Kaizen,
Keep us updated on how this goes. I did a big remodel on the house last year, and did all the research and even started making samples with the plan of making concrete countertops. Ultimately the scale of the project (plus me doing everything else in the remodel) forced us to take the countertops out of the project, we just got granite instead, it was over 80 sqft of counter.
That being said, I am going to be building a new dinette table that will have a 1" concrete cover to get the look and beauty from the concrete. Kinda like this:
Also doing a small desk nearby in the kitchen.
I played around with single packs and sample quantities of a bunch of the countertop products out there. A few experiences I can add that might prove useful:
1) Cheng book is a very good starter point for getting educated on the scale of the project
2) Cheng has a wide array of products. Most of them seem to be very good, but I wouldn't take for granted without sampling it.
3) Cheng seems to have the nicest array of color dye powders
4) Mixing Cheng's dyes with the regular quickcrete bag mixes (countertop or not) seem to yield a mix that has too much aggregate (regular rocks / pebbles and stuff) and is too gray for my liking. My current strategy will actually be to use Buddy Rhodes Bone White mix. It's a much more expensive bag but also is truly white so it will allow your color to come through better, and it doesn't have all that gravel and stone in it. When you start grinding, you'll find that stone gets uncovered and affects the final look. It really detracts when you add the glass, but what you see is a mixture of the really good looking glass shards, but then also pea gravel (reds / grays / tans).
5) I bought this Seeco wet grinder. It's is awesome and does the job really nicely, addressing the issues brought up above. My samples came out with a really nice finish and sheen when using this. It puts out a lot of water!
http://www.amazon.com/dp/B001KAM3K4/?tag=atomicindus08-20
6) As crazy as it seems, they even have pre-mixed ready to press / dump into a mold, if your scale is small and you aren't doing that much. Shapecrete is the product (
http://www.shapecrete.com/)
7) My samples came out with more bubbles than i would have liked to see, despite a lot of effort put into hammering and vibrating them. I don't think you can really do enough to try and get that air out. I have seen designs for strapping the rod type vibrators to a table, and also HF used to have one of the plate-type vibrators that would have worked well. Unfortunately they don't sell those anymore, but the main idea is you can't do enough here to get the air out. In my opinion, the slurry is pretty easy to pick out and can look bad if you have a lot of holes to fill.
8) HUGE resource for concrete countertops is here:
http://www.concretecountertopinstitute.com/, also has a lot of good products that give you another option other than Cheng and Buddy Rhodes.
