NoahG
Detroit, MI
So I need your thoughts,
I’m debating between the M12 ratchet or the M12 right angle impact. Could the M12
ratchet, with the right bits of course, drive 3” screws if I wanted it to? I’m trying to avoid buying two tools and I think the ratchet has more utility for my needs.
rick carpenter
Huntsville, East Texas
All decent electric chainsaws are highly impressive, courtesy of their torque. Don't even bother wearing chaps...they won't bind it.
I think that's the old wisdom that I always thought was right on track. The youtube vids I've seen show chaps stopping electric saws. It would be worth checking out via a safety experts rather than relying on youtube though.
pbon
I don’t think the M12 ratchet would be good for driving 3” screws. It’s not an impact, has very modest torque, and drives very slowly.
Farmall450
Marengo, Illinois
That is per Stihl USA. It would be interesting to see if they still recommend wearing them in the manual.
techieman33
Kansas
I doubt it, but I have everything I need to give it a shot tomorrow afternoon, I'll let you know what happens.
DFB
Southern VT/Western Mass
No...the ratchet would just stall in my opinion. And I'm not even going to try to find out.:lol_hitti
I have both the RA impact and also the M12 RA drill. The drill will sink many screws easily too.
Caparris
Greensboro, NC
I doubt the ratchet could drive 3" screws either.. maybe the impact one? Not sure, never tried one. But I doubt the regular one could
tff
Greer, SC
Jumping on to this thread. (Milwaukee) Impact Drivers vs Impact Wrenches... which is the better tool for loosening (mainly) automotive things (lug nuts, other bolts around the car)? I'm thinking the 3/8" Stubby M12 FUEL is the way to go?
Or is getting an impact driver good for car stuff and in the end more versatile???
Caparris
Greensboro, NC
For car stuff I'd get the 3/8 M12 stubby. It's borderline on lug nuts in my experience. I've had some it took right off and some it didn't.. though the ones it didn't take off required a special socket to turn the lug nuts, then you used another socket on the end of it, so I'm sure it was losing some torque because of that. It ended up being impact wrench-->18mm socket-->lug nut key'd socket-->lug nuts where normally you'd just have the socket going right on the lug nuts
Still... M12 stubby is hard to beat
If you want something that you are SURE will take them off, the mid-torque M18 is a good option, but obviously bigger/heavier
Black300zx
Elkton, Md
Impact driver is best for smaller lag bolts, deck screws, etc. I was able to get it to crack loose a lug nut after a few seconds of hammering, but that's definitely not its intended use. I plan to use it on low settings for small interior/engine bay fasteners.
Based on the ability of my 1/4 hex fuel impact driver to crack loose a lugnut torqued to 110lbft, I sure hope that the M12 stubby impact WRENCH would be able to reliably knock off most lugnuts as long as they aren't rusted or siezed up. (It's rated for 2.5x the torque).
I'd say both have their place in your automotive toolbox.
Fix Until Broke
SE Wisconsin
I just tried this for fun with my 2456 1/4" drive M12 Non Fuel Ratchet.
Only issue I had (besides the bit falling out :)) was that I was using phillips screws and if I pushed down too hard, the ratchet would "skip". If I pushed lighter, it drove them fine - no shortage of power from the tool.
Video of this here - nevermind the mess in my basement...
techieman33
Kansas
Don’t know what magic trick you used, but I couldn’t get mine to put more than a couple threads in before it stopped.
kctyphoon
Jersey/Staten Island
Gotta be honest - i dont think i realized just how small the newer m18 hammer drill and impact is.. amazing.. took em out to set up the one key on everything..
Cable cutters are impressive..
I might be cheating on Milwaukee a little w/ Greenlee (makita). I’m gonna try to get their cordless inline bolt cutters. If milwaukee makes a set - this is the style i imagine they will release. Check these things out.. $1400... ETS12’s.
