Between 485 & 705 SQ/FT Steven's Craftsman Space
taumac
Brooksville, Fl
Picked up these Craftsman adjustable wrenches (?).
These appear to be NOS (new old stock): never used. I guess in some cases NOS also means "got for Christmas and never opened".
I figure they will make good chisel and punch holders. :)
Those are box end adjustable wrenches. I have one and to my surprise very usable. I wouldn't mine finding the other 2 to complete my set.
R
radrush
Atlanta, GA
My Current CRAFTSMAN 19.2V C3 collection:
27 tools in my 19.2V C3 Custom Cordless Combo:
1/2" Heavy-Duty Drill / Item # 00935704000P Model # 35704
1/2" Brushless Drill Driver / Item # 00938595000P Model # 38595
3/8" Compact Right Angle Drill / Item # 00943448000P Model # 11576X
1/2" Hammer Drill / Item # 00925342000P Model # 11580X
1/4" 3-Speed Impact Driver / Item # 00939319000P Model # ID2025
Reciprocating Saw / Item # 00917549000P Model # CRS1000
One-Handed Reciprocating Saw / Model # 17600
7-1/4" Circular Saw with Laser / Model # 11585
5-1/2" Trim Saw with laser / Model # 11578
HAMMERHEAD™ AUTO-HAMMER / Item # 00938600000P Model # 38600
7-1/4" Miter Saw / Item # 00950004000P Model # BT2010
1/2" Heavy Duty Impact Wrench / Item # 00945195000P Model # ID2030K
3/8" Impact Wrench / Item # 00932742000P Model # 32742
Max Axess Auto Ratchet / Item # 00939558000P Model # 39558
Pad Sander (aka Corner Sander) / Item # 11570 Model # 11570
Multi-Tool / Item # 38599 Model # 38599
4 1/2" Angle Grinder / Item # 34407 Model # FS2600
Fluorescent Photon Emitter / Item # 00911407000P Model # 11407
LED Light / Item # 00917601000P Model # 17601
Worklight / Item # 00911391000P Model # 11391
Custom Worklight / Model # 007
Trimmer / Item # 07174380000P Model # CR2050
Leaf Blower / Item # 07174833000P Model # CR2100
Chemical Sprayer / Item # 17599 Model # 17599
Personal Fan / Model # 11595
LED worklight / Item # 950202000P Model # 5518
Orbital Buffer / Model 11597
DRILLs and DRIVERs
drill
[dril] --- NOUN --- 1.a hand tool, power tool, or machine with a rotating cutting tip or reciprocating hammer or chisel, used for making holes.
1/2" Heavy-Duty Drill Powered by XCP
•Robust motor delivers up to 1600 RPM or 465 in. lbs. in torque
•Featuring a 24 position clutch for precision driving
•Single sleeve keyless chuck grabs bits fast
•Balanced design and ergonomic shape deliver more control
•Integrated LED illuminates work
•XCP battery is built to perform in extreme weather conditions
Craftsman's most POWERFUL C3 drill ever!
Brushless Motor -
---without brushes the motor produces less heat
---provides a 50% longer run time
---provides 30% more power and a 10X longer motor life
•Compact 2.0Ah Lithium-Ion Battery
---provides up to 20% more run time
---holds a charge 4X times longer
---recharges in less than 1 hour
•600 In-Lbs of Torque
•22 Position, Adjustable Clutch
•2 Speed, All Metal Gearbox - 0-470 RPM's / 0-1800 RPM's
•1/2" Single Sleeve, Jacobs, Metal, Keyless Chuck
•Variable Speed Trigger
•Battery Fuel Gauge
•Dual Led Work Light
•Dual Onboard Bit Storage
•Overmold Grip with Microtexture
•Auxillary Handle - For increased control
•Powerful Variable Speed Motor Produces 0-1,100 RPM
•Compact 3/8-in. Right Angle Head And Chuck Design
•Oversized Trigger for improved comfort while drilling
•On-board bit storage for convenient holding of bits
•Overmold Grip With Micro-texture
•Forward/Reverse Selector
1/2" Hammer Drill
•½” Metal Ratcheting Chuck
•515 in. lbs. of Torque (while using a 35702 C3 battery)
•3 Position Clutch Bypass for easy mode changes
•Integrated LED work light
•Featuring a 3-speed selector:
---High: 0-3,200 RPM
---Medium: 0-2,200 RPM
---Low: 0-1,300 RPM
•Powerful motor provides up to 1,750 In-Lbs.
