State Select Anode location
BuyMyGarage
MIchigan
I have a 19 year old State Select water heater, propane, on well water. Finally got the rotten egg smell and figure it is the anode rod.
Model PR650ccvit
I've been to the website, but no good drawings.
The anode rod location is not easily visible, I suspect it is under the Power vent.
Any Ideas?
PCustoms
VT
"19 year old State Select water heater"
Incredible, that deserves a "you ****"
My 1985 unit (Bradford White?) was still working 30+yrs later when I moved in.
One day the bottom element died, come to find out the sludge had built up so far it overheated. I swapped it, then swapped the heater a few years later.
When I cut it open, The ceramic was starting to fail, contributing to the buildup. There either wasn't an anode or it was long since decomposed.
PCustoms
VT
Had a commercial Bradford in a school I was the building manager for, lasted 3 years. In 1986. it for went for $3000. That was a lot in '86
I was wrong, it was a Vaughn.
In trying to figure out what brand, I found my old thread!
PCustoms
VT
That was not meant to be negative, pretty amazing that much scale build up.
Oh I didn't take it that way.
Crazy I'd barely been here 2 years, apparently the previous owner let it get BAD. I sucked/scraped enough out to get enough space for the element and swapped heaters a few months later IIRC.
