Spreading the Bonney affliction!
LesserSon
PA USA
My thought is that Bonney switched from brown to red in the late ‘40s (maybe 1949), using up the “plane train automobile” logos on new red boxes, then continuing with the tartan logos. This explains the few red boxes with the “p t a” logos. Maybe too, there could be a few brown boxes with the tartan logo? That’s what I meant by a “mixed-elements transition”.
The red CC10 roller cart persisted from 1950 to at least 1957, and its tan precurser (CC cart) only differs from it in the b/w catalog illustrations by having the casters mounted outside the corners (“outrigger”).IMG_9959.jpeg
Since the one alinc100 posted is both brown and has the casters inboard, could be Bonney added the “10” to “CC” only to distinguish it from the CC5 and CC15 carts, and the caster and color changes are independent from the model number change.
Help me if my logic has failed.
I see no trace of a Bonney logo, but I see no other company logo, either. Whatever its history, I’m adopting it into my Bonney collection. IMG_9958.jpeg
And I am favoring putting my MB82 on it, instead of the earlier box, until I decide about the “Shimano” logo.IMG_9965.jpeg
LesserSon
PA USA
My quest to find a mass market match to 1950s Bonney red crinkle (center) has led me to conclude there isn’t one. Rustoleum 2X (Painters Touch) Regal Red (right) is very close to the oxidized surface, but there are hints under the surface that suggest Rustoleum Stops Rust Sunrise Red (left).
The surface at the left is a (formerly powder blue) Union tool tote I sprayed this morning at 70°F 80% humidity in hopes of inspiring some crinkle (got a tiny bit, so I’m encouraged).
I will wait the six weeks (or whatever it is, then spray Regal Red satin lightly over it and check it again.
Mintgrun
Kingston, Wa.
Have you tried using a heat gun to encourage crinkling?
These guys are discussing using heat
The missing aluminum trim piece on your box looks a little wider than the VW trim.
LesserSon
PA USA
I picked up this 3/4hp Craftsman motor for $10 at last year’s NY90 50mile garage sale, and it’s been sitting in various states of inattention with a POS 2-arm puller (which did a fine job deforming the pulley) ever since. I considered buying a beefier Harbor Freight puller, or some USA brand at the flea markets I frequent, but then figured I’d just keep an eye out for a Bonney to add to the collection.
Today a PO12 arrived from eBay, $37.09 w tax, free shipping (not much more than it sold for in 1950); I put it to immediate use. IMG_0036.jpeg
LesserSon
PA USA
I continued my color experiments today. Home Depot had Regal Red in gloss only, so I picked up two different sprays, mostly for formula compatibility with what they were going over. I think either result works okay. IMG_0040.jpeg
The underside of some original drawers didn’t have a crinkle finish. Without the texture, I think Brick Red wins by a nose. But considering the vagueries of environmental exposure and current lighting conditions, I think either serves.
S-K Tool Fanatic!
NE Ohio
Picked this up for $6, more than I usually would pay, but I wanted a Bonney for my collection.
Before (pardon the bad pic)
Here it is after wire wheeling and a coat of fluid film.
LesserSon
PA USA
Before repaint:
I started with the back, which was silver as found. The obvious red spray edge at the corners (and on the casters, though they’re already booted) had me thinking at first that it had already been repainted at some point, but the color match to other Bonney boxes I have made me decide that’s just the way it came from the factory IMG_0045.jpeg
First a coat of Sunrise Red:IMG_0047.jpeg
Then a coat of Heritage Red:IMG_0048.jpeg
Then I got brave and did the top, sides, and bottom interior (from which all the original crinkle had crumbled and lay mixed with rust and grime), and finally the front.
After an hour, I used mineral spirits and paper towels to help the Sunrise Red peek though a bit. IMG_0055.jpeg
After a couple hours, I decided the color wasn’t earthy enough, so I put some Brick Red over the whole thing. Maybe it was just the can I had, but the pigment wasn’t very opaque, which worked in my favor, as I wanted to use it as toner.
