t&g ceiling - **** joints
Boostingaz
Indiana
Thank you!
Herringbone corners much easier than I thought they would be. vI had a 1/4" slot cutting router but with ball bearing guide. Was quick to set depth on a piece of t&g. Adds a step but only a minute or two.
That looks great! I think that is a better solution that a solid miter seam. That is going to look really good all finished. Nice work.
Firebrick43
West central Indiana
I won't disagree with the splice, but a lot of sources specifically say joints not on joists. They want them to float. The end matched I put in a room, the manufacturer was very clear not to joint on joists.
I look out the window at what I've installed for far and can't see **** joints. If I stand under it and look up I can find them. Like a strip wood floor, there are joints.
How would a professional make the mitre joints look their best?
Lay a board down the whole corner of the 45, centered where the boards would meet with a tongue milled into each side.
On the ends of the boards route a groove using a miter coping sled on the router table.
Or do a simple lap joint with the board laid on a 45 with its lap on the bottom and the boards butting into it on top.
Stuart in MN
Minneapolis
Thank you and others for compliments and advice. We're pleased. To many irregularities in the original porch so will be adding a simple cornice. Thinking of shoe mold, pre finished.
I did something similar on my porch although I used a small cove molding, it provides a nice finishing touch. The big box store or lumber yard will have a variety of different moldings to choose from.
billconner
Thousand Islands NYS
Close. Rain may delay me from ripping last board - usually setting up table saw on patio.
Planning on - bought and varnished already - using 3/4 x 1/2 shoe mold as cornice. 18 gauge brads ok?
I know for a floor nail shoe to base board. Think I should nail it to azek trim here, and not ceiling?
billconner
That looks fantastic
Thank you. It looks better on a sunny day, in particular from inside. Never realized how much a porch ceiling can do for living room.
Lots of help from GJ. All azek trim. Real pine t&g - prefinished - and the heringbone corners.
A real top down project other than deck and posts. Roof, trim and headers, ceiling. Next is railing and floor - primarily trying to remove peeling paint from the pre-existing floor Hope to put on a sealer - probably with a color but transparent. Then the skirt.
Codyboy
S.E. TEXAS
Looks really nice.
Idk and not a trim carpenter, but for something overhead , especially outside , I think i would use finish nails instead of brad nails.
Now if all i had was a Brad nailer I would use it.
But I have both and would go with finish.
billconner
Looks really nice.
Interesting. I have more pneumatic nailers than a non-pro in their right mind should have. I have a 15 gauge finish nailer (and a ridiculous supply of SS finish nails) and an 18 gauge brad nailer. I was actually thinking something smaller but brads don't show in house so fine. Up to 2 1/2". And brad nailer is much lighter weight. Not sure brads aren't fine but will think about finish. Thanks for the challenge.
billconner
On stainless, out doors, seems perfect but on my porch stairs - 2 houses now - they naturally back out. Several times a year I get a hammer and reset many of the SS finish nails. Just a consideration.
billconner
Almost all up high. Lights, but need a 4 1/4" hole saw. Of course I have 4 1/2 and 4, and local supply only has Diablo and all mine and mandrel are Milwaukee.
Railings - undecided on design - and skirt. Some floor "refurbishment" for existing. Paint columns (and railings depending).
Getting cold. Snow not too many miles away. Some things - skirt and floor - may have to wait till spring.
mike93lx
Richmond, VA
Try the 4" in some scrap. Might have enough play to work.
billconner
I thought about that. Either 4 or 4 1/2. The part that recesses is a 32nd or 16th over 4. Flange is 5". There are 9 of them.
Since both holes saws had been used in drywall, I was not confident they'd be great for now on pine, so bought a new 4 1/4".
I'll see how it goes tomorrow....
