Spreading the Bonney affliction!
bonneyman
Desert SW
I'm the person who got the ratchet stub from Mikeske. And I'm currently working on making it into a genuine stubby ratchet that looks decent. Internals are whisper clean and quite stiff, probably unused or used very little. If the stubby idea doesn't pan out it'll be a spare rebuild kit for one of my other four Bonney T-702K's.
twertsy
Reedville, VA
The other oddball in that drawer is a No. 2588 for holding Ford V8 main bearing nuts. The only other one I remember seeing is HeelSpur's way back in 2017 (Page 21/ Post #817).
You must have missed mine then.............or skipped it because you already have one?
All, lots more Bonney, Plomb, Blackhawk, and some other extraneous goodies like NOS Mustang, Williams, Blue Point, etc. headed to the bay this Friday evening. Stay tuned!
bonneyman
Desert SW
OK, here's where I'm at with my Bonney "stubby" project.
I found a suitable aluminum fitting at a local electronics surplus store. They have all sorts of stuff in there - even aviation parts! This fitting was in that section. I cut and ground it to make it more user friendly, then epoxied it onto the stub. Being a stubby it won't be subjected to alot of torque so I skipped putting a set screw in it. Nice size, not too small, rounded hex flats give decent grip. Though I may just put some heat shrink tubing on the "handle". But here it is now.
bonneyman
Desert SW
Being on a roll I decided to continue my tool modding and make a finger ratchet based on the Bonney ratchets. Had a 3/8" torque wrench that I bought for $8 just the ratchet head. The head is very small, and the gear assembly will fit into the standard Bonney 1/4" drive ratchet. (I've got one - really compact 3/8"!)
Anyway I have this bucket of "parts waiting for a project". I grab all sorts of handles, knobs, brackets, castings, whatever I find at estate sales that looks useful I grab and throw in this bucket. Well, I had this Grohe plastic knob which I found out is some sort of water fixture for kitchen use. Very tough plastic. The TW head fits into it perfectly. The hollow fingers actually hold the forged stub nicely with some grinding, and will give great finger grip. Epoxied it in there, and now I'll have a 3/8" finger ratchet. I could have made it smaller, but with arthritis setting in there is now such a thing as too small. Plus I can swap out the gear for a 1/4" drive in the future if need be. Probably with spray it with a coat of that Flex Seal aerosol, to give it a sticking grip. Probably will help with using it. But at the present stage it looks like this:
Very nice finger ratchet, and cheap to boot! Got this sparkplug gapper in a tool lot. Marked in inches and millimeters.20210915_203152.jpg20210915_203145.jpg
Mikeske
Washington State
Yes getting and passing stuff around for us Bonney collectors is a good thing. Sorry if I had been around much as I had to attend to family matters. I may not be on much for a while but will try to get on when I can until I resolve the family matters.
bonneyman
Desert SW
OK, here are my two completed Bonney ratchet jobs. The 3/8" stubby and 3/8" finger ratchet.
I want to thank Mikeske for sending me the broken stub - I hope he likes what I did with it.
Mikeske
Washington State
I like it. What did you do? Thread a hex nut on the end and then shrink wrap the rubber over it?
I like it also and it is a great idea.
bonneyman
Desert SW
I decided to take a family pic of my Bonney 3/8" drive ratchets.
Top to bottom:
Stubby rat mod
Finger rat mod
3/8" anvil in 1/4" body
(3) standard 3/8" rats - beater, decent, NOS
3/8" flex rats (new style and older style)
Mind you I don't really like Bonney ratchets all that much. But how could I call myself Bonneyman if I didn't have any? :LOL:
bonneyman
Desert SW
And while I was digging out my ratchets I came across my Bonney tool "orphanage" and had some new additions to put in there. This roll is for all those partial sets, loners, stragglers, and orphan tools. Figured this was a s good a time as any to add those few tools and take pics.
It's getting a bit crowded!
I don't want to steal Todd's thunder here, but this was just listed and I figured one of you gentlemen would want to know.
I've done a couple deals with this seller. Last purchase we worked out a deal on multiple items, discounts on which varied from 5% to 23%.
YMMV
He apparently bought out the distressed inventory from a hardware store (or warehouse) and has a mess of NOS oddballs well worth taking a look at. There should be a way to exclude "screws" from the search results when you look at all his items.
Not to be dismissive of the loners, stragglers, and orphans, but I am more interested in the roll-up, bman! :)
Which of the wrenches, if any, were original to the pouch? It dates to the mid to late 1970's. The "ratchet" in the set name usually refers to the snap-over action type with the hinged lower jaw made by Imperial, Stride, and even Herbrand during the Triangle era. For tube fittings, valves, nuts and bolts. What is the marking under the NSN? I can make out "Imperial" and that's about it. Secondly, what are the markings on the bottom of each pocket? I can make out the sizes at the top, but not the markings on the bottom.