After repaint:IMG_0058.jpeg
LesserSon
PA USA
Then I tried an idea out that I had for my MB82. The Bonney logo was almost entirely worn off. IMG_9965.jpeg
But I have a better one on another box. IMG_6929.jpegIMG_6945.jpegI took two photos (one holding a ruler for scale) and pasted them into MS Publisher. I matched the ruler to the app’s border scale, then scaled the rulerless photo to match as well, and deleted the one with the ruler. Now I could print the logo at actual scale without trial and error.
I cut out the letters with a utility knife, affixed them to the box with rubber cement, and masked off what I didn’t want ivory IMG_0056.jpeg
LIGHTLY sprayed.
I will add the drop shadow effect and tartan field with black paint with a brush, but that’s a winter project. I plan to add the Bonney logo the same way to the roller cart.
GoToGuy_Ron
Greg: I wondered how closely this chest matches the one you got from Todd?
I couldn’t relocate the images that were
posted previously.
There is no Bonney branding on it; in fact, I can’t make out whatever was on this label. IMG_9880.jpeg
If you could take good photo with no reflection, in photo editor try changing colors or switching to negative photo colors. Also try a UV flashlight, there cheap, and that may get print or logos to " pop out ".
GoToGuy_Ron
New to the Bonney affliction but wanted to share this set I picked up on an online ad for what I thought was too good to pass up ($65!). Still trying to put together my polished combination set but I guess I’ve got another set to complete now! 16694990-BF45-43FB-8943-4B7BE07C4C8A.jpeg
I have this complete set with red roll up. The sizes are 1/4 thru 1 inch the set I bought new in 80's. They have served me well in the Aviation industry.
ararat
Ararat NC
Here's a DOE wrench that has a different style date code. A2R. I haven't seen that before. Maybe they changed something in the middle of the month.
Snaparxon
Closer to Idaho
Found a couple of Bonney Whitworth wrenches today. If you need these for your collection let me know. I will pass these on for what little bit I'm into them plus as cheap of freight as I can do.
Bottom 2 wrenches W1164 and W1165
LesserSon
PA USA
Here’s my Bonney findings for the day. I also found a small Forsberg-style straight screwdriver and a B-shield F29 DOE, but both were very rough - the tip of the driver was almost gone and the handle had plier marks, while the F29 had a broken jaw welded back on.
outofbounds
Looking for a positive ID on this 1/2 Drive ratchet. Previously posted randomly and identified as a Truth but no markings to definitively support this. Since I presume Bonney made the Truth ratchets I figured I’d let the Bonney experts weigh in on this. Is this perhaps a special tool kit ratchet with the part number shown?
Since I presume Bonney made the Truth ratchets...
I'm guessing your presumption is based on the switch, which is, admittedly, very reminiscent of the Bonney switches of the 40s, but it's probably just a coincidence of TRUTH using a similar, simple pin-type design. The forgings of the bodies of the ratchets and the construction are not the same. I can see how the "B" (in that "B" with a small "s" inside of it forge marking) is also tempting a Bonney ID, but as 3bay alluded to, that marking doesn't show up on Bonney ratchets or other tools and is not known to be associated with Bonney.
outofbounds
Thanks to you guys, 3Bay & Lugz, for the direction on this. I scoured the Truth thread (only 3 pages vs. 131 pages here!) and noticed a 1/2 ratchet virtually identical to this one in an old Ward Master set marked "R6 USA". If you want to go down in history as true sages, you might offer insight to the Part No. logic that makes mine read "R6A USA".......o_O
LesserSon
PA USA
Yardsaling today, I picked up a PH1 2oz ballpein and a 16J narrow concrete jointer (ca1915). The jointer was pretty rusty as found. IMG_0268.jpeg
But some vigorous scraping and a few minutes on the wire wheel made that all better. The grip is receiving separate attention. IMG_0278.jpeg
I think I now have three PH1 hammers, and every one has some kind of warp to the handle.