•Integrated 3-LED light illumination
XCP Compact Lithium-Ion Battery Pack
Item # 00935707000P Model # PP2020
•Full charge takes about 30 minutes
•Weather resistant and able to withstand extreme temperatures
•Features a charge level indicator
•Lithium Ion batteries included
R
radrush
Atlanta, GA
SAWs
HAMMERs
saw
[sô] --- NOUN --- 1. a hand tool for cutting wood or other materials, typically with a long, thin serrated steel blade and operated using a backward and forward movement
ham·mer
[ˈhamər] --- NOUN --- 1. a tool with a heavy metal head mounted at right angles at the end of a handle, used for jobs such as breaking things and driving in nails.
Reciprocating Saw
•0-3100 SPM variable-speed motor
•removable battery pack
•A soft-grip overmolded handle and adjustable shoe
•Tool-less blade clamp
•7/8-inch blade stroke
•heavy-duty extended-length trigger switch with lock-off
•Weight: 5.02 pounds
Model # 17600
•Lightweight, balanced design offers more control
•Up to 3,500 SPM cuts easily through many materials
•½ in. blade stroke distributes wear evenly
•One handed operation gets into places other tools can’t
•Tool-less blade change
Model # 11585
•includes 24-tooth carbide tipped blade and edge guides
•3600 RPM rotation gives fast, accurate cuts
•dual lasers plot lines quickly
•spindle lock arbor makes blade change easy
•lightweight design enhances control.
Model # 11578
•includes: edge guides, AAA laser battery, 5 ½ in. blade and hex key
•Die cast aluminum blade guard delivers lightweight protection
•Spindle lock makes blade change fast
•50 degree bevel changes angles easy
•Edge guides ensure accurate cuts
•Depth setting adjustment works with the turn of a wrist
•Laser display makes cutting straight easier
ROTATING AUTO HAMMER
• Rotating Head - Drive nails flush in the tightest spaces. Choose between 0 degrees, 45 degrees and 80 degrees.
• Powerful – 3600 IPM's to drive up to 1 3-1/2" nails flush to the service.
• Bright LED Work Light - for added light when lighting conditions are less than ideal
7-1/4" Miter Saw
•Heavy Duty 19.2-Volt Motor With 4,500 RPM for a variety of cuts
•7 1/4-in. Carbide Tipped Blade for improved performance and fast, clean cuts
•Adjustable bevel from 0-45 Degrees with adjustable positive stops at 0, 45 degrees
•Up To 2x4 Cutting Capacities and 4-1/4" cross cut capacity
•Built-in 9 Ball Detent stops at the most common miter cutting angles
R
radrush
Atlanta, GA
WRENCHes
wrench
[ren(t)SH] --- NOUN --- 1.a tool used for gripping and turning nuts, bolts, pipes, etc.
1/2" Heavy Duty Impact Wrench Kit Powered by 4Ah XCP
Item # 00945195000P | Model # ID2030K
•Powerful Motor produces 0-3,000 RPM
•4 Amp-hour XCP Lithium-Ion Battery Pack provides up to 4x runtime/20% more torque
•1/2-in. Square Anvil with detent pin retention
•Up to 3,000 Impacts per minute
•Up to 300 ft-lbs. of torque for heavy duty applications
•Built-in 3-LED Lights illuminates dark work areas to maximize visibility
•Micro-texture overmold grip for added user comfort and improved tactile control
3/8" Impact Wrench
Item # 00932742000P | Model # 32742
•features a 3/8 in square drive with retention clip
•LED lights illuminate work surfaces
•3,500 impacts per minute deliver a consistent 130 ft. lbs. of torque
•Great for automotive and structural work
•Rugged design stands up to on the job abuse
•Variable speed trigger adapts to the job
Item # 00939558000P | Model # 39558
•With reliable fade-free 19.2 Volt lithium-ion battery
•Fasten and unfasten long rods and bolts
•Forward/reverse toggle switch
•Paddle switch for fastening speed up to 225 rpm
•Lock switch avoids unintentional starts
•LED light switch for bright illumination with low power drain
•Work anywhere, and reach tight spots
•Includes 3/8in., 7/16in., and 1/2 in. sockets and square 3/8in. adapter
R
radrush
Atlanta, GA
SANDERs
GRINDERs
FLASHLIGHTs
sand·er
[ˈsandər] --- NOUN --- 1. a power tool used for smoothing a surface with sandpaper or other abrasive material
grind·er.
[ˈɡrīndər] --- NOUN --- 1. a machine used for grinding something
flash·light.
[ˈflaSHˌlīt] --- NOUN --- 1. a battery-operated portable light.
