The Everything 3D Printer Thread
bugnut
Central Ohio
Finished up the insert for the hitch into the utility box. Then had a brainstorm, the stabilizer arms on the 8n drop to the ground not allowing tractor to reverse. Put a couple minutes into sketching a pin to install on the eye of the lift arm and also into the stabilizer, printing overnight will test in the morrow. Looks like the pins is a placebo for a cat 1 lift arm pin.
dscheidt
Not trying to argue either. This is how friendly bets start
Air is a pretty terrible conductor of heat and when I put my plate on the counter, I hold it down. It's definitely in good contact.
Besides, my freezer is so stuffed full of **** that I could even get the plate with any decent size part in there anyway :)
Either way, it works quite quickly and I have countertop next to my printer, while the fridge is two floor away. If the fridge/freezer is working well for you, send it
Put some water between the build plate and the counter. It will fill in the voids caused by asperities on the plate or counter, and is a good conductor of heat.
mike93lx
Richmond, VA
I really don't need it to be any faster. Within a few seconds of holding the build plate on the counter, it's near room temp.
mike93lx
Richmond, VA
Coming off the bedplate, filaments are both Bambu PLA, gray and a blue silk I believe
The lid is the part with the failed corner, it got reprinted
Came out pretty well. Was running a .6 nozzle and .24 layer lines, if I was to do this or something similar again with this decorative of a pattern I would change down to a .4 nozzle to help improve the first layer appearance. It's not a cheap print as material was 666 grams.
I did give it to the wife who promptly broke it...much to my annoyance so I have a piece reprinting right now. There is a slide piece on the end that has a "pin" that has to slide up/around thru a maze pattern to be able to move other pieces, do it in the right sequence etc. She forced it a bit to hard and snapped the slide pin off, shear failure of the print. So I lowered line thickness, upped walls and a pair of them are printing again so I'll stick an extra in the box in case it breaks again.
I will admit...these are kinda neat....I might have to try a couple more
I'd move the large Grey piece to a separate plate and reduce waste probably pretty significantly.
loganb
Omaha, NE
In this case that prime tower in the back right corner was due to printing with PLA support interface to make removing supports easier, once it was past those supports the prime tower stopped so it would've generated that prime tower even if it was on a plate by itself. I am going to rework the layout a bit as the sittings between the decorative "sides" and the main box I think can be a bit different to balance quality vs speed.
PelicanPines
Printing badged Milwaukee M12 battery covers... 4 on the plate... 5 hour print. Accidentally left tree supports on in the G-code... Wondering how that's going to print... Should have simulated the print in the slicer... Doom koff I am ....
They came out great but will reslice one without trees but include "Elephant Foot" elimination settings .
ed_
Maine
For anyone that remembers my post back on Nov 25th I wanted to share a 2 month update on my side hustle.
I'm happy to say that I've netted $170 profit over 35 sales now. Of that $150 has been in the past 30 days so I'm well on the way to my goal of $250 profit a month. I thought the niche I'm in had a low ceiling but it seems that no one was really doing a good job of selling what people wanted. I've been getting a lot of good buyer feedback which seems to be helping build trust and making sales faster.
I only have 4 designs right now but I like having fewer since I only have one printer because it makes inventory easier to manage. My average sale price is $13.19 with an average profit of $5.00 after materials, fees, and shipping. My printer makes about $8-$10 an hour depending on the print.
I may need to come up with a new goal in the next few months.
WildBill
PNW
Sounds like you need either more printers or a faster one.
jeepxj
niche is the key. let the customers tell you what they want. never be above feedback.
Firebrick43
West central Indiana
Build plates for my printer is at least 35 bucks plus a piece. I have tried several different plates, nothing holds up long term like glass, stays flat on big prints, and 30 bucks at the glass shop buys 4 (1/4" 310mm x 330mm) of them cut to the custom size and the even dub the corners and polish the edges for that
Borosilicate glass isn't necessary either. Just plain old 1/4" plate glass. The only other build plate I use is a piece of 1/4" garlolite, aka fiberglass/phenolic board for large ASA/ABS prints that don't stick well to glass without ABS juice which I dont care to use.
