The Abrasive Blasting Resource Thread
dkmc
NYS--Upstate in the corn fields
Yes condolences to his family.
People in the Youtube comments saying 'it's an old Quincy'....clearly it's a Saylor Beall.
I'm super interested to hear the report on failure if there is one. Rust? Tank seam weld failure?
Fatigue crack? I'd like to see the inside of the tank bottom.
I'm going to also post this again in GJ so more people see it. Especially the ones that laugh and say 'compressor tanks
NEVER blow up'.
NYS has annual heating boiler inspections for commercial facilities.
The inspector comes in asks the question 'does your boiler have a pressure relief valve, and what is the stamped pressure on it'?
You say '30 PSI' and he holds out his hand and says 'Seventy five dollars'........that's it. Unless you give him reason to
inspect further and 'look for trouble'.....which costs a lot more on your part.
O
OccupantRJ
Eastern North Carolina
Which Blasting Media?
O
OccupantRJ
Blast cabinet questions.
O
OccupantRJ
ScatCat blast cabinet questions.
SouthernIllinois
Thanks for cross-posting this.
I missed this thread when searching before starting that thread.
930dreamer
Amarillo,TX and Stinnett,TX
FB MP, not mine.​
Air compressor trailer​
$400
Listed 12 weeks ago in Albany, OR
Details​
  • Condition
    Used - Fair
As is. Not sure on running condition. Never used it.
ching0n
Without going through the whole thread, anyone running wet setups? I had promising results w/play sand.
O
OccupantRJ
I have not played with wet blasting at my home shop yet. I used a Vapor Hone cabinet in the 70’s at work once. It produced a satin finish that looked nice. I have considered it but can’t decide if it is worth setting up a third cabinet.
Kurtis of Cutting Edge Engineering wet blasting his Franna crane project.
930dreamer
Is this a Quincy clone?
Vintage industrial duty air compressor​
$850
O
OccupantRJ
Questions about building a wood blasting cabinet,
TriumphFan
North Georgia
I'm using Shop Vac with a cyclone separator, and the darn thing trips the breaker after about 2 minutes of bead blasting. The filter is clean. Not sure what could be causing this. You can definitely hear the vacuum work harder once I start blasting.
O
OccupantRJ
Sounds like the density of the “contaminated” air stream increases causing it to work harder, but normally on an internal draft fan the speed of the fan will increase as a clean air flow to it is physically restricted because it no longer has air to grab to make it work hard. In the factory on 14” diameter air conveyors we would adjust either the air intake of the blower or the speed of the fan through adjustable width pulleys until the motor was near it’s maximum amperage draw to get the most work from it but not overload It.
O
OccupantRJ
**** Blast cabinet project.
misterfixit
Kaufman Texas
How much blasting media do I need? I'm going to buy some 80 grit Aluminum Oxide media. I can find it with free delievery in various poundages such as 8, 12,and 19 pound buckets, as well as 50 pounds. Im wondering how much to order?
O
OccupantRJ
I would vote for the 8 or 12 pound in most cases, but I only use the amount in the cabinet that it takes to give the gun a steady load during use. My cabinets have cyclone separators, so there is some nuisance dust loss in the bag house during use. When my gun supply is wanting I pour another dixie cup full into the cabinet. On the cabinets with the tube suction device I have seen cabinets not work well with too much media weight compacting at the pickup point. Basically I run no more media in one than what it takes to make it work.
O
OccupantRJ
Syphon gun issues.
O
OccupantRJ
HF pressure sandblaster modifications.
O
OccupantRJ
Blast cabinet extraction air flow issues.
misterfixit
Kaufman Texas
I'm having trouble with my gun. I bought a Best Tools upgrade gun, I think it's a BNP type.
I also built a metering valve. The instructions with the gun say to screw the oriface in and leave about 4 threads showing. I put a vacuum gauge on at had to screw it all the way in to pull 15mmHg. never got more than that, and unscrewed more than a couple turns vacuum went to about 6. The gun surges, I cant get the abrasive to 'flow smoothly' from the bottom metering valve to the gun. I've tried from 60psi to 100 psi and no change.
Abrasive is 100grit Aluminum oxide. it's dry. Air is dry.
O
OccupantRJ
How about post up a couple pictures of your metering valve setup. The working requirement is a flow of air with abrasive dribbled into it at a relatively constant rate in some manner, how to get there does not really matter as long as it is a reliable feed. I would adjust your gun to the high vacuum and leave it. What I usually see is an air entry port on a home made metering valve too far from the grit drop point. Another thing that can cause issues is too much media in a cabinet that has the metering valve at the bottom of the hopper. People put too much media in it and the weight can compress the lower grit to degrade flow. I would run no more grit than it takes to work properly. A garage owner gave me a HF cabinet because it ticked him off and he was done with it. It had 50 lbs of glass beads in it. I gave away the cabinet to my son and kept a nice supply of abrasive.
Look at the picture and take note of where the ambient air flow would pass across the piled grit coming from above. It enters right at the edge of where the grit piles and takes grit with it as more grit replaces that lost by gravity flow. It is basically a grit carburetor.
misterfixit
Kaufman Texas
Update:
This is the metering valve I built, 1" pipe.
I called the manufacturer of the gun, Best Tool Upgrades . I talked to the owner and explained what was happening. Basically he said I was doing all the right stuff but made 2 suggestions to get it to flow correctly. He said first that he had never tested a metering valve with the intake so close to the tee, and explained they are usually in the middle. He wasn't convinced that was the problem, only a possibility. Second was the orifice being screwed all the way in. I told him that's where I got the most suction on the abrasive line, but he said he wasn't sure it needed that much.
The fix was simply screwing the orifice out leaving about 4 threads showing as per the original instructions. I tried that first since it was the easiest and it cured all the issues. Currently I'm running 60psi to the gun and 100 grit aluminum oxide.
O
OccupantRJ
Update:
Good deal. Whatever works for you.
The diagram of the metering valve I showed is an Empire blasting cabinet design.
This is the real one from Empire.
O
OccupantRJ
On the above metering valve the suction hose push fits into the bore of the valve and can be shoved in to partially block ambient air to fine tune intake air to grit ratio. I have a similar shop built metering valve and use 5/8” heater hose for the suction hose.
930dreamer
I fired up my Clemco cabinet after being gone for 9 months. I did remove the gloves to see if anything was living them, yup a few living spiders. I really need shorter gloves. Well, it stills works great.
930dreamer
This air tank caught my eye. 200 gallon, $400.
O
OccupantRJ
Need more air!
930dreamer
I have T-Rex arms and need a shorter pair of blast cabinet gloves. So gloves are sized by length and cabinet glove flange size? Also I'm short and the foot pedal setup doesn't work for me. This is a spendy option!
O
OccupantRJ
Yes, gloves are available in various lengths and cuff diameters. I used to cut 1-1/2” off the gloves at work to shorten them for the operator and make the cuff stretch over the cuff flange to help it stay in place while the cuff clamps were installed. I would order a pair of gloves, then also order two left spares to make usage work out properly. The left glove generally wears out faster from right handed people holding small parts during blasting. Rodeco Company sold left gloves as singles, but right gloves only in pairs with a left.
O
OccupantRJ
Multiple cabinets question.
O
OccupantRJ
Waterloo blast cabinet.
