A couple of old radios, with a small bookshelf system and an iPod...
We're gonna need some more pictures of this . . . .
Jim
What are you looking to see?
Maybe where the ipod is coming in.
Did you gut the radio and put a boom box in there?
TThis is the Zenith table top. I removed it from its case and trimmed the bottom of the face to fit.
Toilet seat!
Toilet seat!![]()
I started cutting the notches to the line first....then around the outside....I used a cut-off wheel on a Dremel tool....
One side down....
Then the other side....
To my surprise it fit the first time! (with just a slight trim)
Worked like a boss....
A little bit of finish filing, I saved (at least) $10 bucks
I came across a pair of FREE cast iron table saw extensions on the weekend. I used them for making welding setup squares based on the ones available from Fireball Tools:
WOW! Those came out great! Really nice work.
Those are fantastic!
you welded them ?
or are they brazed ?
20170415_162723 by Laine Olson, on Flickr
20170322_100127 by Laine Olson, on Flickr
20170322_100138 by Laine Olson, on Flickr
20170415_162434 by Laine Olson, on Flickr
20170401_101852 by Laine Olson, on FlickrIve always liked that TV stand idea...
Homebody. Great repurpose. Need a better pic of the bar area.
20140622_142431 by Laine Olson, on Flickr
20141031_102009 by Laine Olson, on Flickr
20160308_101808 by Laine Olson, on Flickr
20160308_103025 by Laine Olson, on Flickr
20170415_164128 by Laine Olson, on Flickr
20170415_164157 by Laine Olson, on Flickr
20141031_115750 by Laine Olson, on Flickr
20141031_120717 by Laine Olson, on Flickr
20141031_115624 by Laine Olson, on FlickrI came across a pair of FREE cast iron table saw extensions on the weekend. I used them for making welding setup squares based on the ones available from Fireball Tools:
https://fireballtool.com/
Great job on the set up angles.
