Not sure if I posted this already, here's a Clemco at a local surplus yard and they want $500/ too much for the work it needs I think? The reclaimer/filter is rusted out in a few spots etc.
I'm going to check this one out in the morning. No data tags.
The cabinet has good bones, and the steel is 3/16". It funnels down and to the left, not sure it that's a plus, I would bet it's shop made.
Of course, air is usually required for abrasive blasting, so here is a thread on the Volksair compressor engine conversion.
http://www.garagejournal.com/forum/showthread.php?t=32377
What would be the main reason to buy a pressure cabinet setup?
Siphon gun introduces the blast media 1-2" from the tip of the gun.
Pressure pot introduces the media Waaaaay back down the hose at the
mixing Tee.
Media has much more time to accelerate up to the velocity of the air in the
pressure pot design, and is thus much more efficient as the media impacts
the work much harder for a given working air pressure VS the siphon gun.
My Trinco blast Cabinet/Abrasive Separator Rant thread:
http://www.garagejournal.com/forum/showthread.php?p=5793707#post5793707
My 110 cfm compressor for blasting that I bought a couple weekends ago. It is a Gordon Smith 302 Ford monoblock unit. Runs on 4, pumps on the other 4, using a special head on one bank of cylinders. They are very compact units, and were used by a lot of rental companies.
The front needs to be sloped in general to allow one to look downward at an angle to see what you are blasting. Why they chose to just slope that small area is beyond me. Ear plugs would be a requirement with that cabinet, as your ears are between essentially two drum heads with the noise of blasting.
A couple interior pictures of the Pangborn cabinet.
Looking thru the glove holes, it seems like the window does afford good
visibility of the interior. More so than I thought.
However not only does the window "bump in" eat up interior space, but there's also a "box" on the upper back wall that constricts the inside area.
The box is some sort of baffle for dust extraction I think.
And, yes, RJ, there are angle iron rails and even what's left of a cart inside, as is vizable in the pictures. So much debris inside I haven't focused before on what all is in there. Time for a clean out!
The picture on the left with the lighter tan rust shows the "bump ins".
Left side is the window, upper right side is the dust baffle.
Other picture is the work area complete with rails, work cart, some spare parts, rotted gloves, old bees nests (hopefully not occupied) and a ton of other debris.
This cabinet I think was a "sand pot" and I think the media just stayed in the bottom with the dust being drawn off. I don't think it was ever set up as a reclaimer unit. I could be wrong!
Just picked up a snap on YA 3825.... The pickup tube is a single tube... Was thinking of replacing this with a dual pickup tube from TP tools. Is this a useful performance upgrade?