M18 to Makita adapter is $20.. i already looked :)
rick carpenter
I've got an MS170 and Labonville chaps that are a few years old. Everything I read when I bought them said chaps wouldn't stop an electric saw. That was then I guess. I don't know how any mfr could sell an electric saw if chaps couldn't protect the user, so it must be OK? Dunno, but I have that old warning stuck in my head.
malbojah
Cape Cod, MA
Well the addiction has finally started after the clerk at HD spent about 20 minutes searching for where in the overhead storage this kit was placed :bounce:
M12 Fuel Hammer Drill/Driver, Impact, charger, 2 batteries and a packout case for $199 out the door in tax free Delaware
Out of curiosity, what size batteries did this setup come with? Same as 2598-22 (1-2a, 1-4a)?
Edit: found a store that had some left. Comes with 2- 2A batteries
kctyphoon
Just noticing, the cable cutters are not a “Fuel” tool.. wonder why.. The second trigger is only a pressure relief switch. I assume theres a spring inside or a vacuum chamber forcing the jaws to open once the pressure is taken off.
Some carbide blades might be in order for the sawzall, but i just handed over 5 pages of tool requests so those can wait. All in, i now have 8 brand new m18 batteries being kept ON the truck. Much more than i need, but insurance against thieves. All the 9.0 batteries that came with our light lowers have gone MIA apparently. Hopefully at least on a truck somewhere, but i doubt it.
Not pictured is the new Fuel Lineman impact, and M18 Chainsaw. Hopefully a new search light and m18 rover will join the party.
polexican23
burbs-Illinois
man those things would have made stealin...er i mean longterm borrowing bikes as a kid a lot easier.
Black300zx
Elkton, Md
Yup, 2x 2.0s. There also was (maybe still is?) an alternate version of the kit that replaced a 2.0 with a 4.0 but downgraded the packout case to a soft bag for $230. My coworker chose to go that route.
buddylee1998
My wife wants the cordless backpack vac for work-she cleans apartment hallways. Any opinions/reviews on 0885-20? I have plenty of 5.0 batteries she can use as I bought a few tool/battery kits.
Also, what is the best price we have seen on it?
pp1
I own the backpack vacuum. Bought it used off eBay for $250, I use it with a 9.0 battery. Able to do the entire house. Love the power and convenience. My wife also uses it. She says it's heavy but not too bad once it's on her back.
Don't have a Dyson to compare it to, but I'm sure it has more power with a larger battery (e.g. 12Ah)
It's also really quiet on the low setting. Usually the low setting is all we use too.
PelicanPines
Is it me or are the newly announced M12 tools, as they get released, priced way more than they should be??? Yea I know they announced some of the MSRPs during the tool show... but come on... No way I'm spending $230 bare tool price for a die grinder... I bought the $20 adapter off ebay to convert my M12 polisher into a die grinder instead.
p90puma
Seattle pv. Toronto
Link to adapter?
malbojah
Cape Cod, MA
Well, I started drinking the kool-aid today, picked up the 3/8 stubby and the grease gun. Still have to decide on batteries. Still want to do a drill / driver combo, angle grinder, and maybe the 3/8 ratchet. This will be replacing a Porter Cable setup that has served me well for years, but with no new tools coming out from them it was time to make a switch.
takai
Melbourne
Have the BlackFriday deals been announced yet? Back in the US for Thanksgiving and thinking about picking some stuff up.
WhoWhatNow
Collegeville, PA
$165 for the bare tool at Acme. Available as a pre-order. There is a $15 off $150 coupon which may work today as well.
https://www.acmetools.com/shop/tools/milwaukee-2485-20
https://www.acmetools.com/shop/tools/promotions#HEAVYDUTY
jmhinkle
Portland, OR
Present for my Dad. He has to repair copper pipes yearly on his childhood home and summer property every year when he opens it up.
may0naise
Arizona
Home Depot likes to keep their add pretty close to the vest. I don't expect you to see it until 1-2 weeks b4 black Friday.
PelicanPines
