray. The last one I got it was $20.00 for a half pint of paint and $8.00 for the spray can. Add a can of clear and your all set.
Ill check it out tomorrow, We have a Local Carquest, Oreilly <-- I hate going in there. Its Retard central.
This was at an autobody only store.
Elroy, do you have a opinion as to what brand/paint is the closest to the Snap-On red?
For you paint buffs can i get a nice, shiny, scratch resistant along with longevity look via the rattle can. What procedures other than a quality primer should be followed after a full degreasing and bead-blast?
Elroy has news for ya and he thinks you'll agree. The finished paint is only going to be a good as the prep work under it!!!
You're highest quality catalyzed base coat clear coat is going to look like **** applied over rust and grease.
Look, You got three areas to work here:
The first is the hydraulic systems. You're a pro at that. Done
Second is fixing the "mechanical". Like the caster wheel and the all the snap rings and all the nuts and bolts.!
Then you come to the part that really eats up the time. Surface preparation !! And that's a BIG part of making it look good.
It'a a lot of work but we bet it looks good when done.
Keep it comin......................you know, with the Oooh.
Make it look GOOD Baby!
The paint that I am talking about is actual ppg automotive grade paint custom mixed and installed in a can designed for this purpose. I have done small high quality repairs with this along with SEM brand high build primer and clear in cans. Sometimes its not worth the effort to use a conventional gun when you factor in the cleaning time.
My suggestion, and y'all can take it for what it is worth...take the smallest sample of color you can to your best local powdercoating facility. The colors have come a helluva a long ways, and if you are going to actually use the tool when you are done, it would be well worth it to have a finish that could handle abuse. Of course, that is if you are going to actually use it...
Snap on does sell the color you need in a spray can. I just did my cabinet
Yes, I think this is what mine has, and so far, I haven't been able to remove it. I tried a while back but I haven't had a chance to give it another try. I'm not looking forward to it. Is it safe to apply heat?
For the paint, I recommend the Rustoleum Sunrise Red seen here:
http://www.garagejournal.com/forum/showthread.php?t=38758