Item # 11570 | Model # 11570
•Lightweight and ergonomic design gives you more control
•Cordless build gives greater flexibility
•Triangle pads get in where others can’t
•Sealed design ensure longevity
•11,000 OPM speed delivers smooth finishes
Multi-Tool
Item # 38599 | Model # 38599
•Tool-less Accessory Exchange with Quick Release Lever
- Allows for accessories to be easily exchanged with a simple 150° lever rotation
- tool-less accessory exchange
•Variable Speed Dial
– for better control for a wide range of applications
- 7,500 – 15,000 OPM’s
•2 Bright LED Work Lights
•10 Accessories included in the kit
- 1 Flush Cut Blade
- 1 Sanding Pad
- 8 Pieces of Sandpaper
•Accepts most major brands multi-tool accessories
– for the ultimate in convenience and versatility
Item # 34407 | Model # FS2600
•kit includes: grinder, grinding wheel, wheel wrench, auxiliary handle and operator’s manual
•Handle rotates and adjusts for serious control
•C3 emblem doubles as a live tool indicator
•Uses 4 1/2 inch grinding and cutting wheels
•Cordless design delivers flexibility
•Ergonomic shape ensures on the job comfort
•6,500 RPM speed cuts and grinds fast
Item # 00911407000P | Model # 11407
•kit includes: Light and bulb
•Rugged plastic build and shock absorptive design ensure long life
•Fluorescent light shines bright with little energy use
•Ergonomic design and hook makes it easy to use
•Includes lanyard for easy transport
LED Light
•1 watt LED light
•Pivoting head rotates 180 degrees
•Compact design and light weight make it super transportable
•7 times longer run time when compared to Craftsman 11391 Work Light
•Folding hook gets out of the way when not needed
•Unique low design is more stable than others
Worklight
•180 degree pivoting head for users convenience
•over-mold grip and switch for users comfort
•High-intensity bulb for better visibility
Custom Worklight
Model # 007
•1260 Lumen LED Super Flashlight
•die cast aluminum housed LED light is mounted on a 150 degree adjustable trunnion bracket mount.
•LED lifespan = 50,000 hours
R
radrush
Atlanta, GA
Lawn & Garden & Other cool Stuff
Did Dom Quinto invent the leaf blower? A number of google results combining “Dom Quinto” and “Leaf Blower” all point to a single wikipedia entry that reads “citation needed”. So for the time being Quinto remains a figure shrouded in mystery.
Trimmer
•12" Cutting Swath
•Single Line Auto-Feed Head
•Telecopic Boom - Articulating Head - Edging Guide - Adjustable assist handle
•Robust Lower Boom
•C3 Overmold
•5.2 lbs
Leaf Blower
•140 mph with high speed tip
•C3 Overmold
•5.2 lbs.
Chemical Sprayer:
•Lock-in spray wand - Spray wand locks into handle for one-handed use
•Spray wand and tip - Brass spray wand and brass adjustable nozzle for durability and c hemical resistance. Nozzle adjusts from spray to stream
•1.25 gallon tank - Removable tank for easy filling and emptying of c hemicals
•On-board measuring cap - Convenient on-board measuring cap to mix additives
•Chemical Sprayer kit includes one brass wand, one hose, and an operator's manual
Personal Fan
Model # 11595
2 speed motor, pivoting base. For indoor and outdoor use.
