Above 1200 Sq/FT The Salvage Garage
Strouty
Southern Maine
Believe it or not, we have issues on hot days with bees way up the towers. They follow the hot steel and will end up 500 feet or more, I hate bees more than towers.
My eye is almost halfway open now, hopefully tomorrow it will be even better. I did climb, but just to unhook the crane while everybody was doing something productive, anytime I strain my face, it feels like I am ripping things apart, so I am trying not to do any really heavy lifting.
We got the bottom 130 feet of the tower up today, will have it finished tomorrow, then it is all detail work from there.
OccupantRJ
Eastern North Carolina
A coworker on construction, who also kept the Grifton NC tower painted and relamped told me once when I asked him about being up there, “anything bigger than your feet is wasted”.
Jackpod
Tonopah Arizona
The tower pics are awesome, back in the early 70's I did a little tower work but never more than 100 ft. couldn't handle any higher then and struggle with my roof now
Hats off to you for 1500+
Hope the surgery heals quickly
shortykorte
Tallahassee, Fl
Hope all heals well. My bout was similar to Gerard’s. A favor please. Please warn us before posting pics of the Tampa triplets
Strouty
Southern Maine
I wouldn't do that to anyone. ;)
Things are healing well, but the eyelid appears to be a permanent pucker, not too happy about it and will be discussing things with the surgeon on Monday when I go to get the stitches out. I can live with the scar and the loss of part of my eyebrow, but when my eyelid is permanently deformed, that is where I draw the line. I can see part of it in my peripheral vision and it will drive me bonkers.
Strouty
Southern Maine
My body is beaten, due to the surgery, I wasn’t supposed to take any Advil for a bit, until I stopped taking it for a week, I had no idea how much it helped. I started taking it again this morning.
86turbodsl
Yeah that eyelid thing would bother me too. Gotta get that fixed. Nice progress on the tower. Can you get cranes that go higher than 130ft? Seems like a lot of boom to be portable.
Strouty
Southern Maine
This crane has 197’ of hydraulic boom, then it has more jib. Around here the largest over the road crane is about 300’. Usually we set a stub, then use a gin pole and skid winch to put the rest up, but we do not have a good enough crew for that anymore.
Tower is all up, just need to do final tension of the wires, we ran out of ambition, I am still here packing up tools and equipment, most of it is mine and no one knows where it goes, so I get to put it away. The tower looks taller, but they are all 180’ tall.
southalabama
Brewton AL
If you get cut on again consult a cosmetic plastic surgeon. Some surgeons are not as concerned with the finish just the end result, ie removal.
I had some asphalt burn marks around my eye removed. First time I woke up with my eye swollen and ointment in my eye I freaked a little. They didn't tell me that would happen. I thought I was blind but the plastic surgeon moved the scar up into the eye lid and natural creases. He hid it well.
jack stand
Lakes Region Maine
Are these your towers that you lease space on?
Looks like a spiderweb of guy wires there unless it just the pic throwing things off. Glad your head is healing up.
Strouty
Southern Maine
Two of the towers are ours, the third is the enemy’s (self supporting tower) and it will have to be taken down next year, we canceled their land lease and have essentially taken all the customers. Been a fun fight, David and Goliath type of deal, they have 40k sites all over the world and have about 70 billion in capital, little old me took them out.
As for the tension, we read it with a dynamometer, a really rugged fish scale, and the lower wires (3/4” wires) will be about 7500 pounds tension and the upper wires (7/8” wires) will be about 12,000 pounds.
Strouty
Southern Maine
Thanks 1/2 Cup, I am just glad to finally have it vertical.
Need to get a few things done at the shop tomorrow, the the GF needs some help at her mother's old house (under contract), so I think that will take up the day for me. Monday is essentially back to the grind.
Strouty
Southern Maine
I am futzing around with the mill, can’t seem to figure it out. I can make it go through the motions, but I don’t understand what it is asking me for inputs, specifically the x and y arc center. I just don’t understand what that references. The DRO reads different than what the program reads, so I don’t know if I am zeroing things out wrong or what. I may have to talk to the guys that make the program tomorrow, this is driving me nuts.
jack stand
Lakes Region Maine
:thumbup: Good for you! That's the way to do it, heck with just being a tower builder, go for the perpetual income.
Do those tension #'s take all the slack out of the line? Cool stuff Strouty.:beer:
xtremek
St. Johns, Mi
So what's seems to be the issue? You're using a 1/2" end mill, centered from left to right, 1/2" in from the middle, 1/2" down starting at 0 and 4 9/16" dia circle? So what are you getting?
Strouty
Southern Maine
The tension doesn’t take all the slack out, there will still be a visible belly. Those tensions change significantly depending on the ambient temperature.
