T VETTE
Nice work!
Not a bad one but still not good and since the bars made huge difference, I wanted to swap out the stem too. The old style expansion plug was the problem and Specialized has updated them. I Picked up one when I got the stem. This is a mountain bike stem and is way overkill. Even though it looks huge there is on 1-2 grams difference for the stock setup.
Well I had some time yesterday and decided to rebuild the shocks. One thing lead to another and I stripped the whole suspension off the car for a clean/lube. Rear pivot pins were sticky and the outer bolts were too tight.
Pulled apart the shocks and used my drill with some 000 steel wool to polish the shafts. inspected all the bushings and refilled with shock oil. The bottom was rubbing on the caps so I clearanced it and man are they smooth now.
Made sure everything move freely with the shocks off. Reassembled in outermost mounts, then set ride height, camber and caster.
I made my own tire balancer and ride height gage. Will have some pics in the next couple days.
. New off road tires glued up and man do they hook-up. I was launching it 10+ feet up the hill over a trail with the kid. I also ebayed a complete team chassis with no electronics for all the hopup parts and spares.
A friend had given me a motorcycle battery of the kids power wheel but it was too big, but the drill battery would fit perfect.
If it is to crazy with the on/off style switch, I will have to figure some way to mount it.
This weekend I moved my compressor outside and ran the electrical and air hose. It’s nothing special but it gets the job done. One thing is that it is stupid loud and takes up a fair share of space. I got the box as scrape from work. It is weather tight and vented. The steel is around 10 gage. To start I leveled the area with pavers and set the box in place, all 100+ lb’s of it. Then I cut an old 2 inch pipe and a stub of PVC. I wanted the connection to the house to be a slip fit. This was if something moves it won’t hurt the house. I already had most of the hose in place, so I just added another line outside. There was already a dedicated outlet for the compressor that I moved up and installed a switch in it. This will control the compressor from inside and give me a power source for the bench that I am going to build. I was going to put a plug, but decided to just wire it directly. Too bad it’s on 115v and not 230.
Action shots to come
Hi Sean
I use Drumstix. They come with 3 but I find that one works best.
A clean crescent wrench works too.
http://morningstartools.com/Pages/DrumstixIII.aspx
I just checked and they are no longer for sale because Paul died this weekend.![]()
Anyway he was burning out and generally having way too much fun.
HaHa
It was handling like **** anyway.
When we got home I striped the shocks and rebuilt them, but the seals where leaking and sticking. Tried to get new seals, but ended up just ordering new shocks and a metal gear servo.
the last 5 months it has been just barely hanging on. Swung by the hobby town and picked up the pieces yesterday.
I pulled it apart for a clean and lube. I also polished the brass bushings.
It was built with old wood and is taking the weather in stride. The vise I do kinda feel bad about.
I have a lead on another mb8800 for my inside bench.
Sweet!