LED work light
•24 bright LEDs provide significant energy-efficient light
•0-200 degree Pivoting Head
•over-mold grip with micro texture
•free standing - lets you position the light where needed
•A hole opening in the hinge allows you to place the light on a hook
Orbital Buffer
Model 11597
•provides a professional swirl free finish
•conveniently located slide switch
•kit includes application bonnet, polishing bonnet, and operators manual
  • household_craftsman_personal_192v_c3-fp-829288894dca6573bab59e36d38c380f.jpg
R
radrush
Atlanta, GA
Currently NOT in my CRAFTSMAN 19.2V C3 collection:
Spotlight
Model 11593
•high intensity spot light produces 8,000 LUX
•run-time up to 30 minutes on a single charge
•features a lock-on switch for hands free operation
•over-mold grip
•impact resistant housing for durability
Radio
Radio II
Item # 00945192000P Model # EL2200
•Battery Charging Port conveniently charges 19.2-Volt C3 Batteries
•2 Power Source Options: can be powered by a Craftsman C3 19.2-Volt Battery or standard electrical outlet
•AM/FM/AUX/Bluetooth Modes
•Integrated Bluetooth® Wireless Technology easily connects to your Bluetooth enabled device to enjoy music wirelessly
•3.5mm Auxiliary Output Jack Allows For Speaker Expansion or Headphones
•On-Board Storage Tray conveniently stores music devices while charging and/or playing
•USB Charging Port provides 2 amps of power for charging smartphones, tablets and other electronic devices
Radio III
Item # 00945190000P Model # EL2100
•Integrated Bluetooth Wireless Technology easily pairs to your Bluetooth enabled device to 4 Different Modes AM/FM/AUX/Bluetooth
•Integrated Bluetooth Wireless Technology easily pairs to your Bluetooth enabled device to enjoy audio without cables
•10 FM / 10 AM presets store your favorite stations even when disconnected from power source
•On-Board Device Storage conveniently stores music device while charging and/or playing
•High Quality Speaker provides loud, clear sound in a compact design
•3.5mm Auxiliary Input with Cord Wrap for connecting a variety of music devices
•Built-in USB Port provides 1 amp of power for fast charging of most devices
Stapler
Model 11577
◾Lock-Off switch and safety interlock
◾Fires 40 staples per minute – 6 lengths of 3/8 in. Crown staples: 1/4, 5/16, 3/8, 17/32, 1/2, and 9/16
◾Depth adjustment knob – changes driving force/depth for use in a variety of materials
◾Ergonomically designed handle – molded-in comfort grip
◾19.2 Volt – Nickel-cadmium rechargeable battery required
◾Includes: Brads
Brad Nailer
Item # 00942980000P Model # FS2000
•Two Modes: Single sequential or contact mode
•Tool-less jam release
•2 LED lights helps illuminate the work surface
•Tool less depth-of-drive adjustment for proper setting of nails
•Low nail indicator to quickly see when you need to reload...
R
radrush
Atlanta, GA
JigSaw
Item # 00911569000P Model # 11569
•Craftsman C3 19.2 volt jig saw with laser
•4 orbital rotation types help tailor cutting to the material
•1 in. stroke helps power through cutting
•Accepts T shanks blades
•Quick release blade clamp changes fast
•Adjustable base tilts 45 degrees left or right for bevel cuts
•On-board table storage keeps additional blades conveniently on hand
•LaserTrak line gives you precise blade alignment
•Trigger-controlled variable speeds adapt to material changes
Chainsaw
Item # 07134131000P Model # CR2500A
•Craftsman C3 19.2V lithium chainsaw is perfect for trimming and cutting fall trees, cleaning up after storms
•19.2 Volt battery-powered engine is powerful and convenient
•10-inch blade is perfect for deep cutting
•Push-button oiler takes guesswork and mess out of lubricating the blade
•Lightweight design makes maneuvering and controlling the saw easy
Hedge Trimmer
Item # 07174832000P Model # CR2600
•9/16" cutting capacity to trim and neaten all your hedges and shrubbery
•Wrap-around, over-molded handle ensures comfort at any angle
•Blades measure 22 inches
•Hardened steel blades
•Safety lock protects you and your family from injury
•At only 6.3 lbs., it's light enough for extended work without tiring you out
Wet/Dry Vac
Item # 00917598000P Model # 17598
•Craftsman C3 wet dry vac includes: Vacuum, storage belt, 5 foot hose, 3 dry filters, wet filter, crevice tool, floor brush, and wide nozzle with squeegee (battery not included)
•Works with C3 19.2 volt batteries for convenience and reliability
•Long reaching hose helps you get into tight areas
•Converts into a 100mph blower in a matter of minutes
•Powerful portable suction makes clean-up fast
•Multiple nozzles tailor performance to the job
•Convenient drain port empties quick
•On board storage keeps tools within reach
Hand-Vac
Item # 00911571000P Model # 11571
•Craftsman bagless hand vac includes: Filter, crevice tools and brush attachment (battery not included)
•Lightweight and cordless, it’s easy to maneuver
•Quick change filter swaps out fast
•Empties with the push of a button
•19.2 V motor delivers serious suction
•Built tough for long life
R
radrush
Atlanta, GA
Router
Spiral Saw
Model 11582
Cordless spiral saw with a no-load speed of 22,500 RPM. 1/4 and 1/8 in. collets, spindle lock, and removable auxiliary handle. 1 in. depth-of-cut adjustment. Overmold body and handle for user comfort. Includes auxiliary handle (removable, w/cap), 2 bits, circle guide, wrench, allen key, manual.