PSCo1867
PA
Hit & miss today at the flea - stoked to find a “C” S-wrench, but it is missing a bit. I already had an “A” S-wrench, but I couldn’t separate these two.
1729 DOE from Aug1927 (HS).
1023 from Sep1942 (IT) - I have not seen the stamp on the shaft (instead of cheek) before.
Left-behinds: I pawed through a dozen USMC machine wrenches, hoping to find similar-looking “Ford-owners” wrenches, to no avail.
Found an "A" S-wrench in the wild of the steel mill today. Thanks to LesserSon for letting me know these are BonneyA-wrench.jpg
I spotted this odd socket at a yard sale on Saturday. After getting it home and taking a closer look, I discovered the faint Bonney marking and the part number. I have to assume it’s an early refrigeration socket to be used with a female drive refrigeration ratchet.
-Don01433EB1-0081-4C2C-847E-6EF6C646B87F.jpeg0843EDC8-3FAB-49C4-AFB1-DD7424E13645.jpeg
bonneyman
Desert SW
I got that pouch off of the classifieds some years ago. Back then I was into the "tool roll" thing. It was nice condition and only a few bucks. So, none of the tools in it were original to it.
It's packed away in my deep storage so I don't have instant access to it at this time. Next time I open up the stash I'll try and get that nomenclature info for ya.
Ricky Joe
Roanoke, Va.
Are these Bonney? I know the one on the right is. I mean the trio.
LesserSon
PA USA
Hmm. The model numbers agree with what’s shown on p13 of the 1923 catalog. But the “DROP FORGED” and lack of Bonney logos is not typical of Bonney. Possibly 600-series designated S-wrenches made by more than one manufacturer. More catalog research, or someone who has branded versions may tell.
Those numbers are not unique to Bonney. They are Williams model numbers. I'm not saying those were made by Williams. In fact they seem as atypical for Williams as much as Bonney with those raised letter DROP FORGED markings.
LesserSon
PA USA
They remind me of these straight DOEs, which I see frequently and don’t usually buy, unless included in an unsorted mass. Some of these are from numbered sets, some aren’t, and don’t have any marks indicating opening sizes, nor model numbers. They have “MADE IN U.S.A.” on the reverse.
Ricky Joe
Roanoke, Va.
I think those might be Walden, by the shape of the shank and the lack of manufacturer name. They look close, anyway. Mine could be, but no Made in USA and shank has a different profile. Color is close, though.
LesserSon
PA USA
You notice that your 661 B has no hyphen, and the openings are stamped on the reverse, rather than raised on the front? I would think that indicates a different age, if not a different manufacturer. I sort of feel the same about the smallest guy in my pic - the geometry of the heads and the proportion of the shank are dissimilar to the other two. Maybe Waldens all, but really, these are anonymous wrenches that any drop forge facility could have produced. An unbranded tool has to have some distinctive/proprietary element to be attributable to a specific manufacturer, don’t you think?
I picked up this partial combo set at the flea today. Later than I collect. Somebody school me. Are these 1950's? Pre-conglomeration? And look at the largest wrench. It's like they flattened the bubble logo and filled in the grooves. Maybe a replacement by the PO, or maybe the set came that way in a time of transition, huh? Also, maybe you 'later' collectors don't notice, because you're not handling earlier wrenches, but these things have some THICK shanks. Going in the flippety-flip-flip-flip pile.
LesserSon
PA USA
Streamline begins 1949 (also Fred S Durham’s death), continues to 1962, when Outline picks up, lasting to introduction of Full Polish in 1967 (also Fred S Durham II’s death).
Yes, I think a transition with mixed sets is likely. Since the date codes fade out around 1959 (on combos), it would be hard to demonstrate with physical evidence only. A pristine NOS tool roll set would maybe prove it.
LesserSon
PA USA
Those Streamlines look like maybe AT date codes, so 1956? So I think the Outline is a separate, later purchase.
JjKk40
New York
I believe these are Vlceck. I have a few as well and same no size markings or manufacture markings. Lugs posted a set in the "Kit wrenches"
thread i was just reading except his have markings.
Post #51 here...
Edit... these could also be a Norivell Wrench set as well.
LesserSon
PA USA
Spotted this 661A today and bought it…well, not sure why. I was buying any S-wrench for a while, but lately focusing on just Bonney. I’ll see if I have any like it, whether it seems to be Vlchek, and go from there.
Mikeske
Washington State
Also some sockets. This LT20 has an interesting laser-engraved number.
When I was at Boeing for the last ten years I was at the company they provided all tools to the assemblers/mechanics and laser numbering like that identified what tool kit it came out. So if a assembler looses a tool and it found later it can be traced to the toolkit. I don't know how it applies to that particular tool but if it is a SAE socket I am going to say it likely came out of a aviation tool kit.
