Picked up a new Victor nitrogen regulator as the enclosed gauges seemed more robust than the other offerings. It’s a million times easier to adjust pressure than the Amazon Chineseium one I had before. Can’t dial in pressure bellow 200psi, but I have two valves and a bleed off on the fill manifold to do that.
I put Milton Blue quick disconnects on all of my nitrogen fill adapters. This makes things way quicker to charge shocks.
My vacuum bleed / feel adapters are the purple Milton quick disconnects
And all of my air fittings used the silver Milton qd’s so everything in the shop is now color coded to match the proper QD.
Did another walkthrough of the new shop space with Jamie and she loves it, so we are moving forward with a purchase.
From this view is 4k sqf, but I’m having it divided so I’ll just be purchasing this end with the windows / garage doors.
This is the view from the dividing line. Just gotta get the realtor to write up the LOI to purchase. Won’t actually be finalized till the developer finishes the building, but that gives me time to sell my house. Not totally sure on the SQF yet as they need to do a survey but should be around 1200, it’s a bit smaller than I was looking for, but the location is ideal and it’s within the budget and will leave me enough funds to cover the build out. I’ll need to have power installed including 3 phase drops, a restroom and or work sink plus small office.
Originally I planned on just epoxy coating the slab and placing the machines on it, however the slab is 12” bellow the exterior grade / door jambs so at a minimum I’ll need a sub floor under the customer area. City most likely would require ramps instead of steps, so thinking a full sub floor is best.
So need to figure out options for flooring as I’ll have the mill, lathe and ski tuning machine on it. Plus it needs to be good for easy wipe up of suspension oils, etc.
Once I have final dimensions from the builder I’ll need to figure out the layout. Idea is to have a service counter / small retail area up front then a full open shop layout so customers can see the workshop space.
This will be just over double my current work area but I’ll still need to be creative and efficient with the layout. At least all of my wood working tools will live at home so that will help.
Oh and here is a view from the trackside beer garden of the space. The beer garden is right next to one of the largest pump tracks in the country and is a super popular post Galbraith ride watering hole for both locals and out of towners visiting bellingham. The city has turned into a major mountain bike destination, so hopefully the demand is there to support the dedicated suspension / ebike motor repair shop and then the ski / snowboard service in the winter months. It’s a bit scary making such a massive capital investment coming from working out of my home garage. All I know is there is no rewards without risk. So here goes jumping in with both feet, sink or swim.