And with 4 pieces of glass, just pull a plate out of the printer and slide another in and who cares how long it takes to cool. Spray it with aquanet every 5 or 6 prints, and after 12 prints wash, dry and respray it while another print is printing on another plate. And letting them cool slowly has never failed to release a print.
WildBill
PNW
mmhmm
you need so many it causes local networking issues.
On puny shop wireless mine started doing that after number 5 was added. Fixed it when I got them all wired. They need to look at how security cameras do video, how come I can see 12 wireless 4k cameras spread all over my property, all live, without issue, but can't look at more than 5 printers video without it crapping out.
RichieP_MechE
Near Pittsburgh
QD fittings in PETG for my garage exhaust system
Left is welding fume extraction, right is fiber laser exhaust
Also got a more permanent home for the P1S after it sat under my workbench for a few months. These toolboxes are on sale this month at Lowes for $250, casters are a little rickety but otherwise it's a fine box for the price.
mike93lx
Richmond, VA
Actually looks good in the car
Got a smooth build plate and needed to play around with some settings, but ultimately got this to print
It's really close and looks good. If anything, a little too smooth
Although I think all this messing around is for naught, as my daughter got ahold of a previous iteration and did this
How can I not leave that one in?
She's also working on a Swedish Flag to match the tags sewn on my seats
mike93lx
Richmond, VA
A buddy asked me to help with designing a mezzanine for his shop.
Designed it in fusion and ran off a print for the hell of it
Made some changes and got to this version, which is printing now
I've never done 3D Cad for a project like this, always just 2D. Being able to print it is just cool
ER70S-2
This is interesting. I printed a pile of rectangular templates for a project on my brand new H2D, figuring that they would be square as the printer costs 2K and my old Prusa had no problems printing square objects. I was horrified when I checked the parts with a machinist square. They were not square at all. It was obvious on a 3.5” x 5.5” print. Larger prints were even more off and could easily be seen using a framing square!
So, I ordered the Vision Encoder and then watched a bunch of Youtube vids on it, only to find that nearly everybody evaluated the VE incorrectly. Most people printed a small trinket, calibrated with the VE, and then printed the trinket again. Obviously, these dimwits didn’t see a difference in the prints and came to the conclusion that the VE does nothing. Most figured that the VE would only do something for their printer after several thousand hours of printing. These people don’t understand the point of the VE. The point of the VE is to improve accuracy over long distances in X and Y, not to improve overhangs, VFA, top layers, etc.
So, I devised a test to find out if the VE does anything. I designed a 9”x9”x0.375” test piece and printed one before calibration with the VE and then printed another.
I don’t have a 9” long machinist square, so I had to make one on my mill using its table (which is in mint condition), a screwless vice, and a 123 block. I set it up and locked the vice and 123 block between the quill and the table using the knee crank. The setup was perfectly square and rock solid.
Test setup:
I first checked the edges of each print for straightness on the mill’s table. Out of the eight edges, only a 1.5” long section of one edge could I slip 0.0015” feeler gauge under and this was probable due to shrinkage, uneven cooling, or something like that. I think these results are pretty freaking unbelievable. Consider pre and post VE straightness results the same.
I then checked each corner of each print for squareness. I set each print on the table, one at a time, put four light weights into each bottom window of the print for stability, and then slid the print against the vice/123 block and measured the gap with feeler gauges.
Pre-VE results:
I measured from 0.0075”-0.014” on the pre-VE print. 0.014” is too much as far as I’m concerned and for what I want to use the H2D for. This is what 0.014” out of square looks like on a 9” long part. You'll want to view these images full-size. Look at the huge gap on the bottom of the vertical edge!