As for the programming, I don’t know what or where that reference point of 0, 0.5 is, that is my issue.
xtremek
St. Johns, Mi
From what I remember, I was able to set it where I wanted to. It all depended on where I wanted to start from. I put the quill where I wanted 0,0,0 to be, then hit the set button. I'm probably not much help, sorry.
PelicanPines
Pretty much the same thing with fat guys wearing bicycle shorts... no matter the tension... there is the belly... right there.
Strouty
Southern Maine
I have a belly like that.
I figured things out, ended up putting a sharpie in the drill chuck and drawing on cardboard, it became apparent once I took some measurements. The real saga was trying to hold the piece that I needed to modify. I tried to use the vise, but it was too high and would rattle and slowly change positions. Then I tried clamping it to the table, but I didn’t use enough clamps and it popped loose. I finally got it held down and all the previous vibrations loosened up the collet and the endmilll fell out, yes, it just fell out, no dramatic flying across the room. In the end, I had it reset probably a dozen times so nothing was exactly the same, in other words, it was an awful mess. I actually had to use a die grinder to clean it up, biggest issue was when I moved the circle, it was just enough that it left ears at the top edge so I couldn’t just slide the winch into it. I made it work and all in all it was a good experience, but I could have made a totally new bracket in the same amount of time it took me to hack modify this one. I think I spent about 8 hours on it and I didn’t get to clean up the mess I made.
Bracket is made for 4” winch and the other winch is 4 5/8”, at least the bolt pattern was the same.
PelicanPines
Somehow I imagined you sighed when your endmill fell out... before mumbling WTF... then a simple... ok, that's not what I expected.
Honestly your end result looks cool... and you never count the cleanup in the job length... when you're having fun.
Strouty
Southern Maine
Yeah, when it fell out, I was confused for a second, it was in slow motion. I need to understand Workholding better, it is clearly more than half the work.
xtremek
St. Johns, Mi
Sounds like you got a lot of good practice. My take is that your work piece can't be over secure. And I agree with PP, just don't tell him I said that. ;)
Strouty
Southern Maine
I hate to admit this, but when I machined out that circle, I am pretty sure the mill was spinning in reverse. I caught that today, the CNC has a bit different setup from the last machine I used. It has a switch that says low and high, not forward and reverse, I wasn’t paying attention to that I guess. After all that, I still had to slot the holes so that the bolts would fit. It will work fine, but I think I will probably make a new one at some point.
jack stand
Lakes Region Maine
I have wanted some metal machining tools, both a lathe & mill, or even better a CNC table for my plasma cutter for a long time. But the way I am with working any computer (CNC), I stay in very good practice with my grinders to make it look like I have a mill :beer: Your post makes me feel better in some way, thanks.:bounce:
Strouty
Southern Maine
I figure this is like paying my dues, next time it will be a bit quicker and much less of a mess. I can see that I need to come up with some better work holding ideas. The winch is mounted and ready to go for tomorrow and that is all that really matters.
macgyver37
Pittsburg, Kansas
I tried to beat it into my students' head that if you can't hold it you can't cut it.
As you said, most of the work is usually in the workholding and the setup.
What is the control on the mill?
jack stand
Lakes Region Maine
The thing is, you will get faster while I'm cuttin & grinding as fast as I can right now.:thumbup:
Strouty
Southern Maine
It is an EZ Trak DX, conversational programming, but I guess once I figure things out, I can import G-Code with a floppy disk. She is running a nice 486 with DOS.
PelicanPines
That is too funny... way the frack back in time... I wrote the software interface that allowed AutoCad software running a computer like that... to auto upload the program to the CAM/CnC milling machine.
I wrote it at B&D in Rochester NY. Their location where they manufactured the molds used for all of the injection molding.
Best 3 days living in a hotel. Met Andre the Giant... and made a small fortune.
Prior to that software I wrote... they had to burn floppies and hand walk them to each machine...
For what it's worth... the program was about 22 THOUSAND lines long.
EDIT... I just remembered the name of the program SF0022 for Shop Floor... the 22 had nothing to do with the number of lines in the program it was a coincidence …
BoilermakerFan
Indianapolis, Indiana
:lol_hitti :lol_hitti :lol_hitti :lol_hitti :lol_hitti :lol_hitti :lol_hitti :lol_hitti
OMG! This just cracked me up! Floppies, DOS, a 486... C'mon Marty, get back to the future!
Sell off some of those Tamiya goodies and upgrade the controls.
Strouty
Southern Maine
The 486 is actually fine, if, well, when the motherboard dies, I can replace it with a new one with a solid state drive, the latest version of the software for about $1100. The company that took over supporting this from Bridgeport is still supporting essentially every part. There is really no need to upgrade at this point, but someday I want to buy a 3 axis CNC setup, then I will keep this mill as my manual use machine with the bonus of being able to do fancy things.
86turbodsl
You'll get better with time. I do this stuff all the time and still mess up things now and again. Go slow and double check your work often. Good job on the hitch/winch mount!
