emeraldcoupe
the 3x5 foot embroidered American Flag (Made in China)
that is just wrong on so many levels
if u go to lowes u can get the kobalt ones.
The 20- and 23MM sockets would be unlikely to be used, since there are no standard metric hex fasteners in these sizes. The 16- and 18MM sockets would be used on DIN standard nuts (10MM and 12MM, respectively) but ISO and JIS hexes are included in this set.
16MM is only .005 larger than 5/8", so an American wrench could substitute, although a little tight.
I once needed an 18MM wrench, and bought a combination wrench off Ebay. Since this is a DIN hex size, they should be available online somewhere.
Those pry bars recently changed from Made in China to Made in India and the quality is waaaay down now. I bought the set made in China probably 10 years ago and have used and abused them extensively and they haven't let me down. What ***** is if one does ever fail, they'll give me these new, Indian bars.
On this. I have a set that is about that old and have not had any problems.....MASSIVE PASS (after a simple fix) : I got this spray gun:
http://www.harborfreight.com/20-oz-high-volume-low-pressure-gravity-feed-spray-gun-47016.html
and at first, I couldn't figure out how to stop it from leaking air. I thought it was the air inlet stem, as i could feel air coming from there. But that wasn't it, it was the air volume adjustment valve. I unscrewed it and noticed they tried some thread sealant but it got pushed up and didn't seal the threads. I re-sealed it with some teflon tape and the leak was no longer.
so yesterday, i decided to test it out and spray my shutters. i've been renovating my living area and i wanted the shutters to match the new color of the walls. I diluted the latex paint with 20% water and started spraying. first some testing on cardboard and scrap wood i had around... very easy to control and figured out how i wanted to set all the adjustments like air flow, fan pattern, paint flow, etc. then started to spray the shutters.... wow! for an amateur i can't believe the paint came out so beautifully! the atomization of the paint is incredible and results were amazing. even though there were a few spots i messed up, i just sprayed over them again and you can't tell i had messed up there. there's no way that any bristle or foam brush or roller could lay down such a smooth finish. i'm almost convinced that i should always spray the paint instead of using rollers or brushes.
i was using this with my tiny pancake compressor and it had the motor working pretty hard to keep up. so next time i'll probably use my 33gal compressor instead. but for $10 (bought with coupon), i'm very impressed how well this little thing works. i'm starting to think about spraying polyurethane with this on my bar counter top and other things around the house...
i was always under the impression you couldnt spray latex paint unless you used an airless sprayer , learn some thing new every day ..MASSIVE PASS (after a simple fix) : I got this spray gun:
an hour of spraying with an airless sprayer you would have gone though gallons and gallons of paint , maybe it's just a volume issue ..I've heard that too... but i never let other people from preventing me from trying unconventional things. I had to dilute the latex paint by 20% with water though.. and even then after an hour of spraying i had to add a little more water. I'm no pro... i don't know what long term affects my method will have on the finish but so far it's really good and shows no signs of problems
I know its been mentioned, but I will +1 that the green handled roto head 3/8 drive ratchet is great. Can't stop using it. PASS
My orange polisher works fine, but sounds like a bunch of marbles rattling in something. $20 and it works but noisy is fine with me.
Next thing I'll hear is that its "not as good as" the Flex.
ok, i've tried the search and i've scrolled for awhile, and can't find anything on the portable metal cutting bandsaw.... does anyone have one of these (about $79)?? and if so, is it a pass or fail??
68427 Impacting air ratchet - PASS
http://www.harborfreight.com/12-professional-impacting-air-ratchet-wrench-68427.html
I wanted a 3/8, but found a new 1/2" on ebay for $39 shipped. Arrived today and I have only tried half a dozen nuts/bolts at a friends shop, but it works well and appears well made.
Real impact action, some other brands have clutch release type mechanism that reduces kick, but doesn't hit like an impact. This one has no kick and hits like an impact.
Not a Hammerhead with 200 ftlbs that will take off lugs and crank bolts, but worked fine up to about a 15mm nut, and handled larger ones with some manual assist (release the triggle and use it like a regular ratchet), and once broken loose its fast. Maybe too powerful to use on smaller than a M10, but I don't have a good feel for the throttle.
Direction change is a little clunky, push down on a selector and rotate, and it is kind of heavy, which is both good and bad.
I've tried twice to get a tubing notcher that works from HF, as much as I want it to work for some reason both of them had an issue with the threaded portion for the hole saw and would not run true.
So HF Tubing Notcher = Fail.
So I got the tie down two piece strap I'm 99% sure i did the strap right but it's got so much extra when not hooked to anything
http://www.harborfreight.com/automo...ns/2-inch-x-20-ft-ratchet-tie-down-47764.html
Are you talking about the tail/extra strap that is left after the load is tightened down?So I got the tie down two piece strap I'm 99% sure i did the strap right but it's got so much extra when not hooked to anything
98187 - Quick-Connect Compression Tester
Major FAIL! Improper design.
I've heard its bad cause it leaks or something before, but isn't it typical to have the check valve at or near the gauge?
A few points I was told;
Always use a fully charged battery, usually with a charger still on it.
Always do the same number of rotations per cylinder, about 5 is what I do.
Always check a warm engine.
Absolute numbers may vary from one gauge to another, what is most important is cylinder to cylinder with the same gauge.
If so what I do is run the ratchet strap up so it is almost starting to tighten against the load. At this point I gather the extra strap and fold it up from the end into a folded package that is about 12" long. Just fold the 12" sections over on themselves. Then I slip that package under the strap so that it is between the strap and the load. When the strap is tightened down it traps the extra folded strap up against the load, under the strap. Don't know if that made any sense at all.
Now, if I forget or for some reason can't do the above process I will do the fold up the extra strap thing and then fasten the folded strap to the main strap after it's tightened down using these bungees with toggle balls.
Bungee cord with toggle balls
