WI/MI Border
- Joined
- Jan 27, 2025
- Messages
- 196
I have some experience with electrical installations, however, please respond as though I have no idea what I'm doing.
I have a new 200a QO main panel upgrade in my home and I want to run 100A to a subpanel in an unattached garage. Yes, I want the full 100a service to the garage, not 90a, not 70a. A new 100a QO DP breaker (for garage feed) is installed in the new main panel. I'm running 50' to the sub panel, in a 24" deep trench, inside conduit. I have no electrical inspection when finished (yes, I'm sure. I've asked the city and the city's building and codes administrator). Regardless, I want to install safely and according to code. And I am not too concerned about cost; I just want it sufficient for a 100a load.
An additional conduit will have ethernet cable. Another 1 1/2" conduit will be installed (empty) for a future solar array (grid tied)
For the 100a feed ONLY...
What gauge and type wire should I use? Aluminum or copper? (Subpanel and main are aluminum lugs.)
I can install grounding rods and wire at the garage, or use the main panels ground. What should I use?
What size conduit is suggested for the suggested feed wires?