Post-VE results:
I measured from 0.0015”-0.002” on the post-VE print. I don’t know about you, but I think that's pretty incredible for a 9” long object if you ask me. I should mention that both prints were done with the left nozzle which may be slightly less precise than the right nozzle since it moves up and down, although I have not read anything definitive on this yet.
This is what 0.002” out of square looks like.
Summary: The H2D (and probably the H2S, also) can be extremely accurate, but you have to shell out another $100 to unlock its full potential. If you want to make functional prints that fit together or if you want to print templates or other layout tools, the VE is definitely worth it.
Edit: I forgot to mention that the pre-VE print was printed with a shrinkage rate set in the filament profile, so the length of each side of the print was very accurate and within a few thousandths. After cal'ing with the VE, parts began printing slightly small, so I had to calculate a new shrinkage rate. This was unexpected, but easy enough to fix. If you run a VE cal, check dimensions again if you already had shrinkage dialed in.
PelicanPines
Grumble grumble grumble... Really need to get a filament sensor on the big printer. Luckily I only wasted 15 minutes into the print.
My flashforge 5m pro comes with one... That ships... DISABLED... Thankfully I caught the oopsy and was able to cycle through a filament runout and swap.
lovetap
the last frontier
I have this funky European style sliding door, works really nice but it has eight sort of vault style door closures and as I got the door second hand a few were broken. I haven't had luck finding the closures in the US, so as I'm learning Fusion I modeled them up to have them milled. Printed a test piece out of PETG and so far they work, wonder how long they will last.
dscheidt
it gets HARD to make names after the first 10.
In the IT world, there's a concept of computer systems as either pet or cattle -- are they a special snowflake or interchangeable? Having stuff that can be easily duplicated, destroyed, recreated, etc by automation makes running it cheaper, faster, more reliable, and is basically required where the scale of operartions gets big enough. Pets have names, cattle have IDs, usually self-describing. Manufacturing cells can work the same way. You're at that scale, I think.
burger
Erf
Things always turn out better when you plan ahead! Proper planning prevents piss poor performance
jeepxj
instructions unclear. got pet cow.
kaymccampbell
Upstate New York
Then there's the worst of both worlds method. I used to name server herds like this when building datacenters.
Florg23Blimf
Glipt45Trubi
Jumbf92Spalp
And don't forget the _SR, _JR, _III, etc for special clusters.
It makes both the lay person and the IT pro unhappy, and that makes me overjoyed. It all had meaning, you just needed the secret decoder ring. I heard a story that one of my acquaintances walked into a datacenter I had long left behind, looked around, and said, Kay's been here.
PelicanPines
Florg23Blimf
Glipt45Trubi
Jumbf92Spalp
I was simply...
Mo
Larry
Curly
Damon L.
SE Minnesota
I have a set of T-handle wrenches. They came in an odd rack that doesn't really work with any of my other tool storage. I decided to separate the sets (metric, SAE, torx), and make racks for them. Did them with a French cleat for hanging, but they will stand on their own as well. I also made the labels big for easy ID.
Full set. I would have paused the print and switched filaments for the labels, but this is for my personal consumption, and I am fine with the sharpie.
I did upload these files to Nexprint. They are awaiting approval.
Designed in SolidWorks for those wondering.
Model A Fan
NW Washington
What is the general consensus on AliExpress filament? I have been looking for "generic" filament for Gridfinity/Skadis/Multiboard prints and don't want to use up all of my Bambu filament because replacing it is more costly when its not on special (Black Friday is a great sale, otherwise you have to spend $160+ to get the good deals right now). AliExpress has 10kg for $80ish currently and I'm planning on using it for just structural things, not any kind of print that needs to be "pretty".
The brand is Kingroon or Sunlu it seems. Google says Kingroon is rebranded Sunlu (or vice versa). Does anyone here any any input as far as quality goes? Even with a few potential failed prints, the cost puts me ahead on the purchase over buying other brands.
