Teardrop trailer build
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Yeah we figured that out the other night after we put the bedding in when we went out and sat in it for a while. I've also read it's possible to use up all the air in such a small space overnight.
We will leave the vent and at least one window cracked; we did that the other night and were still too hot under the comforter. Supposedly running a small fan to circulate the air also helps with condensation.
Sent from my SCH-I545 using Tapatalk
Even in the coldest weather you will need to do that. I know from experience.
Syberia
Perris, CA
Finished up a few odds and ends...
Made a trim piece out of a piece of 3" roof flashing for the bottom of the trailer. Painted with Rustoleum metallic silver.
Caulked the joint between the wall panels and the trailer frame. It didn't stick out far enough to use trim. It looks a bit like *** in this shot but I went back and cleaned it up as best I could once it started to dry and some of it could be removed without smearing it everywhere.
Put handles on the hatch
And installed racks on each side to use as clothes hangers.
And with that, I think we can call this project complete :)
Syberia
Perris, CA
Quick update, had the trailer weighed and it comes to 1360 lbs with no water in the tank. 34 gallons of water comes to 283 lbs, so a total weight of 1643 lbs. My 4 cyl Tacoma feels it back there a bit but tows it fine.
nmantas
Downriver Detroit
Only 80lb from the HF limit of 1720....hopefully it was a very conservative rating. In any event, for liability purposes its massively better to be under that rating than over.
Syberia
Perris, CA
That weight includes the weight of the frame. The HF trailer has a GVW of about 2,000 lbs, so it's well under. When we're in it, it's probably close, but then the stabilizers are down to take some of the weight anyways.
jabin
SW Ohio
Very nice job and I hope you guys enjoy it for many years.
You may want to double check the bearings on those trailers, (speaking from experience) they're not assembled for critical use. You may even want to carry a completed hub in addition to a spare tire.
Enjoy camping, we love it
Syberia
Perris, CA
Where would I get a spare hub/bearings? You're not the only one to tell me they're **** in these trailers (though I have the small HF enclosed trailer that I've overloaded the **** out of and pulled behind my motorcycle with no issues after a few years).
I might even just replace the bearings once for peace of mind and be done with it, if quality replacements exist.
Spare tire is on my shortlist of things I still need to get.
jabin
SW Ohio
Yes, they are **** but it's held up fine for my limited abuse. It did turn pink once I started storing it outside. I have the folding model and use it to haul bulking items, furniture, quad, mulch etc.
I've overloaded it twice with topsoil and 3" rock. It pushed the fender bolts into the tire. I would recommend flipping the fender bolt to put the threads up rather than toward the tire or redesign the connector,-- trim the extra threads off or something to protect the tire in case of massive bounce or an overload situation.
Even with all the abuse it hasn't failed. All I did was pack the bears with good synthetic high temp grease but I don't use it much on the HWY, especially with a heavy load.
Hope this helps:
https://www.etrailer.com/question-142432.html
Syberia
Perris, CA
1643 lbs with water tank full. Weighed it at a truck scale yesterday.
LXCam
There a trailer supply joint that will have those hubs on Indiana just west of Washington. In the very first industrial complex you come to on the south side of the road.
Looking like you're ready for a trial run, where you going?
Syberia
Perris, CA
Anza Borrego Desert, Blair Valley campground. Heading out tomorrow and will be back Thursday night.
Syberia
Perris, CA
So I read online that Dexter brand 1" hubs will fit the Harbor Freight axles, use standard-sized bearings, and are generally higher quality. I might just end up replacing mine when I get back from the trip. I'll at least keep an eye on them and see if anything feels hotter than usual.
volksnick
Chattanooga, TN
I had read that the bearings come with a grease-like material in them and that they should be cleaned an packed before use. It's like a cosmoline type stuff used to keep them from rusting during shipping. Maybe just cleaning and repacking will suffice, but it's always good to have spares. Places like Northern or Tractor Supply often have quick kits or preloaded hubs and bearings that you can store easily for replacements. If your axle requires special bearing sizes and you plan on going long distances, maybe plan for an axle swap down the road for bearing sizes that you can find at most big box stores.
Syberia
Perris, CA
I've heard that too, but mine had thick black stuff in them that was definitely grease. I'm going to run them as-is for this trip, then I'll probably swap out the hubs.
LXCam
Cool. I'd suggest one mod. Either build a skid plate for the drain plumbing or install unions on it so it can be removed when being towed.
383 240z
Findley Twp. Allegheny Co.
Tear Drop trailers
Who has one? Who wants one? Anybody start building one? Who actually finished? Where you happy? Did you buy plans, or did you wing it?
I'm seriously considering one. They were a dream of mine when I was younger. Now that I'm single again, they are more useable. After tent camping all last week a mattress sounds real nice. Thoughts from the owners/builders out there?
58Yeoman
Central IL
Re: Tear Drop trailers
Funny that you brought this up. We were hitting the garage sales today, and a guy had a really nice 5x10 to tow behind his jeep. He said they started at ~$7500 and went up with options. I figured that he had between 10 and 12 thousand in his. We really liked it, but I don't think that we would use it enough to justify the cost.
TCTeardrop.com
Jack Olsen
Los Angeles
rjacobs
Dallas, TX
Every time I look at tear drops and see how much they cost and how little you get, I am underwhelmed.
You can get a smaller(under 20') bumper pull thats light weight AND has a toilet and a shower... for about the same price as a tear drop.
CTyankee
CT
x 2.....
Heavy Metal Doctor
Mason Dixon Line
They only really appealing advantages to a teardrop is having a real bed to sleep on, more out of the weather, and the possibility of heated / cooled space AND small enough to tow behind just about any vehicle, even ones for which the smallest pop-up or hard-side camper would be too heavy. So, with that in mind, and the fact that I already have a large travel trailer with all the comforts of home, my wife and I have kicked around the idea of buying a teardrop so we can hook it up to our little commuter car and do quick weekend trips out. We want one, just can't justify the expense of ready-made (like a Little Guy brand) and I don't have time to build one 'till some other priorities are behind me.
Randy in Maine
The Beach
Lightweight travel trailers are really popular out there as you don't need a $50K tow vehicle to pull them around. Also look into the fiberglass ones from Scamp, Casita and Oliver. Very popular about everywhere.
A guy down the street from me built his own from plans over a winter and it came out very well. My suggestion would be to start with well built trailer frame. I think he used one from AlumiLite.
LS6 Tommy
Northern NJ
If you want to blow some dough, there' always this:
http://www.cabelas.com/product/FREE...VQrnACh1XtgG9EAYYAyABEgI3p_D_BwE&gclsrc=aw.ds
I saw one at The Glen last fall and almost snarfed my beer when the guy told me how much it was. He seemed to think it was a really good deal...
Tommy
d.mcfarland
Western PA
Know an old individual that has a T@B and uses the hell out of it. No issues she encountered yet.