◾22, 500 RPM (No Load Speed) – for fast and efficient cutting
◾1/4-in. and 1/8 in. Collets – to accept bits for a variety of applications
◾Spindle lock – for quick bit changes
◾Removable aux. handle – for added control
◾1-in. Depth-of-Cut adjustment – for cutting in various materials
◾Over-mold body and handle
Planer
Model 11584
19.2 volt planer. 10,000 rpm. Adjustable plane depth, chip exhaust and removable dust bag, grooved front shoe design. Automatic surface guard. Capacity: 2 in. Includes 2 blades, edge guide, rabbet guide, blade wrench and dust bag and owners manual.
Paint Sprayer
Model 17597
Handles all paints and stains. Advanced delivery system eliminates the need to dilute paint. Three spray patterns. Quiet.
Caulk Gun
Model 11596
Caulk gun powered by a 19.2 volt Diehard battery. Features a variable speed selector, over-mold grip, all metal plunger rod and on board puncture tool. Over 500 lbs. of force.
Inflator
Item # 00911586000P Model # 11586
•Craftsman C3 19.2 volt cordless inflator includes: Inflator, chucks and 3 nozzles
•Flexible hose gets the right angle
•Comfortable grip is easy to hold
•Maximum of 200 PSI
•Designed to inflate automobile tires, sports balls, beach toys and more
•Backlit digital readout allows preset pressures and will shut off automatically
•Inflates 2 tires on a single charge
•On-board storage keeps chucks within reach
coleman10
Fort Lauderdale, FL
I
Am
Floored
What an incredible, Craftsman garage. Definitely gives me some ideas on how to create some more room in my own space.
BTW, you're also missing the new, LED work light. Since it's available only as part of the 6 tool kit, I'm not sure if that counts or not.
Super Sport
West Michigan
Chemical Sprayer:
Item # 17599 | Model # 17599
•C3 window built into handle - C 3 window illuminates when energy indicator is pressed Lithium Ion battery
How do you like this sprayer? I see they're discontinued now and selling for what I feel is crazy money on Ebay ($100+). I could see it being handy, just not that handy! Do you know what they sold for new?
R
radrush
Atlanta, GA
I like it fine...but...winter is coming on so I don't have anything to spray. I'll give a better review in the spring. One drawback, you flip the switch and the pump runs, you pull the trigger and it sprays, let off the trigger and it stops spraying, but the pump runs all the time unless you turn it off.
R
radrush
Atlanta, GA
The Socket Collection
621 SOCKETS
493 CRAFTSMAN
Chrome --- 1/4", 3/8" and 1/2"-drives
+18 SK
+ 4 Snap-on
+ 3 Proto Professional
+1 Booney
Chrome --- 1/4", 3/8", 1/2"-drives
+48 Craftsman
Impact --- 1/2"-drive
+54 Craftsman Industrial
Impact --- 1/4" and 3/8"-drives
16 Wrench Sockets
-08 12 pt. SAE - 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16 and 3/4
-08 12 pt. MM - 8, 10, 12, 13, 14, 15, 17, 18
Mid-Length Ball Hex Bit Sockets
1/4" and 3/8" drive
-06 pc. Mid-Length Ball Hex Bit Set - SAE - 5/32, 3/16, 7/32, 1/4, 5/16 and 3/8
-06 pc. Mid-Length Ball Hex Bit Set - Metric - 4, 5, 6, 7, 8, 10
8 piece Spark Plug socket set
3/8" drive
-04 06 pt. padded spark plug socket (5/8, 3/4, 13/16, 18mm)
-02 06 pt. padded spark plug flex socket (5/8, 13/16)
1/2" drive
-02 06 pt. padded spark plug socket (5/8, 13/16)
44 piece flex socket set
42 Craftsman sockets
+ 2 SK* sockets
1/4" drive
-08 06 pt. SAE - 3/16, 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16
-12 06 pt. MM - 5, 5.5*, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15*
3/8" drive
-07 06 pt. SAE - 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4
-07 12 pt. SAE - 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4
-10 06 pt. MM - 10, 11, 12, 13, 14, 15, 16, 17, 18, 19
377 piece socket set
353 Craftsman sockets
+16 *SK sockets
+4 **Snap-on socket
+3 ***Proto Professional
+1****Booney
1/4" drive:
Craftsman...socket lengths - shallow 0.87", deep 2"
SK Tool.......socket lengths - shallow 0.87", semi-deep 1.25", deep 2"
-13 06 pt. shallow SAE - 1/8*, 5/32, 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8*
-15 06 pt. shallow MM - 4, 4.5*, 5, 5.5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15*, 16*
-03 08 pt. shallow SAE - 1/4**, 5/16**, 3/8**
