Looks like you've been busy. On the subject of air ride, have you heard anything bad about AirLift? Since they're local to me, I've been leaning that way.
I've only ever heard good things about the air lift air management systems, and are basically the same as accuair, but accuair just beat them to market for leveling suspension. Air lift Dominator air bags also seem to be one of the go-to's for bags, I have their Dominator 2600's on the white truck. Air lift seems to have some cool things built into their system, (auto draining water trap?)and lets you see the air pressure, though I don't really see the point in needing to know the air pressure if the heights are set. if people are setting it up to really handle or something in a sporty car and want to really dial it in, that makes sense, but for a cruiser truck, where it rides comfortable, being able to hit one button and have the ecu raise it all up at once if theres a big pot hole or something, works for me. all this air ride talk makes me want to get the truck out!
Saw horses are all freed up, but as not to want to tie up someone else's stuff, and to make me move a little faster, Im going to try and get it knocked out fairly quick.
20200411_110521 by
Dan Haas, on Flickr
first I wanted to get the majority of the tailpan welded in so theres no big floppy body panels when I pick it up. The side edges of it don't line up because of some changes made, poor planning rather than poor cutting
20200415_175655 by
Dan Haas, on Flickr
A first pass with a roloc just so it didn't bother me having to look at a welded seam while leaving it for a while. Still needs work, but not a million miles off. the tiny little filler piece I made was giving me a hard time since there was some undiscovered old brazing on the backside that just happened to be where I was joining the 3 new pieces to the body, so I called it a night
20200415_195458 by
Dan Haas, on Flickr
and nice to see it looking a little more complete
20200415_201651 by
Dan Haas, on Flickr
Dug out some eye bolts that fit into the body and fender mounts. Shouldn't be too bad, I recruited a buddy for Friday or Saturday and we'll use an engine hoist since this is a big body and after all the back issues ive had and its feeling great the last 6months, I dont want anyone to jack their back up trying to pick it up by hand
20200415_201437 by
Dan Haas, on Flickr
20200415_201432 by
Dan Haas, on Flickr
While I love working on cars, I hate working under them, so while the body's off and the frame is getting cleaned up and painted, I'm going to try and get a gas tank in, run a fuel line up to the firewall, and atleast the brake line going to the rear, maybe even make some exhaust hangers in the places I know the exhaust is going, so when I get to the point of exhaust, it will make life a little easier
Since I dont have a gas tank, and no one repops them, someone sent me a print of the stock tank measurements. Tanks inc makes a handful of 30's chevy tanks that are sort of close, but seem to be off in the dimension between the stock crossmembers that would support the tank. the '71-'72 nova tanks seem to be a lot closer dimensionally to the stock tank, and either way, would require making new mounting straps, cutting out the filler neck, welding it up and repositioning, to the back right corner since the filler neck snakes out to the gas cap on the rear passenger side fender, and the nova tank is at least $100 cheaper, both being from Tanks inc.
https://www.tanksinc.com/index.cfm/...t_id=316/category_id=131/mode=prod/prd316.htm
2020-04-16_06-58-24 by
Dan Haas, on Flickr
