Above 1200 Sq/FT The Salvage Garage
xtremek
St. Johns, Mi
^ Dang, cheap out on our boy. For as much "fun" as he has, multiply that by 10 times per month. $59.99 a month and you get all the drama and action anyone can hope for.
jpmmilner
“You can’t fool me... there’s no a-such thing as a sanity clause!” -Marx brothers.
Strouty
Southern Maine
Please stop. ;)
Last night I got Perk plumbed enough to hopefully get the knuckle boom moved to the final location. I need to get some hydraulic fluid today, then I might try and shuffle things tonight, but I am leaning towards Saturday, it should be warmer then and I can get help in the daylight.
Strouty
Southern Maine
We went for it tonight, Perk functioned under its own hydraulic power, we unbolted the boom and shuffled it away from the cab about 8”, now we have too much clearance, but I will wait for final adjustments until after I get the larger 100 gallon fuel tank installed, then we can squeeze the boom up tight to the tank. Still need to do some plumbing, but at least we know it functions.
7dfc58d3df0b54b8ff10c0d56f0502a7.jpg8912eb180f7dee88690496abc3aa7830.jpg7b9e12e22fb2b53c15c3217be929cd6d.jpg7a6021c08840fe160192c62783d9977d.jpgbe3fa6fbf4d320189adfb61cadb5d354.jpgb062b962e49448ff574741f6a946865e.jpg
Strouty
Southern Maine
It was actually not too bad, there is a light that is burned out, once I change that, it will be much better. I was just excited to have the knuckle boom all folded up. Even though it functions, I still have a ton of stuff to button up and rework. At least I am on track to have it fully functional by spring.
Strouty
Southern Maine
Thanks guys, I am over at the SG now, going to try and dig out the Cascadia so I can get a fuel tank off. Once I know where the fuel tank is going, everything else falls into place for the layout of Perk. I bought some hose and fittings, should be able to get things all laid out this weekend, then I can start building brackets and dealing with final hose design.
Here are some daylight shots of Perk.
8b6d61947ef4b307e2c9da8950a1e274.jpg0c666d5800f2c4064e60724858ef4935.jpg85ba05a5da6899ff3045a8b6d65263ca.jpgf024634d6f46055ae7737eb501d2a73d.jpgd57cccc9f6c0e2b8f07a2a2872709688.jpgce35a9c8279e06c437245ae59daac603.jpg468c2df4dc59f1fa517f90250a0251b4.jpg
Strouty
Southern Maine
Got the Cascadia pulled out, it was a bit frozen in, took a lot more effort than I thought.
e604e6e11e7d070a6fe61ad3590ad64c.jpga0b3555e10e6b36ca5e56cc87852a4ac.jpg9e22d959a858341dde88c82953bc6673.jpg
I just got the fuel tanks out, need to trim a bit more of the old tank straps, then I can put the Cascadia back, the more I look at the mirrors, the more I think they may be useful on either Perk or maybe even OMO. I am not taking them off yet, but I will once I get a few more loose ends cleaned up, probably sometime in 2021. ;)
e604e6e11e7d070a6fe61ad3590ad64c.jpg8ecf8b98acd7f82a8e371411e36a2714.jpg089748a4c4fdaefded2fdb40952a8334.jpg5f377260d23cc92ff3180ad240de1065.jpg12434038286d044f8d4b414333163690.jpg
Strouty
Southern Maine
I took both tanks off, but only one is going on Perk, it will replace the smaller one. Hopefully they are the same diameter, looked like it, but you can never tell until you actually try and bolt them up. I will end up with 100 gallon tank instead of a 60, passenger side only.
Strouty
Southern Maine
Pines, those lines are temporary, just to get it located, I have to mount the tank, mount the cooler, mount the air dryer, and I am sure there will be other things to do, once I have established where things are going, I will start making lines to fit the permanent locations.
macgyver37
Pittsburg, Kansas
Run and tape or even string or rope around both tanks to see if they are actually the same diameter before you go hoisting it up there to try and mount it. Might save some aggravation.
I am running a reefer tank on my old DT and I found out the hard way they made a few different diameters of those.
Strouty
Southern Maine
Mac, that would totally ruin the surprise though. ;) even if it is a different diameter, I am still using it, I really want to have 100 gallons of fuel, especially with the knuckle boom.
Never useless Pines, you excel at spreadsheets, see what I did there?
Strouty
Southern Maine
Today I am gathering more stuff to bring to TH, it is a balancing act, don’t want to take too much stuff, don’t want to screw myself over at the SG, so far I am doing different types of projects, as soon as they overlap, I might be in trouble tool wise. I am going to need a few more travel boxes so I can have some of the tools and supplies loaded up, electrical/wiring stuff will definitely be one of the boxes. No point in buying duplicates, will just have to be cautious of what I am planning on doing at each location.
Strouty
Southern Maine
Loaded two trucks, now ready to get lunch, then unload things at TH. I have Clark situated so I can remove the forks, then get to the mast ram, so it can be repaired, I want it working right for the spring.
shortykorte
Tallahassee, Fl
Blasphemy. Throw caution to the wind. More tools!!!!!
Shorty Korte
Always remember quality in QST