-10 12 pt. shallow SAE - 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16
-12 06 pt. deep SAE - 1/8*, 5/32*, 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16
-14 06 pt. deep MM - 4, 4.5*, 5, 5.5*, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15*
-10 12 pt. deep SAE - 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16
3/8" drive:
Craftsman...socket lengths - shallow 0.92/1.20", mid-depth 1.5", deep 2.5"
SK Tool.......socket lengths - shallow 0.92/1.20", deep 1.75/2.5, extra long deep 2.14"
-13 06 pt. shallow SAE - 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1
-17 06 pt. shallow MM - 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22
-06 08 pt. shallow SAE - 1/4, 5/16, 3/8, 7/16, 1/2, 5/8**
-13 12 pt. shallow SAE - 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1
-15 12 pt. shallow MM - 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 21
-09 06 pt. mid-depth SAE - 1/4*, 5/16*, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8
-13 06 pt. mid-depth MM - 6*, 7*, 8*, 9*, 10, 11, 12, 13, 14, 15, 16, 17, 18
-13 06 pt. deep SAE - 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1
-11 06 pt. deep MM - 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19
-11 12 pt. deep SAE - 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1
-13 12 pt. deep MM - 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 21, 22
1/2" drive
-15 06 pt. shallow SAE - 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/8, 1-3/16, 1-1/4
-14 06 pt. shallow MM - 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22
-08 08 pt. shallow SAE - 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 7/8***, 1***
-10 12 pt. shallow SAE - 3/8, 7/16, 1/2, 9/16, 19/32, 5/8, 21/32, 11/16, 3/4, 25/32
-10 12 pt. shallow SAE - 13/16, 7/8, 15/16, 31/32***, 1, 1-1/16, 1-1/8, 1-3/16, 1-1/4, 1-1/2, 1 5/16****
-24 12 pt. shallow MM - 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 32, 36
-11 06 pt. deep SAE - 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/8
-09 06 pt. deep MM - 12, 13, 14, 15, 16, 17, 18, 19, 21
-13 12 pt. deep SAE - 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/8, 1-3/16
-15 12 pt. deep MM - 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 24, 27
20 Crowfoot Wrenches
3/8" drive
-10 pc SAE: 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 1
-10 pc MM: 10, 11,12, 13, 14, 15, 16, 17, 18, 19
62 Torx and Bit sockets:
1/4" drive:
-05 SAE hex bit sockets - 3/16, 7/32, 1/4, 5/16, 3/8
-03 Torx bit sockets - T15, T20, T25
-07 Torx bit sockets - T7, T8, T10, T15, T20, T25, T27 (tamper-proof)
-03 External Torx sockets - E6, E7, E8
-03 Slotted screwdriver bit sockets - 3/16, 7/32, 1/4
-02 Phillips screwdriver bit sockets - #1, #2
3/8" drive:
-06 SAE hex bit sockets - 5/32, 3/16, 7/32, 1/4, 5/16, 3/8
-05 MM hex bit sockets - 4, 5, 6, 7, 8
-04 External Torx sockets - E10, E12, E14, E16
-03 Slotted screwdriver bit sockets - 7/32, 9/32, 3/8
-04 Phillips screwdriver bit sockets - #1, #2, #3, #4
-06 Torx bit sockets - T27, T30, T40, T45, T47, T50
-05 Torx bit sockets - T30, T40, T45, T50, T55 (tamper-proof)
1/2" drive:
-02 SAE hex bit sockets - 9/16, 5/8
-02 Metric hex bit sockets - 14, 17
-02 Torx bit sockets - T55, T60
Impact sockets
1/4" Drive: (Craftsman Industrial - USA)
-09 06 pt. shallow SAE - 3/16, 7/32, 1/4, 9/32, 5/16, 3/8, 7/16, 1/2, 9/16
-09 06 pt. shallow MM - 4, 5.5, 6, 7, 8, 10, 12, 13, 14
3/8" drive (Craftsman Industrial - USA)
-09 06 pt. shallow SAE - 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4
-09 06 pt. shallow MM - 10, 11, 12, 13, 14, 15, 17, 18, 19
-09 06 pt. deep SAE - 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4
-09 06 pt. deep MM - 10, 11, 12, 13, 14, 15, 17, 18, 19
1/2" drive: (Craftsman)
-12 06 pt. shallow SAE - 3/8 thru 1-1/16
-12 06 pt. shallow MM - 12 thru19, 21, 22, 24 and 27
-12 06 pt. deep SAE - 3/8 thru 1-1/16
-12 06 pt. deep MM - 12 thru 19, 21, 22, 24 and 27
R
radrush
Atlanta, GA
The Tool Box
Total Storage Capacity = 32,181 cu. in.
marketed as
CRAFRTSMAN - PROFESSIONAL
Sturdy 26-in. wide Ball-bearing Storage
(items R, S, T, U - 1998 Sears Craftsman Tool catalog - page 5.)