LesserSon
PA USA
Picked up a mostly-complete Set No.WS in original box last weekend for $15. Sold for $14.55 in 1932, by which time the sockets and some drive tools had different designs (knurled band). The few date codes I noticed were “U” (1929). IMG_0282.jpeg
I thought OR posted a box like this, without a visible logo, but haven’t relocated the post. IMG_0291.jpeg
In addition to some other-branded subs and extras and a thick layer of hardened oily crud, it contained a Bonney 4093rat 4087tee 4084spdr 4091ext 4095uni and sockets D28,26,25,20,19,18(owner-ground narrower),16,14. Missing D24,22.
A Herbrand substituted for the missing 5”ext was owner-marked with three short slashes, like the Bonney drive tools. I am moving my collection from one room to another, but probably have the three missing items to fill in.
LesserSon
PA USA
Yes - 1/2dr Vlchek 3/4 & 9/16, Husky 11/32, a couple 3/8dr. There are two Wright tools I don’t recognize, looking like sockets with an eccentric 3/8 sq hole end and a larger keyhole end. I’m at work now, so I’ll post pics of the extras this evening.
LesserSon
PA USA
OR - Somebody else, then. I’ll take another look through the thread. EDIT - right guy, wrong box and wrong thread.
At the request of 3bay, here’s what else was in the box:IMG_0294.jpeg
The drive plug in the Bonney rat turned out to be Hinsdale.
A Wright drag link socket and whatever these two things are.IMG_0299.jpegIMG_0297.jpegIMG_0298.jpeg
I think the small hinged thing in the center is a can-opener. The two L-shaped arms…maybe for a large snap-ring pliers?
LUGZ - I did find a 4090ext from 1928 and spare D22 & D24 in my hoard. I even have the right drive plug, but it’s already with an appropriate ratchet. IMG_0260.jpeg
^ the odd hinged thing is a P38 can opener
Shelby / Shelby Corp., Shelby, OH / "P38" can opener / patent 2413528 Dec 31 1946 & RE22934 Nov 11 1947 John W. Speaker / see also J.W. Speaker Corp., see also KoolAir, St. Paul, MN /
Speaker / J.W. Speaker Corp., Milwaukee, WI / "P38" can opener / patent 2413528 Dec 31 1946 & RE22934 Nov 11 1947 John W. Speaker / also manufactured by KoolAire, St. Paul, MN, and Shelby Corp., Shelby, OH / https://www.army.mil/article/25736/the_best_army_invention_ever /
KoolAire / KoolAire, St. Paul, MN / "P38" can opener / patent 2413528 Dec 31 1946 & RE22934 Nov 11 1947 John W. Speaker / see also J.W. Speaker Corp, see also Shelby Corp. /
^ this is all more in Private Lugnutz's area of expertise, but ..... I THINK that the Speaker company was the first to produce these units. (Can openers, bottle openers, lid lifter, and corkscrews is a weird rabbit hole.... I still have several hundred files in an "unknown" folder I need to sort through, which is why I try to NOT mention them here.)
Why always the bent nails in tool boxes? What's up with that? Is it a thing like using roofing nails to secure the heads onto ball-pein hammers?
(I've sent an inquiry to Wright regarding those sockets, but my eyeballs are telling me some sort of gland nut socket maybe? I hate making wild guesses.... especially when that gizmo in the other thread turned out to be a "barrel vise".)
Mike'smeatshop
My dad would of straighten those nails and used them again. It is a growing up in the depression thing.
^ My Grandfather and his partner Emil taught me how to straighten nails when I was 6 years old and they were building Grandma and Grandpa's new house. I was helping! (I think they actually used those nails, too.) (Grandpa landed at Ellis Island in 1903)