(items F, G, H - 1999 Sears Craftsman Tool catalog - page 10.)
Bottom Roll-Away
•26 in. 8-drawer heavy-duty red/black
•$379.99
•10,663 cu. in. of storage space
•All steel USA construction - exclusive I-Frame® design (holds 50% more stress than flat-sided models)
•Full-extension ball bearing drawer slides / drawers hold up to 75 lbs.
•Overall Dimensions: 26-1/2" W x 18" D x 41-1/4" H
Drawer dimensions:
-1 drawer measures 22-3/8" W x 16-1/2" D x 6-1/8" H
-2 drawers measure 22-3/8" W x 16-1/2" D x 3-1/8" H
-2 drawers measure 22-3/8" W x 16-1/2" D x 2" H
-3 drawers measure 22-3/8" W x 16-1/2" D x 4-1/8" H
•5" x 2" casters combined with caster channels support up to 1000 lbs.
•Weight: 160 lbs.
Intermediate Chest
•26 in. 3-drawer heavy-duty red/black
•$159.99
•3,394 cu. in. of storage space
•All steel USA construction for long-lasting strength and durability
•Overall dimensions: 26-1/2"W x 18D x 13-1/4"H
•Drawer dimensions:
-1 drawer measures 22 3/8" W x 16 3/8" D x 2" H
-1 drawer measures 22 3/8" W x 16 3/8" D x 3 1/8" H
-1 drawer measures 22 3/8" W x 16 3/8" D x 4 1/8" H
•Weighs 61 lbs.
Top Chest
•26 in. 6-drawer heavy-duty red/black
•$289.99
•6,826 cu. in. of storage space
•Full-extension ball bearing drawer slides / drawers hold up to 70 lbs.
•full width cover hinge
•recessed aluminum handles
• Overall dimensions: 26" W x 18" D x 19 3/4" H
•Drawer dimensions:
-5 drawers measure 22 3/8" W x 16 3/8" D x 2" H
•Weight: 102 lbs.
Side Cabinet X2
•15 in. 6-drawer heavy-duty red/black GRIPLATCH®
•$249.99
•5,649 cu. in. of added storage space (X2 = 11,298 cu. in.)
•All steel construction for long-lasting strength and durability
•Full-extension ball-bearing drawer slides / drawers hold up to 70 lbs.
•Overall dimensions: 15-3/4" W x 18" D x 35-1/4" H
•Drawer dimensions:
-1 drawer measures 11-3/4" W x 16-1/2" D x 4-1/8" H
-4 drawers measure 11-3/4" W x 16-1/2" D x 3-1/8" H
-1 drawer measures 11-3/4" W x 16-1/2" D x 12-3/4" H
•Weight: 96 lbs.
total retail cost (back in the day 1998) = $1325.95
(Note: side cabinets are actually more recent China versions with GRIPLATCH®.)
NOTE: 1998 first year of CRAFTSMAN ball-bearing toolbox badge.
Bigbandguy
North Carolina
The training depends on the dog (personality and temperament) and the type of mill (electric or slat). The intricacies of training a dog to run on a mill are many. Not sure I can explain that here.
You started with the right kind of dog. BC's can be trained to do most anything a dog can do in a very short time. Best dogs I have ever had and by far the smartest. It really is like living with a 4 legged extra person in the house.
stioc
SoCal
Very cool. I have a lot of c-man tools, I always found them to be a great bang for the buck. Then again I started my collection back in 2002 or so. What I'm new to are the C3 tools, I have the usual drills/drivers and lights but haven't bought anything else. I was interested in the polisher/buffer but they don't make them anymore. The Nailer looks useful too but kinda pricey and my pneumatic one works just fine and probably lighter too.
Which C3 tools besides the ones I mentioned above would you say you really like and use quite a bit?
coleman10
Fort Lauderdale, FL
You might want to check out the following thread:
Craftsman 19.2v C3 Fans
http://www.garagejournal.com/forum/showthread.php?t=297733
MPOWERD
Picked up a pretty cool vise.
Looks to be an early 1970's made in USA Craftsman No. 506-5181 with 5" jaw.
Found it in a friend's garage. He knows I'm kind of a Craftsman nut and I played with it long enough that he finally up and gave it to me.
Looks like it has a clean up, lube, and paint job coming....
I have one of these vises in equal need of refurbishment. Did you ever get around to working on yours?
R
radrush
Atlanta, GA
Craftsman Professional Pliers
first appeared in the 2004 catalog
Made in USA at Western Forge.
info on WF = https://en.wikipedia.org/wiki/Western_Forge
My Current Inventory:
8".............Slip Joint long-nose Pliers....................................(9-45752)
9".............Offset Arc Joint Long Nose Pliers (aka beak-jaw).....(9-45757)
6 3/4".......Slip Joint Pliers...................................................(9-45760)
9 1/2".......Arc Joint Pliers....................................................(9-45761)
6".............Diagonal Cutting Pliers.........................................(9-45762)
8".............Long Nose Pliers.................................................(9-45763)
9".............Linesman Pliers..................................................(9-45764
7".............Spring-Loaded Wide Jaw Diagonal Cutting Pliers.....(9-45765)
10 1/2"......Arc Joint Pliers...................................................(9-45766)
8".............Spring-Loaded Wide Jaw Diagonal Cutting Pliers.....(9-45767)
8".............Bent Wide Jaw Diagonal Cutting Pliers...................(9-45768)
Inventory also includes SK green handle versions of the following:
11".....Slip Joint Long Nose Pliers....(CM 9-45459)......SKT-17811
11".....Long reach pliers Duckbill.....(CM 9-45487)......SKT-17844
11".....Long reach pliers bent nose...(CM 9-45499).....SKT-17831
11".....Long reach pliers long nose...(CM9-45497)......SKT-17830
Having been produced at the same factory (Western Forge), the SK pliers are, except for branding and handles, identical to the NLA CRAFTSMAN versions.
Pictures below are from the 2010 tool catalog.
TonkaJoe
Southern ON, Canada
I really like those cabinets, they're pretty sharp looking!. I also REALLY like that screen door.. would sure keep the damn mosquitos and horse flies the hell out of my shop in the summer. :thumbup:
R
radrush
Atlanta, GA
Found a nice little socket to add to the socket collection.
Since Craftsman never offered this size socket in 3/8"-drive, I had to get a (vintage) Snap-on.
5/8" socket in 3/8"-drive 8-point / model F-320.
R
radrush
Atlanta, GA
I never go to pawn shops but every once in a long while you can find something kinda good...found a group of 1/4 drive 8-point sockets. Pretty cool.
That brings the collection of mostly Craftsman mixed with a few of S-K, Snap-on, and Proto Professional sockets up to 663.
caseysam
11"..........Long reach pliers bent nose................................(9-45799)
11"..........Long reach pliers long nose.................................(9-45797)
Numbers seem invalid.
I believe they should be 9-45499 and 9-45497.
R
radrush
Atlanta, GA
Fixed it.
Thanks.
R
radrush
Atlanta, GA
Picked up these really sweet SK long reach pliers. The fit and finish of these USA tools has no equal; really nice. The only way these could be better is if they had the red and black handles.
11".....Slip Joint Long Nose Pliers........17811
11".....Long reach pliers Duckbill..........17844
11".....Long reach pliers bent nose.......17831
11".....Long reach pliers long nose.......17830
Having been produced at the same factory (Western Forge), they are, except for branding and handles, identical to the NLA CRAFTSMAN versions. (CRAFTSMAN long-reach pliers pic for reference only.)
Note empty space between the groups of pliers reminds me that I'm still missing 3 tools from the red/black handled pro-collection.
R
radrush
Atlanta, GA
Found an awesome complete 8-piece set of the NLA CRFTSMAN stainless steel screwdrivers. Seriously, I own more drivers than a DIY guy should be legally allowed to own. :lol: But I found these brand new in the original pouch and could not resist. The original owner told me that he bought them and stuck them in a drawer and simply forgot about them. :beer:
R
radrush
Atlanta, GA
Finally completed my set of Craftsman pro red/black handled pliers.
Well almost, due to the lack of availability of the Craftsman branded long reach pliers, I supplement the set with the SK green handled long reach pliers.
prone2xl
MS
The new & improved Craftsman Space
Does anyone know if they still make the red 8 drawer bottom toolbox cabinets anymore ? Feel like all I’m seeing are the 5 drawer ones and want that shallow drawer storage ! Kinda looking at the craftsman edge series personally. Anyone have experience with them?
R
radrush
Atlanta, GA
Nope... never did anything with it. Both the vise and the air compressor have been collecting dust ever since the wife got the cancer and died. But that's nearly 3 years past so I need to get back on it. Some life events can certainly change your outlook on stuff.
